Quantcast TJ/YJ fell through... thinking about XJ - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > TJ/YJ fell through... thinking about XJ
Poison Spyder February Special: FREE Rubber Liners when yoSlappin' on 61,510 Rigid Industries Lumens for Big RedRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 04-16-2001, 08:26 PM   #1
horatio102
OK so I was going to get a Wrangler as a weekend wheeler/something to haul junk around in, but it fell through. They're just too expensive for me (a student) as a second car.
I'm not looking at 2-door Cherokees. I've always liked the 2-door looks, and the interior room would be nice. I've found a white 1990 with 4.0l and 5-speed and A/C. It's got 112k mi on it and they're asking $3995. It looks pretty much bone stock.
I also found a '92 red w/160k mi for $5000.
Is there anything to look out for on 90-92 Cherokees? I'm planning on up to 4" lift with slightly larger tires.
The only thing I know about older Cherokees is that pesky 2.8l motor that blows up after 100k, but these are both 4.0l.
Thanks for any info.
This will be a replacement for the WJ, I know it won't be as plush. I'm looking for something that I can bounce off trees/rocks and not consider jumping off a cliff.
horatio102 is offline   Reply With Quote
Old 04-17-2001, 10:18 AM   #2
CHVYPWR
It pays to shop around. The 92 w/160k for $5000 seems a bit high. Before you buy an XJ, be sure to look for the obvious, all u-joints, be sure the front axle engages, check the front wheel bearings for play(esp. on high milage ones). You can bring the price down if you can find some items that need replacing. On the 4.0, check the air cleaner for signs of blow-by.
BTW, my 2.8 has 164,000 miles on it, and it still going strong!
Good luck on your XJ search, happy wheelin'!
-1985 XJ. Trail beater in the making.
-'04 GMC Canyon SL 4x4
CHVYPWR is offline   Reply With Quote
Glock Forum
