Towing Rig Build (planning stage) - JeepForum.com
post #1 of 15 Old 12-20-2010, 07:37 AM Thread Starter
mjkissel
Well I feel like I have had every jeep model under the sun and I keep going back to an XJ. I currently have a 99 xj I use for a dd and work vehicle. Since the work part has beat the crap out of this jeep I am looking to make it into a straight Work Vehicle and build a XJ DD.
Now here is the twist to this build. I want it to be built with mild towing in mind. I have a 1964 Shasta 16' camper that I restored. I have towed this camper with my 99 XJ and got 14 mpg while towing. I have also towed it with my wife's 06' Grand Cherokee and only got 9 mpg. So the XJ looks like a good choice to start with. The Shasta is around 1800 lbs. I tow it once or twice a month. So the new XJ will need to be a good DD first, towing second, off road (trail riding) third.
I want to start with a high mileage 99-01 XJ. I am looking at possibly a stroker build options, possible diesel conversion or the elusive 2.5 diesel, and finally sticking with the stock motor and maybe doing a top end rebuild with cam and head work and a bunch of bolt on parts. I do want to maybe put a 3" lift with only 30" tires.
I want all this and to improve the mpg while towing. If I could get 17mpg while towing I would be thrilled. I say high mileage because I am going to rebuild the suspension and trans so that I am starting from scratch.
Let me know if I can have a good DD with enough torque to tow and get good mileage while doing so.
mjkissel is offline
post #2 of 15 Old 12-20-2010, 03:51 PM
egodfrey
egodfrey's Avatar
put lower gears in your axle
So many people to thank here's a start to the list
Spidertrax, Yukon, rustys, warn, branik, PSC, advance adapters, Bad wheels, interco, essentially off-road. And many more
Most of all thanks too Ian Johnson and the xtreme off-road crew for all their work, and 4 wheel to heal for their part in it too.
egodfrey is offline
post #3 of 15 Old 12-20-2010, 04:23 PM
furius
if you don't care for speed, and you want reliability i don't know the mph i just heard that jeep released a new 4.7 stroker I6 you might want too look into that. plus you would have gobs of torque for towing or trails. just make sure to get an OD for highway.
furius is offline
post #4 of 15 Old 12-20-2010, 04:35 PM Thread Starter
mjkissel
Yep that would work for the "torque" part but it will put my MPG in the tank.
mjkissel is offline
post #5 of 15 Old 12-20-2010, 04:39 PM Thread Starter
mjkissel
I am looking pretty hard at a stroker. On my way home tonight I was getting 24 MPG at 60mph. So if I went with a stroker and kept it above 20 mpg I would be happy with that for DD. I would guess that due to the extra torque that my towing MPG would still be around that 14MPG mark I am seeing now
mjkissel is offline
post #6 of 15 Old 12-20-2010, 06:05 PM Thread Starter
mjkissel
Here is what I am towing around.
mjkissel is offline
post #7 of 15 Old 12-21-2010, 01:25 AM
jeepkid46
1994 XJ Cherokee
if you wanna look into doing it yourself this is pretty good info Stroker's - Jeep Cherokee Forum plus the tv show trucks has a stroker rebuild show on there cheep cherokee project
jeepkid46 is offline
post #8 of 15 Old 12-21-2010, 05:12 AM
Mikeand
jeepstrokers.com great forum for stroker info. Ive only gotten 15mpg with my stroker.
1996 Cherokee Sport -4.6L Stroker, TB Spacer, Cold Air Intake, APN Header - D30 front / 8.25 Rear -RC 3" Lift -Dakota Leaf Pack -Rough Country Discos / -31" General Grabber A/T2s on 15x8 Cragar Soft 8s -Diamond plate rear quarter panels -Front bumper with hoop - IRO Double shear Track Bar and HD tie rod -Homemade light bar
Mikeand is offline
post #9 of 15 Old 12-21-2010, 06:34 AM Thread Starter
mjkissel
Mike
Did you upgrade your head when you did your stroker?
mjkissel is offline
post #10 of 15 Old 12-21-2010, 07:21 AM
Mikeand
Upgrade to what? Its got larger chevy valves in it. ported and all the works.
Mikeand is offline
post #11 of 15 Old 12-22-2010, 07:40 AM
furius
looks like your set up is pretty nice as it is, that trailer should only be putting 10% of its weight on your hitch if it is set up right. i am wondering though would putting a little more suspension to stiffen up the rear help his towing mph.
furius is offline
post #12 of 15 Old 12-22-2010, 08:35 AM
furius
i just had a thought your jeeps are pretty new you could have the option of performance chips. those can always be changed back. they are probably worth looking into.
furius is offline
post #13 of 15 Old 12-22-2010, 10:04 AM Thread Starter
mjkissel
Yep I am looking at that as well. From my limited research here on the forum it looks like so,e of this chip end up getting overridden by the factory computer. So I am trying to fin a "good one"
mjkissel is offline
post #14 of 15 Old 12-22-2010, 10:09 AM Thread Starter
mjkissel
The grand Cherokee in the picture towed the Camper like a dream, but on long runs it only gets the 9mpg and since it is 4wd the front differential over heats and requires a fluid change after towing. The front diff oil change is around $50 in material plus my time.
So that is why the XJ is a better rig plus the drivetrain is more rugged and easier to work on, plus cheaper to maintane.
mjkissel is offline
post #15 of 15 Old 12-23-2010, 08:25 PM Thread Starter
mjkissel
Alright so the plan has changed. My current 99 XJ DD blew up the water pump and radiator on the way home yesterday. So I ordered a "sever duty" water pump and CSF 3 row radiator. So the tow rig build begins.
My 99 XJ has 222k miles on it. The trans was replaced at 130k, so it will be the weak link I will be keeping my eye on. Since it was my DD I need to go through the suspension completely. The rear spring sags even with a bag of groceries in the back
mjkissel is offline
my cherokee build... Stage II 1sickXJ XJ Cherokee Technical Forum 11 03-15-2009 11:16 PM
Need help planning my XJ build! Corndork2 XJ Cherokee Technical Forum 27 02-22-2009 01:53 PM
JCR Stage 2 bumper PESteele XJ Cherokee Technical Forum 6 09-06-2007 08:09 PM
Jet Chip: Stage 1, 2 or not at all??? liviu XJ Cherokee Technical Forum 2 04-16-2006 10:44 PM
