Time to beef things up! - - a build thread of sorts - Page 38 - JeepForum.com
post #556 of 628 Old 03-06-2013, 11:10 PM Thread Starter
EricsXJ
The Post man
EricsXJ's Avatar
Thanks for the comments.
I have so much still to do that sometimes I wonder if I'll get it done by summer, let alone by May.
Eric
2000 XJ "PROJECT RUBICON" 3-link front / 4-link rear / coilovers / running 37's on Dana 60s
My website -
EricsXJ is offline
post #557 of 628 Old 03-06-2013, 11:14 PM
Climbit
Hurry up... only only 4 months 'til the con and DV.
Climbit is offline
post #558 of 628 Old 03-07-2013, 06:34 AM
mdhadel
1995 XJ Cherokee
Yeah better hurry. May is coming fast.
mdhadel is offline
post #559 of 628 Old 03-12-2013, 06:11 AM
97cherosport
1997 XJ Cherokee
Looking forward to seeing what you've got planned next. Had to put my xj on hold to work on my mj front end conversion and resto since its my work truck it kinda takes precedents over the xj. Also just got your book in the mail. Very well written I must say and extremely informative.
Eat sleep and breathe jeep
97cherosport is offline
post #560 of 628 Old 05-10-2013, 11:57 AM
henry9419
Originally Posted by EricsXJ View Post
Capped the corners with some tail light boxes:
scared me when i first saw the chopping, but in the end this is the best comp cut ive seen, bad thing though is that now that ive seen it done and have taillights that look good i kinda wanna do it on mine...
henry9419 is offline
post #561 of 628 Old 05-10-2013, 08:13 PM Thread Starter
EricsXJ
The Post man
EricsXJ's Avatar
Originally Posted by henry9419 View Post
but in the end this is the best comp cut ive seen, ..
Thank you. I agree that most comp cut's I've seen either are simple hack jobs or don't quite match the flow of the body. We'll see how this turns out, I should have it driving in another month.
Eric
My website -
EricsXJ is offline
post #562 of 628 Old 05-18-2013, 08:57 PM Thread Starter
EricsXJ
The Post man
EricsXJ's Avatar
Been so busy working on this thing I haven't been posting any updates. Here's a brief one.
Finding disc brakes for the Dana 60-ISU was a major headache and didn't turn out how I planned. I'll post this here so that if anyone else finds themselves with the same axle they will know what they are faced with. My axle is a 1989 and had drum brakes. 1995 - 2004? supposedly have the disc brakes and retain the 8 x 6.5" bolt pattern. I mistakenly thought that the axle flange that the backing plates bolt to would be the same on my older axle as the new ones. They aren't.
Here's the newer ones (guy said these were from an '01 or '02 I think):
Problem is the bolt pattern on the flange is a trapezoid pattern and my 1989 is a square/rectangular pattern like the usual Dana 60's and Dana 70's. So obviously these will not bolt up. Billy (JeepFreak21) used these but he had to make a spacer and then weld them on. I could have done that but this guy wanted $200 for these backing plates, calipers, and caliper brackets, which were all in bad shape. I said screw that.
I went back to the RuffStuff brackets and ordered the Dana 70 brackets, which is what Billy originally used (http://www.bsfab.net/?p=85). I also used the bolt-on brackets but cut the lower half off in order to raise them, roughly 1/4", to fit over the E-350 rotors. I should mention that I tried using 12.5" rotors with a deep hat but all the ones I found will not fit over the E-350 hubs. So... you have to use the E-350 rotors which are 12.83" diameter.
I used the '75 Chevy 3/4-ton calipers which is what RuffStuff suggested and what I found is the brackets have the right spacing when welded to the in-board face of the flange. Here's how mine turned out:
So finally the rear axle is all but done. Got the Yukon cut-to-fit 4340 chromoly shafts cut and installed. Finally a simple job that went as planned!
Also I am jumping around a bit because unfortunately that is how the build is going at this point due to having to wait on parts, etc. Here's the shock hoops for the front:
Eric
My website -
EricsXJ is offline
post #563 of 628 Old 05-27-2013, 07:54 AM
Project1
The shock hoops are killer .. a lot of work bother... keep it up
Project1 is offline
post #564 of 628 Old 09-24-2013, 01:31 PM
crockett07
1992 XJ Cherokee
updates!
crockett07 is offline
post #565 of 628 Old 09-24-2013, 01:33 PM
Rockdrummer93
Agreed!! ^^^
2014 Cherokee Of The YEAR
Rockdrummer93 is offline
post #566 of 628 Old 09-24-2013, 05:11 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
Look on NAXJA.
1990JEEPXJ is offline
post #567 of 628 Old 09-24-2013, 08:20 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Originally Posted by 1990JEEPXJ View Post
Look on NAXJA.
^^^ Just did....................
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #568 of 628 Old 09-24-2013, 08:35 PM
Rockdrummer93
Same here! Had to change my underwear.. That thing is ****ing nasty now! I can only dream mine will be that awesome one day!
post #569 of 628 Old 09-25-2013, 02:30 AM
Timo_90xj
Timo_90xj's Avatar
Just checked as well.. looks sick!
***Under construction***
Timo_90xj is offline
post #570 of 628 Old 09-30-2013, 10:45 PM
CRJEeP_wj
Amazing build, and so much useable write ups that i plan on using. I may hang out in the xj section a little more now. I noticed you were using a 110v lincoln in the biggining is that what you used to weld the rockers and cage? Also what kind of tube bender was used?
02 grand cherokee, hp60 14b, 42s. Stazwork, triangulated 4-link, rear leafs, homemade bumpers and sliders. build thread
CRJEeP_wj is offline
My '01 Build Thread Ninety5poloz XJ Cherokee Technical Forum 17 10-02-2009 02:22 PM
The Lift is On (A Build Thread of Sorts) xjarchaeologist XJ Cherokee Technical Forum 14 04-26-2009 08:44 PM
Upgrade time..minor things. keaton XJ Cherokee Technical Forum 3 10-02-2008 08:29 PM
Stupid Things Jeep Did To Out XJs Thread 00xj54 XJ Cherokee Technical Forum 81 05-20-2007 11:31 PM
