Quantcast Time to beef things up! - - a build thread of sorts - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Time to beef things up! - - a build thread of sorts
Old 04-03-2008, 11:52 PM   #46
jeeposaurus
1990 XJ Cherokee
Master fabricator at work, very nice work. I have done tig and mig (very small amounts) and those are some fine looking welds you have there...I understand the therapeutic part.
The only prob I see with your exhaust turn down is the carbon monoxide and cabin. I think they put the tips out past the ends of the vehical to prevent exhaust from making its way into the cab...mine is just tucked in close enuff to my rear hitch to avoid getting smacked, and still fires exhaust clear of the vehical...I dont know if there is any fact to my exhaust in the cab myth...I guess you'll figure it out once you fire it up.
Very nice.
1990 Black 2 Door, Homemade 3" lift, 31x10.5 BFG AT's on rock crawlers, recovery front and rear, bed lined interior, rockerless, armored rear quarters, magnaflow muffler, CB, DIY Immobilizer, AC to OBA, Silverstars and a nice rack.
Build Up:
http://www.jeepforum.com/forum/f11/black-2-door-build-up-820250/
325,000km young.
jeeposaurus is online now   Reply With Quote
Old 04-04-2008, 12:09 AM   #47
EricsXJ
The Post man
EricsXJ's Avatar
Thats a valid point but I actually had the tip of my old exhaust cut off well before the rear bumper. It was routed to the stock location on the side of the gas tank but because I cut it off, it just shot straight back and didn't even have a turndown. So I think I'm okay in that regard. Unless the fumes have been making me stupider by the day and I don't know it...
Eric
2000 XJ "PROJECT RUBICON" lifted, locked, shafted, running 35's, 4.56 gears, pair of ARB's, and stock AM/FM cassette
My website - EricsXJ.com
EricsXJ is offline   Reply With Quote
Old 04-04-2008, 12:55 AM   #48
badassr1
1995 XJ Cherokee
No adjustable spring plates?
badassr1 is offline   Reply With Quote
Old 04-04-2008, 01:04 AM   #49
EricsXJ
The Post man
EricsXJ's Avatar
I'm sorry I don't know what you are talking about.
Eric
Old 04-04-2008, 02:37 AM   #50
jersey_jim
maybe he is asking about adjustable rear bump stops.
did you dump it right near the gas tank because you have a extended rear shackle that would hit the tail pipe? i had to cut mine down when installing my boomerang shackles, and now its almost time to redo my entire exhaust from header to tailpipe, and i like the idea you have.
( northjerseyjeepclub.org )
99 cherokee sport auto/231 - RK 3 link long arms, RE 5.5" coils, RC 4.5 leafs w/ RE 1.5" boomerang shackles, RE track bar & bracket, JKS disco's, rustys/RC shocks, P.O.R.C SYE w/ front drive shaft, rugged ridge steering, OR-fab front winch bumper w/ superwinch LP8500, surco roofrack, airflow snorkel, bushwackers & 33" maxxis bighorns .
95 cherokee sport auto np231 - 4.5 RE coils, OME 3 inch full packs, stock track bar ,RE upper and lower control arms, JKS quicker disco's,RC shocks and steering stab.stock tires/rims,t-case from the 99xj, slowly being robbed of all its part before it goes to the JY
jersey_jim is offline   Reply With Quote
Old 04-04-2008, 10:29 AM   #51
badassr1
1995 XJ Cherokee
No I am talking about front adjustable spring mounts. It allows you to adjust for spring sag or more hieght.
Old 04-04-2008, 11:15 AM   #52
EricsXJ
The Post man
EricsXJ's Avatar
No. I was happy with the ride height and I didn't have a case where one side was sagging more than another.
Eric
Old 04-04-2008, 11:23 AM   #53
RWKXJ
Exhaust looks great Eric! I wish I had taken my new setup off before I welded it all up...but it turned out good. You need to watch the exhaust by the gas tank though, I had mine cut and turned to go out between the corner of the gas tank and toward the passenger leaf and I had exhaust heating up my gas tank on long trips causing it to expand and vent through the gas cap and back up thru the evap canister, giving a strong gas smell in the cabin. Once I put the new exhaust on and turned it down before the axle it took care of those problems....just something to think about. I used a 90* mandrel elbow from summit to do the turndown. Also I used a summit welded muffler that has quite a drone on the highway, It'll be interesting to see how loud yours is!
95 Sport, ~6" Lift-Rubicon Express & ACOS; RE Longarms w/ custom x-member.... 35x12.5 BFG KM2's, F&R Dana 44's; front-High pinion, narrowed to waggy width and an ARB, 4.88's, custom bumpers/sliders...
RWKXJ is offline   Reply With Quote
Old 04-04-2008, 11:24 AM   #54
HeavyMetal
Forum God
HeavyMetal's Avatar
1997 XJ Cherokee
man that exhaust clearancing is annoying huh? my TNT arm on the passenger side is in full contact with the exhaust pipe at all times, just rubs up against it as it moves
Though I wheel through the valley of the shadow of death,
I will fear no evil: For thou lockers are with me;
Thy lift and thy tires, they comfort me.
Thou preparest a spotter before me in the presence of mine obstacles;
HeavyMetal is offline   Reply With Quote
Old 04-04-2008, 11:41 AM   #55
Timo_90xj
Timo_90xj's Avatar
1990 XJ Cherokee
Very nice Eric I'm sure you'll gonna love the T&T kit! ..and yes, I ran to a couple similar problems than you did with the bellypan and exhaust. My exhaust pipe was bent as well, so I had to cut it off too
What I should've done with the new exhaust was side exit (tip behind pass. rear tire and as high as possible). Now I have to do some modifications, I'm just installing my gas tank skid and there's not enough room for the exhaust pipe
1998 Grand Cherokee 5.9 LX, 100k miles, 1.75" BB, 32 x 11.50 BFG MT KM2s, custom- fabbed bumpers etc..
http://www.jeepforum.com/forum/f13/daily-driver-5-9-build-thread-bumpers-tube-rockers-etc-1222317/
***Under construction***
1990 XJ (4-door), 4.0 I6, AW4, NP242, PBR 42" tires, Unimog portal axles, 110" WB, full cage + uniframe completely rebuilt, front 3-link + panhard / double triangulated 4-link rear, etc...
http://www.jeepforum.com/forum/f11/hybrid-cage-build-exo-cage-internal-973910/
Timo_90xj is offline   Reply With Quote
Old 04-05-2008, 12:28 AM   #56
EricsXJ
The Post man
EricsXJ's Avatar
Okay I got the suspension on and did some testing. The exhaust is not abnoxiously loud but it can be heard at all speeds when you are on the gas. I think I like it. I've also been checking the gas tank skid and it isn't getting hot at all so I think its good. Worse case I could cut it off and do the turn down before the axle as RWK suggested.
And because someone asked, I got a sound clip for you. I rev'd it to 3000rpm. Keep in mind this is in the driveway, the exhaust was already warm, and it was a bit windy today. I think it sounds a whole lot better in person.
http://www.ericsxj.com/unibody/exhaustclip.avi
Eric
Old 04-05-2008, 12:32 AM   #57
XJLI
1993 XJ Cherokee
sounds throaty, I like it.
And yeah, listen to that auto volume level clip with the wind
Factory Four Link
XJLI is offline   Reply With Quote
Old 04-05-2008, 12:51 AM   #58
EricsXJ
The Post man
EricsXJ's Avatar
The big benefit of the T&T Customs Y-Link is clearance. The mounts are tucked up inboard of the frame rails and the bend in the lower arms gives awesome clearance. Heres the pic I posted on page one of my old setup with the drop brackets:
The clearance I had with the drop brackets was 15.5" from the ground. With the Y-Link I have 19" measured at the same place. So for the mathematically challenged, I gained 3.5" of clearance!
As far as the ride is concerned, it is slightly better than my old arms with the drop brackets. It does seem to absorb road imperfections (both on-road and off) better.
I also tested the flex to check for clearance and to make sure everything was working properly. I also took measurements for limiting straps. I'm using the same shocks as before so with those as my limiting factor, the amount of droop I have is the same.
I did adjust the arms to move the axle a little more forward than I had it before. It looks like it put the wheel right in the center of the wheelwell. I'm happy with that. Pointed straight I have no rubbing and my bumpstops are making contact. If I turn while flexing it will rub parts of the inner fenderwell but I am used to that.
Eric
Old 04-05-2008, 01:00 AM   #59
EricsXJ
The Post man
EricsXJ's Avatar
More pics, flexing the other side now.
Also I will say the stiffeners have made a HUGE difference. There is only a miniscule amount of body flex even when maxing out the suspension. I got out to take the pics and the doors open and shut just like it does on level ground.
So that is pretty much where I am with this project so far. There is much more to come but I probably won't be doing daily updates - more like weekly since I get most of the work done on the weekends. What you've seen so far has taken me several weeks, not just a few days.
Eric
Old 04-05-2008, 01:30 AM   #60
XJ2000
Eric, everything looks great!
Thanks for posting up this "update" of sorts, it really complements what you've written in your book.
Keep up the good work!
North Jersey Jeep Club
Trail Rig: 2000 XJ w/ 4.5" RE SF, Locked XJ D44 Rear, Locked D30, and a bunch of other things
Pavement Pounder: 2001 XJ Daily Driver, 2" BB, 245/70R16 AT's on Moabs
XJ2000 is offline   Reply With Quote
Glock Forum
