TJ spare tire mount on XJ ? - JeepForum.com
post #1 of 5 Old 05-15-2013, 07:25 PM Thread Starter
xj94
1994 XJ Cherokee
Has anyone tried to mount a TJ spare tire mount on an XJ. I was thinking about bolting it directly over the license plate area and adding a couple of heavy duty hatch struts.I figure i'll start a little project after i tackle my dead head and tail light issue.Any tips will be appreciated
xj94 is offline
post #2 of 5 Old 05-15-2013, 10:56 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
With hatch struts seeming to often struggle to lift just the weight of the hatch particularly in cold weather, it would take some uber-struts to lift a hatch with tire attached.
Not to be a killjoy, but I don't think there's enough structure in a hatch to hold the weight of a tire without fear of it unexpectedly departing of its own accord after road bumps and gravity have their way with it for a while. I've seen TJ tailgates and hinges become distorted from the weight of only slightly oversized tires hanging from them coupled with some good wheeling trips.
***Chris***
chris87xj is offline
post #3 of 5 Old 05-15-2013, 10:57 PM
cory4um
Its been talked about. I don't recall seeing one.
The tailgate is thin and weak. The weight of the tire will just pull the mount right out of the metal... Or in your , worse case yet, fiberglass tailgate (iirc)
You would need extensive reinforcement, adding even more weight.
It would be much easier to build a "swing out", or just find a stock swing out carrier...
cory4um is offline
post #4 of 5 Old 05-15-2013, 11:57 PM Thread Starter
xj94
1994 XJ Cherokee
yeah, thought about beefing up the tailgate with some steel backing plates but that just will be added weight along with the 32" wheel.Like cory4um suggested i may try to hunt down a stock swing away.Thanks guys,there's nothing like a voice of reason.
xj94 is offline
post #5 of 5 Old 05-16-2013, 05:28 PM
Motorcharge
97+ steel hatch you could do it with upgraded struts as long as you backplate.
For the older fiberglass I wouldn't try. It will put too much stress on the hatch trying to close it. They're already prone to cracking over time from the pressure placed there anyway.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
