Tire help? - JeepForum.com
post #1 of 5 Old 07-14-2010, 04:00 PM Thread Starter
CHEROKEE55
1991 XJ Cherokee
Tire help?
i currently have BFG MUD ALL TERRAINS 32x11.50 R15
they somehow all have leaks so im looking to get new tires
what tires are equivalent or a little bigger that will fit?
by the way its a 1991 cherokee with a 6" lift
CHEROKEE55 is offline
post #2 of 5 Old 07-14-2010, 07:33 PM
BrunoS
whoa nelly big dagum' tires.
BFG is very good brand.
1) check the valve stems for leaks and tightness of the shraeder valve inside as well. many are loose and leak when they seat the beads on the rim on installation.
2) your aluminum rims may be porous, but doubt it.
3) all tires lose around 1-2 psi per month, normal. i check mine about every 2 months or so or when mpg takes a dump, and before any highway trip with the family.
4) as for tires, anything from 31" and bigger will fit, but 6" lift makes any tire look small.
Newly Painted! Emerald Green '96 XJ 4x4 4.0 HO 5-spd
3" Lift + 31" Tires / D35 TracLok / NP231
Drilled out Stock Airbox / Gauge Cluster Upgrade
Magnaflow Muffler / High-flo Cat / MSD Coil
BrunoS is offline
post #3 of 5 Old 07-14-2010, 09:29 PM
Wup This
33's will fit. Do you have all terrains or Mud terrains. The new mud terrains are very nice (I run them and I am very pleased with on and off road performance). You really need to decide what is more important, on or off road performance and then pick a 32 or 33 that fits your needs.
98 XJ, Pearl Green, 4.5" lift, 32's Daily Driven. BEAT IT! BREAK IT! FIX IT!
Wup This is offline
post #4 of 5 Old 07-14-2010, 09:58 PM Thread Starter
CHEROKEE55
1991 XJ Cherokee
thanks for the help guys
post #5 of 5 Old 07-14-2010, 11:27 PM
BriansCJ
1994 XJ Cherokee
If you cut your fenders, you could fit 35s, but I doubt your gears and axles would be up to it.
I would just get some 33s.
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
tires
rear tire carriers - how close is your tire to the window? EricsXJ XJ Cherokee Technical Forum 24 08-13-2008 08:16 PM
stock tire carries what size tire? TwistedcaB- XJ Cherokee Technical Forum 1 04-30-2008 10:09 AM
what tire company offers a true 31" inch tire? kaketj XJ Cherokee Technical Forum 12 05-25-2007 04:15 PM
Will a 30x9.50 tire fit in the stock spare tire location? 79bigmack XJ Cherokee Technical Forum 4 02-03-2007 01:16 PM
What size tire can be run on a stock tire carrier hmmhoyhoy XJ Cherokee Technical Forum 8 06-24-2006 09:31 PM
