Quantcast Top Dead Center on a 4.0? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Top Dead Center on a 4.0?
TJ 5.25" Speaker Adapters - NalinMFGSpartan Lockers FREE SHIPPING Excellent PricesRough Country Deals at JeepHut.com
Old 12-11-2007, 01:11 PM   #1
RamboPants
1987 XJ Cherokee
I need to replace a rocker arm and possibly a rod in my 4.0. Would i need to unbolt all the bolts and rockers just to replace 1? Would i need to find top dead center before unbolting anything?
RamboPants is offline   Reply With Quote
Old 12-11-2007, 03:02 PM   #2
AZ Jeff
This is like the third thread you have put up in the past 24 hours related to the valve train on your engine. I asked this before in one of the other threads: what makes you think your valve train has issues?
Do you have lifter noise (valve train clatter) with the engine running? If so, have you isolated it to this particular valve?
Furthermore, just because the rocker arm is loose, it's not necessarily the arm that is the faulty component. You may have a bad pushrod, or a collapsed lifter instead. (Having either one of those would probably result in lots of valve clatter, so that's why I asked what your symptoms were.)
The only way to know for sure is to measure valve lift on one or more cylinders and compare it against the one you suspect is defective/loose. Just pulling and replacing parts may be a waste of time and money.
AZ-Jeff
1992 XJ 2" lift -- RIP
2000 XJ 3" lift -- Australian Ford Big Brakes up front, rock rails, ZJ rear discs (with WORKING parking brake), C4x4 rear bumper/tire carrier, Hella H4 headlights, IPF driving lights, OEM skid plates, OME springs/shocks, JKS LCA's, JKS Sway Bar links.
AZ Jeff is offline   Reply With Quote
Old 12-11-2007, 04:08 PM   #3
RamboPants
1987 XJ Cherokee
No its the 2nd and you didn't reply to the other one. I getting tapping from time to time that i know isn't normal. I get tapping going up hills. I was changing my valve cover and decided to check to see if anything was loose, I noticed one of the rockers were loose. So i pulled it out and replaced it along with the rocker beside it and both pivots. Now when i tighten it, it dosn't move then when i check it a minute later its loose again along with the one beside it.
Old 12-11-2007, 04:14 PM   #4
Mikeand
Uh yeah because the valve isnt being compressed, so no pressure on the rocker arms. Lol if they were totally tight all the time, how would they rock..hence rockers lol...You might be hearing pinging coming from inside the cylinders, since you say you hear it while going up hill or while the engine is under stress..or who knows could be a rod bearing, crank bearing...
1996 Cherokee Sport -4.6L Stroker, TB Spacer, Cold Air Intake, APN Header - D30 front / 8.25 Rear -RC 3" Lift -Dakota Leaf Pack -Rough Country Discos / -31" General Grabber A/T2s on 15x8 Cragar Soft 8s -Diamond plate rear quarter panels -Front bumper with hoop - IRO Double shear Track Bar and HD tie rod -Homemade light bar
Mikeand is offline   Reply With Quote
Old 12-11-2007, 04:22 PM   #5
RamboPants
1987 XJ Cherokee
crap, so those loose rockers i just replaced are fine? Oh yeah so why are all the other rockers tight?
Old 12-11-2007, 05:38 PM   #6
AZ Jeff
Because those valves are partially or fully OPEN. Gotta remember, every valve is open for SOME portion of the rotation of the camshaft.
Valve train parts won't clatter just going up hills. It will clatter ALL the time when you have valve train issues.
Noises "going up hills" sounds like spark knock/preignition. That's REAL common on slight loads (such as steady mild grades) and with low engine speeds.
It's caused by carbon buildup on the piston tops and/or combustion chamber in the head, and is pretty common in older engines with high mileage.
Have you run higher grade gas? 89 octane or even better, 91 octane, will inhibit this spark knock. If you run a couple of tanks of this higher grade of gas, and it goes away, then you have POSITIVELY identified your source of the issue.
Do that, and tell us what happens. Personally, I think you are barking up the wrong tree with looking at your valve train, because the noise you describe does not sound valve train in nature.
AZ-Jeff
Old 12-12-2007, 12:58 PM   #7
RamboPants
1987 XJ Cherokee
Got the new rockers and all in place, Guess what...no more clicking.
Glock Forum
