Quantcast TNT long arm 5.5 suspension installed finally - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > TNT long arm 5.5 suspension installed finally
Old 03-05-2006, 01:57 PM   #1
winks00XJ
Before:
Still need to do some finishing touches and may need to add spacers up front to level it out. I think the front bumper and winch may be why it is lower in the front.
After:
winks00XJ is offline   Reply With Quote
Old 03-05-2006, 02:27 PM   #2
SpikeSpeigel
What spring combinations did you use? If the rear has new spring packs, give 'em some time to settle. Looks good. What size tires are you running/planning on running? I'm about to jump to 35's. My 33's just look to small.
[B]'99 XJ 4x4[/B]
[SIZE=1]RE 5.5" front coils, TNT Customs Y-link radius arm kit, S-10 rear leaves, RE .75" shackles, ORO u-turn steering, SYE/CV driveshaft, YJ brake lines, 33" BFG MT's, K&N drop-in, Flowmaster 40 series, Tow hooks, Trimmed fenders, M.O.R.E. motor mounts, TNT Customs frame stiffeners, RE HD trackbar/mount, Autometer Trans temp gauge w/ pillar pod
[/SIZE]
"Sticking feathers up your butt does not make you a chicken!!"
[CENTER]-Tyler Durden[/CENTER]
SpikeSpeigel is offline   Reply With Quote
Old 03-05-2006, 03:08 PM   #3
youngwon22
thats very nice...that is a beefy looking bumper!
well if you've got the long arms, you gotta post up some flexing pics..no?
youngwon22 is offline   Reply With Quote
Old 03-05-2006, 03:31 PM   #4
javik
what size tires are those on there now?
javik is offline   Reply With Quote
Old 03-05-2006, 04:18 PM   #5
winks00XJ
The rear springs are RE 3.5 inch lift and I was wondering about them. I hope they settle some, if not I will just go up highre in the front to match. The tires on there now are 267/75/16. They look pretty small. I am planning on running MTR's that are similar in size to a 33/12.50 for a 16 on Rubicon Moab wheels. At this time I dont want to cut the fenders, I guess time will only tell the truth. As for some flex pics here are a few where I parked in my yard for now. Still needs to go to the alignment shop and also need to get shocks for it, just not sure what shocks to run. Ideas?
Nothing to extreme, just feels really wierd without shocks.
Old 03-05-2006, 04:25 PM   #6
law.74
Looks sharp!
law.74 is offline   Reply With Quote
Old 03-05-2006, 04:34 PM   #7
javik
are you running 1.5 shackles and 3.5 springs plus their u bolt eliminatiors out back?
Im really interested in this kit and how it drives. How do you like its onroad handling(after the alignment of coarse)
What did you do on the part where they say to massage the pinch seam on the LCA bracket? got any clearance probs with the arms?
Thanks man, looks real nice.
If you are selling those tires and rims give me a hollar, i like that 31.5 size in metric.
Old 03-05-2006, 04:47 PM   #8
Blue XJ
1988 MJ Comanche
What track bar is that?
'88 MJ
Blue Jeep Club Member #72
| 4.6L Stroker | AW4 | 6.5" RK Long Arm Kit | 35" TruXus MT's | HP30, 4.56, ARB, Alloys, Lockouts | C8.25, 4.56, ARB, Alloy Shafts, Disk Brakes | Warn XD9000i | Interior Cage |
Blue XJ is offline   Reply With Quote
Old 03-05-2006, 04:49 PM   #9
jeepster89
looks good that will be that long arms im getting for mine i hear they are really nice i might be sitting a little higher though either way sweet rig
1989 jeep cherokee,stock front and rear d30 and d35 aw4 auto tranny, np231 t-case, 33's and i think 3.5 of lift not sure bought it from someone who bought it lol
jeepster89 is offline   Reply With Quote
Old 03-05-2006, 06:11 PM   #10
winks00XJ
I am using the 3.5 springs plus the 1.5 shackles in the rear. I have not had the time to install the ubolt eliminators which will give me another 1.5 inches of lift as they require cutting and welding and I cant weld. I hope to get that done soon. I think that I will need to trim some more where the stock LCA brackets were. It looks like you need to trim right up to the pinch seem.
The rims and tires are for sale as well as the old RE superflex 3.5 kit along with Rancho 9000 shocks and adjustable trackbar, basically a full 3.5 inch lift kit tried and true.
Old 03-05-2006, 06:13 PM   #11
winks00XJ
The trackbar is from TNT and uses a Johnny joint on the frame side and rubber bushings on the axle side.
Old 03-05-2006, 06:16 PM   #12
javik
if you could send me a pic of where you think the Ca is going to hit it would be greatly appreciated! jxhemm@sbcglobal.net Also, how much for the tires and rims? how many miles on them, condition, ect? Oh yeah, you said you have the 3.5 re kit for sale? Im assuming that u used your rear springs, what did you use up front? So if you used the 3.5 up front you basically have the old LCA and shocks, what kind? Anything else? sry to be a pain.
j.
Old 03-05-2006, 07:31 PM   #13
Marsquatch
winks that looks sweet. I am uber happy with my TNT LA's. It does look like you'll need to trim more of the old LCA area. Can you get a better shot of that area for us?
Marsquatch
http://jeeps.barsmar.com
Marsquatch is offline   Reply With Quote
Old 03-05-2006, 08:47 PM   #14
XJdamyankee
Where can you buy the TNT long arm at??? I've looked around a little and cant find them.
96 cherkoee SE I-6 AW-4 np231 dana30/chrys 8.25
Doug Thorley Tri-Y header/magnaflow cat/rustys FM50 exhaust
Kumho KL71's 31x10.5x15 mounted on rock crusher 15x8 w/4.5"BS black D-window
OME 2" lift & shocks, RE super-ride control arms
XJdamyankee is offline   Reply With Quote
Old 03-05-2006, 08:49 PM   #15
jeepster89
go here they have awesome stuff
http://www.tntcustoms.com/webV3/xjylink.asp
Glock Forum
