tips need on cutting out rear wheel wells - JeepForum.com
post #1 of 7 Old 02-08-2010, 12:09 AM Thread Starter
srhcherokee24
i have cut out the little lip that is on the rear wheel well but i want to go bigger. i want them to match the front and i need some tip to reconnet the wheel well and the quater panel back to gether.
srhcherokee24 is offline
post #2 of 7 Old 02-08-2010, 12:34 AM
steven-o
i would cut out the wheel wells where it starts to go flat, and get sheet metal and weld it in, connecting them together
steven-o is offline
post #3 of 7 Old 02-08-2010, 12:37 AM
Mighty Thor
You could also try some of the new adhesive bonding methods. They are strong enough to hold body panels on new cars and I haven't seen anyone try them here yet.
Mighty Thor is offline
post #4 of 7 Old 02-08-2010, 04:42 AM
mecompco
www.midcoastjeep.com
mecompco's Avatar
1994 XJ Cherokee
I'm pretty sure the adhesives are NOT used for structural components of a unibody. If one cuts through the welds of the pinch seam I think welding would be be a safer way to go.
'94 Cherokee Country
Engine: 4.0 HO, Sealed canister filter, 3 core CSF steel radiator, CatCo cat, Dynomax Turbo Flow muffler.
Electronics: Remote start/locks, Pioneer DEH-P7800MP w/XM, Polk Audio speakers, Garmin Nuvi 660 GPS, Cobra 148 GTL P&T w/Wilson 1000.
Suspension: Old Man Emu 3" lift+OME AAL, JKS adjustable trackbar, QDs, LCAs UCAs, A.C.O.S., DPG Offroad adjustable bumpstop plate, Daystar poly bumpstops.
Steering: Currie HD steering, C-ROK steering box reinforcement, OME stabilizer.
Armor/Recovery: T&T Custom belly skid, Mopar gas tank skid, JKS LCA mini skids, Rock Lizard Super Skink Sliders, Mopar 2" receiver, ARB Bull Bar/Ramsey REP 8.5 winch.
Drive train: D30 front axle w/Superior Chromo D30 axles & outter seals, D/S 4.56 R&P, ARB locker, Ruff Stuff cover. Ford 8.8 rear axle w/Superior Super 88 kit, Ford Motor Sports 4.56 R&P, ARB locker, SOLID cover, Russell stainless lines. Front and rear Tom Woods HD drive shafts, 242 x-fer case w/Tom Woods SYE.
Tires/Wheels: 33x10.5x15 BFG Mud Terrains on Alcoas.
Misc: Garvin Wilderness rack, Safari Snorkel, Redline Tuning hood lifts.
Awaiting installation: Autometer A pillar gauge pod, oil, water, & tranny temp guages, PIAA driving lights, Goferit tie-rod flip bushing, '95 Brake booster and M/C, M.O.R.E. Motor mounts, TnT Custom 1.5" Shackle.
Stroker Project: HO Block, '99 intake manifold, bored TB, 1" TB spacer, Dynomax Blackjack Header, Permacool electric fan.
mecompco is offline
post #5 of 7 Old 02-08-2010, 08:46 AM
fla_cracker
1995 XJ Cherokee
If you do go bigger than the original welds you are going to be doing a fair bit of welding to get new metal in place. I recently attempted opening up the rear of my 4-door and found it to be more work than I had originally planned for. The inner wheel well on the outer side is kind of conical shaped and requires alot of relief cuts to be able to bend and reach the outer quarter panel again.
If I were to do it again, I would cut the inner fenders where they come together and fab a new outside inner wheel well out of new sheet to weld in. The new metal would go from the inner well to the quarter panel.
just my opinion....hope it helps
"Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. "
Albert Einstein
Originally Posted by N2Fix View Post
"somewhere between really crappy and kind-of-crappy gas mileage."
fla_cracker is offline
post #6 of 7 Old 02-08-2010, 10:57 AM
Mighty Thor
Not sure I would agree. The outer skin on the Cherokee's rear end is no more structural than any other vehicle and they use the new adhesives to bond almost all of the skins on several new vehicles including the Camaros and Mustangs. I have seen some of this stuff in wrecked vehicles and the metal has torn before the bond broke. Also, in the stated application It would not likely be subjected to high stress. That is why there are only spot welds there in the first place. If it was a high stress structural area it would be seam welded.
post #7 of 7 Old 02-08-2010, 11:31 AM
Ckwapich
1989 MJ Comanche
my dad has a body shop and we tested those kinds of adhesives by "glueing 1/4" plates together and the chain broke around 3500 pounds and the adhesive was still intact
i would use the adhesive before i would weld it, no warping is a major plus
Ckwapich is offline
Rust above the rear wheel wells.... Gnl.Weirdness XJ Cherokee Technical Forum 15 03-22-2010 03:48 PM
Removing the plastic panels over the rear wheel wells.... Gnl.Weirdness XJ Cherokee Technical Forum 4 12-09-2009 10:09 AM
tips on cutting the rear fenders xjkid91 XJ Cherokee Technical Forum 4 02-24-2009 09:26 PM
Wheel wells mj xj the same??? traitor5150 MJ Comanche Technical Forum 3 09-13-2005 01:06 AM
Wheel wells jon campbell XJ Cherokee Technical Forum 12 01-24-2004 02:32 PM
