Torque Specs on Head Bolts - JeepForum.com
post #1 of 7 Old 08-29-2008, 06:03 PM Thread Starter
ineffablelove
I am in the middle of putting my Jeep back together and cannot find my Haynes manual after recently moving. Anyone have the torque specs for the head bolts on a 96 4.0?
ineffablelove is offline
post #2 of 7 Old 08-29-2008, 06:30 PM
Ed Rico
1997 XJ Cherokee
Per the FSM, torque all head bolts in sequence in a spiral pattern to 22 ft-lbs, then 45 ft-lbs. The final torque value is to 110 ft-lbs on all head bolts except the driver's side front, which is torqued to 100 ft-lbs with Loctite 592 (PTFE) on the threads. All other head bolts are installed with dry threads.
-Ed Rico
Ed Rico is offline
post #3 of 7 Old 08-29-2008, 06:31 PM
AZ Jeff
2014 JK Wrangler
From the FSM:
(4) Coat the threads of stud bolt No.11 with Loc-
tite 592 sealant, or equivalent.
(5) Tighten the engine cylinder head bolts in
sequence according to the following procedure (Fig.
56).
CAUTION: During the final tightening sequence,
bolt No.11 will be tightened to a lower torque than
the rest of the bolts. DO NOT overtighten bolt
No.11.
(a) Tighten all bolts in sequence (1 through 14)
to 30 Nm (22 ft. lbs.) torque.
(b) Tighten all bolts in sequence (1 through 14)
to 61 Nm (45 ft. lbs.) torque.
(c) Check all bolts to verify they are set to 61
(d) Tighten bolts in sequence:
• Bolts 1 through 10 to 149 Nm (110 ft. lbs.)
torque.
• Bolt 11 to 135 Nm (100 ft. lbs.) torque.
• Bolts 12 through 14 to 149 Nm (110 ft. lbs.)
torque.
(e) Check all bolts in sequence to verify the cor-
rect torque.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #4 of 7 Old 08-29-2008, 06:32 PM
AZ Jeff
2014 JK Wrangler
Ed Rico beat me to it. Dang, he's fast.
AZ-Jeff
AZ Jeff is offline
post #5 of 7 Old 08-29-2008, 06:38 PM
Ed Rico
1997 XJ Cherokee
It's all good, Jeff. I just went with the condensed version.
-Ed Rico
Ed Rico is offline
post #6 of 7 Old 08-29-2008, 07:54 PM
durango-bob
2006 WK
If you need more info, check out the tech section at GreatLakesXJ.com
durango-bob is offline
post #7 of 7 Old 08-30-2008, 10:27 AM Thread Starter
ineffablelove
Thanks guys, she's back together! I don't know how the back right bolt is going to be because I had to use a swivel... but there's only one way to find out. Thanks again.
Bolts and torque specs for springs, shackles, etc? GibeonXJ XJ Cherokee Technical Forum 2 02-02-2008 07:25 AM
4.0 torque specs for head! rivers edge XJ Cherokee Technical Forum 2 04-16-2007 04:40 PM
Diff Cover Bolts - Torque Specs? sjd78 XJ Cherokee Technical Forum 9 01-26-2007 08:05 PM
torque specs for the head bolts? 600dollarXJ XJ Cherokee Technical Forum 1 12-03-2005 06:42 PM
torque specs on suspension bolts janes5150 XJ Cherokee Technical Forum 6 07-15-2004 01:16 PM
