Tire PSI on road/off road - JeepForum.com
post #1 of 3 Old 09-06-2006, 09:59 PM Thread Starter
89Cherokee4x4
What is the best tire PSI to run on road/off road with 31x10.5 kumho mud terrains?
1989 Jeep Cherokee 4x4
3 inch Rough Country AAL lift
Cragar soft 8 wheels
31x10.5 Kumho Mud Terrain tires
89Cherokee4x4 is offline
post #2 of 3 Old 09-06-2006, 11:19 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
27-32 psi on road depending on how the tires wear. 14-18 psi on the trial, lower if somebody has onboard air (in case one comes off the bead of the rim).
CJ7-Tim is offline
post #3 of 3 Old 09-06-2006, 11:24 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Take some chalk and draw a line straight across the tread. Then drive in a straight line for a couple of yards and inspect the marks.
If the lines are still thick and unrubbed on the outside the tires need to be deflated some.
If they are not rubbed as much on the middle and rubbed good one the sides, the tires need inflated some.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
On road/Off road tire pressure XJoutlaw XJ Cherokee Technical Forum 25 10-08-2009 01:18 PM
blew a tire on the road accidntal drifting RavenCorax XJ/MJ Cherokee Non-Technical Forum 1 03-26-2009 02:35 PM
Road/Tire noise Differential or elsewhere? mfinkler XJ Cherokee Technical Forum 1 05-13-2008 06:37 PM
What tire pressure are you running? On road and off MattS XJ Cherokee Technical Forum 25 04-11-2005 08:51 PM
tire pressure before off road 94xj1 XJ Cherokee Technical Forum 2 12-16-2002 03:09 PM
