Quantcast Towing 4000lbs in '00 Sport ok? - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Towing 4000lbs in '00 Sport ok?
Truck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE NeededRuffstuff Axle Simple Swap Kit!
Old 11-22-2009, 06:57 AM   #16
tjwalker
It's the crank sensor!
tjwalker's Avatar
Originally Posted by Techno Duck View Post
Thanks for all your input. I guess I'll start thinking about a more capable tower. Maybe a used F350 diesel, my friend just bought one, ne'er thought I'd like a turbo diesel pickup, but a great ride.
Now you're talking. An F350 diesel would be a great choice for towing your ride.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline   Reply With Quote
Old 11-22-2009, 07:18 AM   #17
lcarney91
Why does everyone jump straight to a one-ton truck when a guy asks about towing 4-5000 pounds? Sure, an F350 Powerstroke would be a good tow rig, but so would just about any full-size truck with a V8. Most newer half-tons are "rated" to tow somewhere between 6500-11000 pounds. Back to topic, your XJ WILL tow 4000 lbs. It will not be easy on it though. I pulled my 3500 pound camper through the mountains last summer, even at speeds of 70+ and temps around 90. By no means was it good for my XJ, but it handled it. I have since bought a Dodge half-ton to handle my towing needs.
Here is an example of how my Jeep lived for a little over a year:
1999 XJ.....
Stock, with some intake/exhaust work
"The ol' family truckster"
lcarney91 is offline   Reply With Quote
Old 11-22-2009, 08:43 AM   #18
Kettles
Kettles's Avatar
Originally Posted by Deezelweazel View Post
I have the slight feeling that trailer mounted overrun brakes are totally unkown in the US?
Am I right?
I wouldn't tow anything more than 1600lbs with a trailer without an overrun brake.
I think they call them surge brakes here. Not too popular I think, when you come to a stop it jerks alot. So the midrange trailers 1500-3500lbs usually are brake less in my experience. Then electric brakes for heavier. But having trailer brakes is a very good idea I dont know why most of our midrange trailers don't have them. I have owned 2 boats and my has uncle one, my friend has one, and my ex-uncle has one, none of which had any brakes, and they all are around 3000lbs.
And lcarney91, we didn't suggest a one ton diesel, the OP did. Tjwalker was just saying it would be a great tow rig.. and it would be, but that doesn't mean you NEED a f350 diesel. I just said a fullsize truck. A f150 would be fine (or equivilent), and a beater one can be had really cheap, atleast around here. (of course ford has two truck plants in Louisville, so there are alot of fords) so that is what I would suggest..
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output Pictures Build Thread
"Live Free Or Die; Death Is Not The Worst of Evils."
-General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline   Reply With Quote
Old 11-22-2009, 09:45 AM   #19
rivalarrival
Stormaggedon
rivalarrival's Avatar
Surge brakes aren't unpopular - lots of utility and boat trailers have them. The worst characteristic I discovered: when you lose braking traction in the truck, you lose ALL braking traction. In the meantime, you've become accustomed to a certain stopping distance because the trailer brakes are assisting. When the reason for you losing all traction is hard ice under water (due to a broken water main) these three factors combine to let you slide nearly 200 feet at about 3 MPH, through a red light and jack knifing into the next intersection.
Ask me how I know this.
He that would make his own liberty secure, must guard even his enemy from oppression; for if he violates this duty, he establishes a precedent that will reach to himself. --Thomas Paine
We work together every damn day. --Jon Stewart
Any gas can be a knockout gas, when you wrap a steel cylinder around it and beat someone with it.
Low Output 4 Cylinder Jeep Club member #188
rivalarrival is offline   Reply With Quote
Old 11-22-2009, 09:46 AM   #20
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
I've been towing for nearly 40 years and I towed several larger boats for many miles behind the '89 XJ I used to have. Yes, absolutely my XJ was rated for 5,000 lbs. It said so right in the documentation when I bought my brand-new XJ that had the factory tow package. Would I have actually towed a 5,000 lb. trailer with my XJ any distance on the highway? No frigging way, absolutely not.
That 5,000 lb. rating is only under perfect ideal conditions. My XJ's wheelbase and weight (lighter than my current TJ) made it marginal for even my 4,000 lb. boat. Heck I when I towed that same boat and then a newer 20' power boat even with our WJ with its larger V8 engine I wished I had a V8 truck. But with the XJ, I knew when I was towing to pray to stay out of any emergency maneuvering situation where that boat would have taken the XJ over... akin to the tail wagging the dog. Yes it may have been rated for 5K lbs. but having towed a lot of bigger boats behind a lot of different vehicles over that nearly 40 years, my XJ was adequate for 3500-4000 lbs. most of the time but it was right on the edge of being safe. And all of my trailers have always had either surge or electric brakes. A vehicle's actual tow limit, regardless of what the brochure says, is a combination of its official weight limit mixed in with a lot of common sense.
5,000 lbs? Well, officially yes... but in my personal opinion, I think that much weight capacity is from the marketing department wanting to help it compete against larger vehicles and definitely not from the Jeep Dept. of Common Sense.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is online now   Reply With Quote
Old 11-22-2009, 10:26 AM   #21
GregB_00XJ
GregB_00XJ's Avatar
Well put...
I agree, at 50% of rated capacity (or a little bit more) my XJ tows excellent. Would I want to go above 3500 LBS, no. I don't think it is advisable to go to the rated tow capacity of ANY vehicle. Use the "common sense" laws, not state/provincial laws or the vehicles manual. If rated to tow 5000 pounds, keep it to 75% MAX and you will tow that day in day out safely and happily for years to come.
Oh and in Canada (BC at least) any trailer over 2500 pounds MUST have an active braking system i.e. electric/hydraulic/surge brakes. As a side note on surge brakes, I hear that they suck hard for backing up unless you are captain smooth on the gas?
Hooked up for towing...
2000 Jeep Cherokee Classic
1992 M101 CDN2 1/4 Ton Off-road Trailer. 90% Daily Driver 100% Fun!
____=__=
l l ,[_____],
l---- L -[]lllllll[]-
()_) ()_)--o-)_)
GregB_00XJ is offline   Reply With Quote
Old 11-22-2009, 10:40 AM   #22
justanotherjpr
With a WDH, trailer brakes, and a rear disc conversion kit, I think you'd be OK if you took it easy, but you'd be better off with something heavier. The 4.0 will pull all day long, but at the end of the day, the XJ was designed as, and is, a light weight vehicle.
FWIW, I have towed a 2001 Explorer Sport on a tow dolly and it stopped just fine without trailer brakes. I did not have a tounge load since it was a tow dolly, but I did have to move the weight. The Explorer has a D30 swapped in an 33" tires. I had (at the time) 33" tires and 3.55 gears. It moved and stopped without issue. However, I kept it under 55mph. YMMV.
Edit: As you can see, there was no WDH (no tounge load) and no 'trailer' brakes.
justanotherjpr is offline   Reply With Quote
Old 11-22-2009, 11:46 AM   #23
Jerry Bransford
You are correct. My boat trailers all had surge brakes and I couldn't back any of them up any useful amount. Surge brakes usually come with a big cross-bolt that is inserted into the top of the mechanism that prevents the brake mechanism from actuating while backing up. Without that bolt inserted, I really couldn't back my boat up at all.
Getting Savvy...
Old 11-22-2009, 12:09 PM   #24
XJmaine97
1997 XJ Cherokee
I tow my '69 Grady White behind my '97 sport, its probably around 5000lbs w/ 15 gallons (30 gallon tank). its a bear of a tow and I would never tow it more than 20-30 miles. The XJ has the power but going down hill is a little hairy and I don't know what would happen if I had to stop quick behind some nut.
Just my two cents.
XJmaine97 is offline   Reply With Quote
Old 11-22-2009, 01:36 PM   #25
Techno Duck
Was just thinking out loud about the F350. I think I may go with a newer grand cherokee. I prefer SUV over pickup anyhow. Hate to have to bother selling the XJ now, what a reliable daily ride thts actually relativley fun to drive.
Jon
'88 Porsche 951 (track car)
'00 Jeep Cherokee Sport
Techno Duck is offline   Reply With Quote
Old 11-22-2009, 05:38 PM   #26
GregB_00XJ
GregB_00XJ's Avatar
Yes,
I would probably go with the Grand with a V8 if I was going to tow anything heavier than what we have now. Since we just bought the tent trailer new, I imagine we will have this for at least 5 or 6 years... and I just spent a bundle on the lift etc so...
F350 Diesel would rock, but I too lean towards the SUV. My last vehicle was a Dakota Extended Cab, miss it sometimes, but most of the time you are hauling around a lot of empty space.
____=__=
l l ,[_____],
()_) ()_)--o-)_)
Old 11-22-2009, 06:06 PM   #27
rivalarrival
Stormaggedon
If I already had an SUV, I'd keep it and go with a heavy duty pickup, just to expand the capabilities of my fleet. Kinda hard to put a fifth wheel on a Suburban without some major mods.
Of course, it's kinda nice to be able to haul 8 people and a big-*** boat with one truck...
Old 11-22-2009, 06:41 PM   #28
98GooseXJ14
98GooseXJ14's Avatar
jeeps are rated at 5000 lb towing but you do need brakes on the trailer for that much if you plan on stopping.
1998 Cherokee XJ 159k miles
"I may get lost, but I never get stuck"
There was a distinct moment where I felt the Jeep go past the center of gravity. My buddy and I looked at each other and just said "Oh ****".
98GooseXJ14 is offline   Reply With Quote
Old 11-22-2009, 07:00 PM   #29
Techno Duck
Keeping the Jeep is an idea, frankly they aren't worth much to make selling worth while. But that would leave me with 3 cars and a trailer. No space for everything. I work offshore in month long rotations so I usually keep everything at my parents place when I'm at sea. Don't want to have the driveway at my parents filled up with all my crap .
Jon
Old 11-22-2009, 08:14 PM   #30
Kevin108
Back from the dead @ 167k
Kevin108's Avatar
I spent 350 miles with around 1,600 lbs behind me yesterday. It's going to be too much for an XJ. Not only is stopping an issue but the short wheel base makes things a lot less controllable. Even a small trailer can exert a lot of leverage on our little rigs.
It took me a while, but I finally figured it out: catastrophic failure and
the subsequent repairs is the Jeep thing they're always talking about.
Kevin108.com | My 2000 XJ Build | Hampton Roads Jeep Club
How to reindex the camshaft position sensor on an 00-01 XJ
Tips on trimming 97+ XJ bumper end caps and lower facia
Kevin108 is offline   Reply With Quote
Glock Forum
