Tow Bar Connections?? - JeepForum.com
post #1 of 5 Old 08-17-2002, 12:26 AM Thread Starter
BBJeepXJ89
I just bought a tow bar today from Draw-Tite and it came with installation brackets....these brackets are either supposed to attach to the frame or the bumper, but i dont think the bumper would be strong enough. Anyone purchased anything like this? If so if you could help me out with some installation advice, that would be excellent, thanks -BB
BBJeepXJ89 is offline
post #2 of 5 Old 08-17-2002, 09:04 AM
White-Knight
To be real honest, I don't have much in the way of experience here, but here's what I've been told: attach it to the frame - the bumper won't be able to handle the weight generally. Whatever level of receiver it is, you're looking at what, a thousand pounds and up? I don't think I'd want that just attached to the bumper. When I had my '88 Jimmy, I had a similar hitch and it was bolted straight onto the frame. Don't know if this helps any, but there's my 2 cents.
White-Knight is offline
post #3 of 5 Old 08-17-2002, 10:13 AM Thread Starter
BBJeepXJ89
I was reading over the directions before I went to bed last night and it says to fabricate a device that will reinforce the bumper...As much as I believe in Draw-Tite, this kit sounds rediculous. I can bolt and drill, but when it comes to fabricating a device, I'm not sure... Draw-Tite 5,000 lbs Economy Tow Bar Scroll all the way to the bottom to look at the tow bar, from what I understand there are no other mounting options, just the T-Brackets.
post #4 of 5 Old 08-17-2002, 11:51 AM
CruzNlife1
CruzNlife1's Avatar
yeah that does sound a little ridiculous, but i would definitly connect to the frame
1989 Jeep Cherokee XJ LIMITED....2door.... Auto, NP242 4x4...
1996 Ranger Supercab....
1991 Mustang LX....
VERY SOON TO BE A BRAND NEW TJ OWNER, TRYING TO LEARN AS MUCH AS POSSIBLE RIGHT NOW !!
CruzNlife1 is offline
post #5 of 5 Old 08-17-2002, 01:00 PM
EricsXJ
The Post man
EricsXJ's Avatar
I don't have experience with these either but obviously the tow bar itself isn't going to be strong enough and you don't want to attach it to the bumper.
If it was me, I would get one of these
Its a "tow plate" from www.tomken.com for under $100. Oddly this one with a 2" receiver is cheaper than the one without the receiver??? Anyways you need something like this that ties into both frame rails. Then somehow attach the tow bar to it. Tomken also has tow bars and brackets but state the brackets can be attached to any "stout" bumper, which the stock one is not.
Eric
2000 XJ "PROJECT RUBICON" 3-link front / 4-link rear / coilovers / running 37's on Dana 60s
My website -
EricsXJ is offline
No spark, unplugged connections? TajMan4X4 MJ Comanche Technical Forum 6 10-04-2007 01:52 AM
Head bolts and fuel line connections 98tXJ XJ Cherokee Technical Forum 5 06-02-2006 11:26 PM
wiring harness connections max09108 XJ Cherokee Technical Forum 1 02-15-2006 06:26 PM
Fuel Filter Connections? cmotsvt XJ Cherokee Technical Forum 1 03-06-2005 05:53 PM
Factory fog lamp connections or make new? JBassXJ XJ Cherokee Technical Forum 8 06-03-2004 11:49 AM
