torque and tighting the valve cover - JeepForum.com
post #1 of 5 Old 03-11-2012, 05:46 PM Thread Starter
RamboPants
1987 XJ Cherokee
ruined my haynes manual can someone give be the torque spec and the tightening sequence for an 87 4.0 thanks.
RamboPants is offline
post #2 of 5 Old 03-11-2012, 10:24 PM
AZ Jeff
2014 JK Wrangler
It's 85 INCH-pounds. Unless you have a in-lb torque wrench, the next best thing is "wrist tight" with a quarter inch drive socket and ratchet. They don't have to be killer tight, just enough to compress the gasket a little. Recheck them in a day or so in case the gasket takes a set.
Tightening sequence is not important, but if you are worried, start in the middle and work out to the two ends.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #3 of 5 Old 03-12-2012, 12:33 PM
unkajeffy
inch pounds divided by 12 is foot pounds so 7 foot pounds.
Michigan Yankee in Redneck Land
unkajeffy is offline
post #4 of 5 Old 03-12-2012, 05:18 PM
AZ Jeff
2014 JK Wrangler
Very few ft-lb torque wrenches are accurate at readings THAT low. Its best to do "wrist tight" if you dont own an in-lb wrench.
AZ-Jeff
AZ Jeff is offline
post #5 of 5 Old 03-18-2012, 11:35 AM Thread Starter
RamboPants
1987 XJ Cherokee
I just wrist tightened it seems to be holding up fine. Thanks
Torque for FelPro rubber valve cover gasket... Yojimbo XJ Cherokee Technical Forum 2 09-10-2010 01:16 PM
valve cover torque 1gopokes1 XJ Cherokee Technical Forum 4 06-29-2007 12:13 PM
Torque specs for valve cover 1996xj XJ Cherokee Technical Forum 10 08-20-2006 09:14 AM
Need torque spec for valve cover... Yojimbo XJ Cherokee Technical Forum 3 09-09-2004 05:12 PM
Valve cover torque? thewooddogg XJ Cherokee Technical Forum 2 02-14-2003 12:39 PM
