Torque specs and bolt pattern for 4.0 Valve Cover? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Torque specs and bolt pattern for 4.0 Valve Cover?
Build your Dream Jeep with Poison Spyder's Interactive GarIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!
Unread 08-20-2007, 03:07 PM   #1
76CJ5
1993 XJ Cherokee
Does anyone know the torque specs and the boltr pattern for the 4.0 Valve cover?
It's a 93 with a 4.0.
I plan on using gasket sealer, etc but I was wondering what the factory settings are.....
76CJ5 is offline   Reply With Quote
Unread 08-20-2007, 03:15 PM   #2
76CJ5
1993 XJ Cherokee
Looks like 80 Inch lbs for the cover bolts or 9 N.m.....
I have a factory service manual in PDF so its a little hard to find these things.
Still hoping to find a sequence.....
Unread 08-20-2007, 03:17 PM   #3
76CJ5
1993 XJ Cherokee
I guess if I can't find one I should just crisscross from the inside to the outside.
Unread 08-20-2007, 06:24 PM   #4
Rock Kustoms
93 is a steal valve cover, you should get the gasket, but its expenive for the newer years, reuable gasket tho. i beleive the 87-90 cork gaskets fit, and are about $6
as far as specs, never had one leak just jumping around w/ my 1/4" air ratchet
Rock Kustoms is offline   Reply With Quote
Unread 08-20-2007, 06:34 PM   #5
severous01
start from center and go out on both sides.
tq is 74-80"lbs
1994 jeep cherokee, xj, 3" rough country springs / bilstein 5100's, 31" tires with trimmed fenders, aussie locked front diff, herculined ext, hella FF75 driving lights on factory fog location
[COLOR="Lime"]soon to be[/COLOR] 4.11 gear and and a ford 8.8 LSD rear and herc'd interior
severous01 is offline   Reply With Quote
Unread 08-21-2007, 09:17 AM   #6
76CJ5
1993 XJ Cherokee
Ended up using the cork gasket and put RTV on both sides. Hopefully that will make a good seal.
Unread 08-21-2007, 09:18 AM   #7
76CJ5
1993 XJ Cherokee
tq is 74-80"lbs
Thanks
Unread 08-21-2007, 09:19 AM   #8
76CJ5
1993 XJ Cherokee
Probably shoulda done that.....the cork gasket has me a little worried.
