Torque Converter Clutch - JeepForum.com
post #1 of 3 Old 02-13-2009, 01:41 PM Thread Starter
LimpZip22
i've had a check engine light on for a while and went and got the codes read at pepboys. it came back as a torque converter clutch circuit malfunction. from the couple of people i have talked to it could range from a wire being off, to needing new fluid, to needing a whole new tcc. i was wondering if anybody has any suggestions theres 130k on the jeep and ive had it since 85k with no tranny flush or any tranny stuff done. im tired of looking at that ****ing light and want to get my jeep back in shape. any suggestions or tips on how to fix this issue would be awesome, i also really dont know what the tcc is so any other help would be great too.
LimpZip22 is offline
post #2 of 3 Old 02-13-2009, 02:10 PM
oisiaa
The torque convert clutch allows your torque converter to lock so that the engine drives the transmission directly without any slippage. In older cars there would always be ~10% slip during steady state driving which kills fuel economy.
oisiaa is offline
post #3 of 3 Old 02-14-2009, 02:19 PM
gfh004
I have the same year as you and had the same problem but I have many
more miles.Three shops said I needed a rebuild but I thought I would
try changing the fluid to see if that would stop the tcc error and engine light.
After changing the fluid the error is gone and it's been 10 months since
the engine lights been on.
gfh004 is offline
torque converter clutch circuit malfunction DexFie XJ Cherokee Technical Forum 4 05-03-2010 06:58 PM
Torque converter clutch solenoid (TCC)help? ytbrown XJ Cherokee Technical Forum 2 09-07-2009 07:47 PM
torque converter clutch solenoid mephastopholes XJ Cherokee Technical Forum 2 08-29-2008 05:55 PM
Torque converter clutch solenoid, code 0740 Timberwood XJ Cherokee Technical Forum 0 04-14-2008 08:28 AM
torque converter clutch solenoid? JoshZ XJ Cherokee Technical Forum 1 08-28-2005 07:13 PM
