timing is off on my Country 4.0 - JeepForum.com
post #1 of 27 Old 07-16-2011, 03:46 PM Thread Starter
highmountaingee
I have had major problems with my Cherokee 4.0 6 cyl. country for the last month. I have had my car in one of the best shops in Houston and they can't seem to find the problem.
It is running rich and is heating up the manifold red hot. All the common checks have been made they can't resolve it: checked the computer, crank shaft sensor, vacuum hoses, distributor cap/wires/plugs, o2 sensor, map sensor, you name it they checked it. The timing is off and does not idle properly or just run properly. They say it seemed to have "jumped timing", or "idle jumped"They even pulled the trans to see if the fly wheel was messed up and was not sending the proper signal to the Crank sensor, but it seemed fine.
Now as a last resort they want to "trim" the distributor cap to make it adjustable. I'm not sure exactly what they are going to do, but supposedly they can move cap like a GM and adjust the timing that way.
Does anyone out there know what could have happened to my Jeep?
highmountaingee is offline
post #2 of 27 Old 07-16-2011, 06:41 PM
Luke94XJ
1994 XJ Cherokee
You don't have to do any mods to the cap to "adjust" the distributor. You just leave the hold down bolt out and rotate it while running. Just don't take your hand off of it. I doubt that is the problem though. You may have skipped a tooth on your timing chain. Or have a stuck valve.
The red hot manifold is strange though. You may have bad injectors.
Luke94XJ is offline
post #3 of 27 Old 07-16-2011, 07:32 PM
SFRautomotive
#WannaBeRockBouncer
SFRautomotive's Avatar
1992 XJ Cherokee
do not do this, this will NOT adjust your timing.
the ignition timing on the 4.0 is non-adjustable
turning the distributor only affects fuel synchronization, and is best left alone
00XJ limited.....Tons, ORI's, Caged
92xj....Linked, Locked, Caged, Armored...RIP
what are leaf springs?
"You're what's wrong with America. You don't drink enough PBR and you probably run sway bars on the street. Fawking communist."-ibjeepin95
2013 COTY
SFRautomotive is offline
post #4 of 27 Old 07-16-2011, 07:36 PM
SFRautomotive
#WannaBeRockBouncer
1992 XJ Cherokee
are they sure it's a timing problem? have they done compression test? how about making sure the timing chain doesnt have to much slack? (doubtful though) checked out the camshaft position sensor?
2013 COTY
post #5 of 27 Old 07-16-2011, 10:41 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Google Jeep Scan Tool Toothpick Test and perform the simple steps to check and/or adjust the base timing.
I would also suggest finding a garage that doesn't hire Morons to be mechanics.
CJ7-Tim is offline
post #6 of 27 Old 07-17-2011, 12:12 AM
SFRautomotive
#WannaBeRockBouncer
1992 XJ Cherokee
thats only good if he has the DIS ignition....and since he doesnt say what year his xj is, he very well could have a 99 and earlier XJ
X2 on the second part though
2013 COTY
post #7 of 27 Old 07-17-2011, 04:43 AM Thread Starter
highmountaingee
Thanks for the info. The jeep is a 94, sorry. I did have the head redone also and they said that would not affect the timing. They didn't check compression because they felt that would not affect the car that way. We checked the crank sensor numerous times and even replaced with a jeep original part recently. Thanks for the input. Any more suggestions?
post #8 of 27 Old 07-17-2011, 07:29 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
I agree that it's time to take your vehicle to a different shop. Get a fresh set of eyes on it. It is often the ticket to finding root cause.
How have you determined that it is running rich? Exhaust gas analysis will tell that story in a hurry.
As mentioned, base timing is controlled by the computer. Unless the distributor was removed (was it?) or it jumped a tooth (unlikely), this could be something else other than timing.
Seriously, find another shop (with ASE technicians) and let them take a look. The fact that they want to "trim the distributor cap" is a sign that they are in over their head on your problem. That is not likely to be the fix here.
ROOT CAUSE needs to be established methodically, using a testing based strategy.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is online now
post #9 of 27 Old 07-17-2011, 08:45 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Have they performed a simple vacuum gauge test to see if your exhaust is restricted, like a clogged catalytic converter?
cruiser54 is offline
post #10 of 27 Old 07-17-2011, 11:36 AM
CJ7-Tim
CJ7-Tim's Avatar
The Toothpick Test should work on any 1996-2001 OBD-II Cherokee to check or adjust the base timing when the motor is at TDC.
I don't have a 96-98 on hand to physically check for the alignment holes, maybe somebody can look for them and confirm they exist ?
CJ7-Tim is offline
post #11 of 27 Old 07-18-2011, 09:33 AM
Luke94XJ
1994 XJ Cherokee
SFRautomotive, I was just saying that if they were going to modify it to "adjust" his timing, that they could simply test it by rotating it. Obviously its not permanent.
Luke94XJ is offline
post #12 of 27 Old 07-18-2011, 08:16 PM Thread Starter
highmountaingee
They ruled out a clogged exhaust pipe, Cruiser54. The issue seemed to have started when I had the transmission rebuilt. The shop took it off, rebuilt it and put it back on. Right after that is when it started to get jerky and completely off. Of course, they said that they did nothing to the car. I had everything checked that had to do with the trans. The crank sensor, computer, flywheel, etc. It's a mystery. I'm not kidding when I say this is the best shop in Houston when it comes to car repair. The owner can tell you practically everything about a any car, any year, etc. They have almost every computer, tester, and machine to repair a car. I was pretty confident they could solve the problem, so that's why I'm totally surprised and confused with what is going on with my Jeep. She's had a good run. I have 384k miles on it and it had been running pretty well, until recently. Hope these guys can find the problem.
post #13 of 27 Old 07-18-2011, 08:57 PM
SFRautomotive
#WannaBeRockBouncer
1992 XJ Cherokee
turning the distributor will not adjust ignition timing on a 4.0
2013 COTY
post #14 of 27 Old 07-19-2011, 10:08 AM
Luke94XJ
1994 XJ Cherokee
Well It will retard and advance spark, That's ignition timing. But Its not meant to be done. Its not permanent, and only checks to see if someone put it in a tooth off.
It doesn't sound like its his problem either, I was just making the point that if they are the best shop in all of Houston they should know that you don't need to modify it to test it.
Luke94XJ is offline
post #15 of 27 Old 07-19-2011, 12:57 PM
alexrule123
alexrule123's Avatar
No it won't. The 4.0 does not adjust timing that way. Timing is determined by the crank position sensor. That is what tells it when to fire, adjusting the distributor will make it run like crap and throw off the fuel deliver timing, that is what the cam position sensor is for.
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
idle jump , rich
Rough Country RS9500 Winch Giveaway NOT FREE! cost $20 to Enter xsubarudude JeepForum Announcements 3 03-15-2011 05:03 PM
UserCP new/old - read/unread timing?? JeeperDon JeepForum Announcements 3 06-23-2010 08:47 AM
Rough Country mrblaine JeepForum Announcements 10 02-24-2009 08:38 AM
Timing out? jlmclean JeepForum Announcements 1 03-07-2007 08:47 AM
Classifieds By Country rxl JeepForum Announcements 1 12-02-2006 09:19 AM
