Towing - JeepForum.com
post #1 of 5 Old 08-14-2002, 08:11 PM Thread Starter
GrantMLS
Towing
Got an 1988 4.0L Auto 4x4 jeep with around 175,000 miles on it. (just figured out it gets 17.5 mpg!) I currenly pull my race bike on an open 4x8 trailer but am about to purchase a 5x8 enclosed trailer. The trailer weighs 840lbs and bike with tools weighs around 400lbs. Is this gonna be a problem on long pulls? OR just keep a good steady pull? I have a bigger thens tock Radiator and a replacement trans cooler.
anyone else tow with an older Jeep?
GrantMLS is offline
post #2 of 5 Old 08-14-2002, 09:57 PM
arpy
The Cherokee with 4.0 and auto with a trans cooler and class 3 hitch can tow 5000 pounds. Even with a lighter hitch you should have no trouble at all. Just be sure your brakes are tip top.
arpy is offline
post #3 of 5 Old 08-14-2002, 11:25 PM
BrianG
depending on how far you drive, or how hot your area is, you may want to convert the closed cooling system.
1988 XJ - 4.0; RE 3.5"; rear D44 w/ ZJ disc brakes; 31x10.50 BFG ATs; Sanden OBA
BrianG is offline
post #4 of 5 Old 08-15-2002, 01:10 PM
glenzx
glenzx's Avatar
Also make sure your rear differential fluid is in good shape! The added load of a trailer really punishes the diff. The Trans. cooler is a good investment. Make sure the rear suspension and shocks are in good shape too. All pretty basic stuff, but make a huge difference!
glenzx is offline
post #5 of 5 Old 08-18-2002, 08:38 PM Thread Starter
GrantMLS
thanks for all the tips. I am just fixing my oil leaks, changing out all the fluids and I will be going to pick it up. Also going and installing new shocks.
GrantMLS is offline
Towing the XJ Motorcharge XJ/MJ Cherokee Non-Technical Forum 3 05-12-2009 12:18 PM
towing 88wagon XJ Cherokee Technical Forum 1 02-10-2007 12:17 PM
Towing and Towing package. CherokeeClassic XJ Cherokee Technical Forum 8 07-09-2006 11:58 PM
Towing honas XJ Cherokee Technical Forum 3 06-20-2005 01:30 PM
xj towing xj ? ChipsXJ XJ Cherokee Technical Forum 4 04-14-2005 04:38 AM
