TnT Customs HD TrackBar - JeepForum.com
post #1 of 10 Old 12-11-2007, 02:22 PM Thread Starter
Grand Fan 4eva
I'm going to be ordering the tnt customs hd trackbar system but i have a couple questions. i was curious as to how much adjustability there was. i'm running about 4.5-5" up front but i have re-drilled my track-bar mount so i can use the stock trackbar. when i called them up today, i was told that they only have options for 4-6" and 6"+. do you think i'll be able to adjust the bar down enough to run the 4-6" bar with the re-drilled mount and 5" lift??
Thanks!
'97 XJ ~5" / 33 trxus / RK 3-link / FOA 12" CO's
'91 MJ
'68 M715
'98 5.9 Limited
Grand Fan 4eva is offline
post #2 of 10 Old 12-11-2007, 02:28 PM
ktmracer419
ktmracer419's Avatar
1997 XJ Cherokee
why not use the old hole?
and re hd trackbar+ 1/2" bolts > tnt customs
97 xj
44 front, detroit, alloyed
60 rear, detroit, 35 spline alloyed
35" beadlocked km2's
3" midarmed
more bells and whistles than you can shake a stick at
ktmracer419 is offline
post #3 of 10 Old 12-11-2007, 02:41 PM
MGrobe
Man In Black
MGrobe's Avatar
KTMRacer has a very valid point. He has the TNT bar and bracket and has bent the bracket to some degree and has broke multiple bolts. Unfortunately the jury is still out as to why this has occurred, but one fact that can't be ignored is the bolt size difference used between the two. RE uses larger bolts and I can't remember someone that has sheared a RE XD track-bar bolt. It probably has happened somewhere, but it sure isn't a common problem. And its not like a lot of people aren't running that setup either.
Another good reason for RE is that you can buy a crossbrace to take some of the load of the bracket and frame.
If the price difference is negligible and your needs require a heavy duty track-bar I would consider the RE 1660. And I am not a must buy RE zombie.
-Marc-
Sweet Pea 1998 - XJ
For Sale: (4) AR 767-5766 Wheels (used) 15x7, 5x4.5, 4.5BS - for local pickup in the Chicago-area
MGrobe is offline
post #4 of 10 Old 12-11-2007, 05:48 PM
Twsty
1988 MJ Comanche
Be absolutely sure that you get the right length. I went through this this past August. I ordered a T&T bar for a 6.5" lift and when I got the tracbar, it was too long. I was a bit peeved. I called them, and they said that they sent me the correct one and that the problem was with my springs. Apparently when they designed the tracbar they take into account the 1"-2" extra that you get from NEW springs, and since my springs were actually broken in and sat at 6.5" the bar was too short.
Long story short, I had a local welder cut out the threaded insert and lop 1" off of the tracbar. It fits, but barely. You can see how much thread engagement that I have on the tracbar now (which is good I guess...more thread contact=more strength).
1988 MJ 4.0/D60/14b/5.38/42s/PSC hydro
1995 XJ 4.0/AW4/231/JCR sliders/235s on KJ 16" wheels
1996 F350 PSD/ZF5, 375hp/692ftlbs
Twsty is offline
post #5 of 10 Old 12-11-2007, 07:20 PM Thread Starter
Grand Fan 4eva
when i redrilled the hole, it wasn't a full hole over so i welded a plate over the front of the axle bracket and drilled though that. it would be easy enough to grind it off and weld another plate back on drilled out for the stock hole but i was just wondering if you thought i'd have to or not. i just don't want to turn my bracket into swiss cheese where can i pick up the RE bar for the best price? I haven't really had a chance to look into it yet and i've been pretty busy prepping for finals
Thanks!
'91 MJ
'68 M715
'98 5.9 Limited
post #6 of 10 Old 12-11-2007, 08:16 PM Thread Starter
Grand Fan 4eva
so are you saying this is what i want?
http://www.jeepinoutfitters.com/scri...?idproduct=116
i saw an upgrade somewhere for the bigger bolts/ joint. do i have to purchase that too or am i going to be all set with just that set-up from jeepinoutiftters? $256 with free shipping sounds quite reasonable and there is a 5% discount code right? the tnt was going for $240+ $30 shipping... guess that puts the RE on top for price too... i kind of assumed the RE would be more exspensive i guess.
'91 MJ
'68 M715
'98 5.9 Limited
post #7 of 10 Old 12-11-2007, 08:28 PM
ktmracer419
1997 XJ Cherokee
you need to call re and ask for the 1/2" sleeve and superflex ball. the ball is $12 and the sleeve is $2 iirc. then you just need to drill
97 xj
3" midarmed
post #8 of 10 Old 12-11-2007, 08:38 PM Thread Starter
Grand Fan 4eva
how badly do you think i need the 1/2" upgrade for 33's? since i've already drilled my mount once, the structural integrity is already compromised and it's tough to weld a plate to the back side of the mount. i guess what i'm getting at is that if i drill for the 1/2" bolt, is my bracket going to become the weak point?
thanks!
'91 MJ
'68 M715
'98 5.9 Limited
post #9 of 10 Old 12-11-2007, 08:58 PM
Jeepernick
Jeepernick's Avatar
2008 XJ Cherokee
or dont run the sleeve and just slide a 3/4" bolt in there
That is what I did, but I have a custom axle bracket to and the 3/4 is most likely OverKill LOL just a little
I also have the 1/2" superflex ball and grade 8 bolt, cant image snapping it
Jeepernick is offline
post #10 of 10 Old 12-12-2007, 12:43 AM
MGrobe
Man In Black
MGrobe's Avatar
More food for thought...
http://www.jeepforum.com/forum/f11/lets-hear-double-shear-trackbar-mounts-482122/
-Marc-
Sweet Pea 1998 - XJ
MGrobe is offline
Beware of TnT Customs godplayer XJ Cherokee Technical Forum 25 06-13-2009 11:03 PM
Top Gun Customs cherokeered XJ Cherokee Technical Forum 3 06-25-2007 12:05 AM
TNT Customs trackbar IronWagon XJ Cherokee Technical Forum 7 02-14-2006 08:58 PM
loose trackbar mount, will RE H.D. trackbar help 97cherokee XJ Cherokee Technical Forum 2 05-24-2005 12:47 PM
JKS Adj Trackbar -vs- RE1600 trackbar wyrdvans XJ Cherokee Technical Forum 6 03-26-2004 11:17 PM
