tires and wheels - JeepForum.com
post #1 of 4 Old 11-10-2010, 07:19 AM Thread Starter
Beta144
1995 XJ Cherokee
tires and wheels
Using a sizing chart i found online, my cherokee with a 1.5" spacer shackle lift should fit 30" tires without rubbing. 4wheelparts.com has bfg allterrains on sale and i'm going to order this model:
30x9.50R15, BFGoodrichAll-Terrain T/A KO-RH2
What i can't figure out is what width wheels i need to order. 7" or 8"
Rock Crawler Series 98 Gloss Black Monster Mod Wheel-RH2
any insight?
Beta144 is offline
post #2 of 4 Old 11-10-2010, 09:30 AM
mosh-n-roll
2009 JK Wrangler
I'm guessing you would want to go 7", but I'm not totally sure. Make sure you get the proper backspacing or there is a chance the tires could still rub when the Jeep is flexed.
mosh-n-roll is offline
post #3 of 4 Old 11-10-2010, 10:00 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
You can run that size on a stock jeep with very minimal rubbing. If you are replacing the wheels get a 15x7" wheel unless you plan to go to a 12.50 wide tire at a later date. You also want 4.5" or less back spacing to keep from rubbing the lower control arms at full lock. With the 15x7" wheels with 4.5" backspacing you should still be able to stuff the tires without hitting the flares.
xjfever is offline
post #4 of 4 Old 11-10-2010, 11:40 AM Thread Starter
Beta144
1995 XJ Cherokee
Thanks for the info!
Beta144 is offline
cherokee , tires , wheels , xj
XJ wheels and tires bspillane30 XJ/MJ Cherokee Non-Technical Forum 4 02-28-2009 06:23 AM
Tires and Wheels TimA XJ Cherokee Technical Forum 3 07-24-2008 12:35 PM
New wheels/tires on the DD: BIGNUTT XJ Cherokee Technical Forum 22 05-23-2007 12:10 PM
Wheels/Tires djshortsleeve XJ Cherokee Technical Forum 7 09-18-2005 06:10 AM
Tires/Wheels GwinnettXJ XJ Cherokee Technical Forum 4 09-11-2002 10:32 AM
