#241 | |||
The Post man
Treddyo, sorry I missed your questions in your last post.
And you can install the Y-Link without stiffeners but later on if you want to add them you will regret not getting the stiffeners first.
Eric 2000 XJ "PROJECT RUBICON" lifted, locked, shafted, running 35's, 4.56 gears, pair of ARB's, and stock AM/FM cassette My website - EricsXJ.com
#242 |
Moparrrrrrrr
i cant believe such a nice rig would have lift blocks....WTF?
-2001 Dodge Dakota Quad Cab 4x4 - 4.7 V8, the new hotness! -1997 Jeep Grand Cherokee Limited - 4.0, 4" lift, 33s, bilstiens, IRO stuff, FOR SALE -1999 Jeep Cherokee Sport 2 door - 4.0, 8" lift, 35" KM2s, IRO stuff, Long Armed, Armored, Rolled, Parted |
#243 |
The Post man
Who made the bumper? AEV. They only sold 25 then stopped because they had issues with the powdercoat and never continued making them again. I modified the bumper corners and now the carrier, so its not exactly how they intended it to be. They also only intended it to hold a 33" tire maximum.
#244 |
Moparrrrrrrr
btw, my comment above was sort of a joke
#245 | |
The Post man
Lift blocks are bad because they can cause axle wrap. Key word there is "can". With stock flexy and worn out leafs, lifting via a block will most likely cause axle wrap. I have 4.5" leaf packs, much stiffer than stock, so it will be much less prone to axle wrap and I haven't noticed any so far. Lift blocks are good in that they add lift without changing how the suspension will ride. When you get up in the 6" lift range, you should be using more than one method to achieving that lift. 6" leaf packs alone would be foolish and way too stiff. Shackles are good but you can only get them so tall. Blocks? Not bad I say if you don't go crazy and get really tall ones or do something stupid like stack them... And besides, mine are just fat shims not lift blocks, remember? ![]() Someone inevitably would post the same thing, so I'll leave my reply as is. You should use a smiley next time. ![]()
#246 |
Moparrrrrrrr
yeah man its all good. i didnt know that so thanks for the info.
my jeep wont be getting that high (atleast i dont think) but yeah i know what ya mean. cant remember where i saw it, but there was an xj with half moon leaves..looked pretty bad. rigs turning out great man and it looks sick..definitly inspirational.
#247 |
x2^...
Even wit a AAL in my pack I aint got the least bit of wrap with my 3/4 zero rates. I like to think I just raised he mounting point. They aint going no where cuz I made them...LOL... When I get my 3.5" packs I'll prolly leave the block in cuz I like having a sort of custom wheelbase heh and it helps that the tires dont eat my flares.
-1998 XJ Sport 4.0L-
-6.5" RE/Rustys/RC lift, Custom Y-link LAs, custom shackle relocation boxes, Pro Comp/RE monos- -315/75/16 Toyo MTs on Moabs- -Shaved 8.25 w/HD shafts/Auburn LS/4:10s, HP30 w/ Lock-right, sliders, HD track bar bracket, AA SYE, AppA TC skid, AFE intake, Magnaflow exhaust, Bored TB- |
#248 |
Man that tire looks HUGE on the back of your XJ!!
Alabama Dan [ []|||||||[] ] 1988 Jeep Cherokee Laredo 4x4 Bone Stock 163,000 miles |
#249 |
Rear Tire Swing Bumper
Eric, I like the AEV bumper you have in the rear. Do you know where to get one, or if someone has one for sale?
Thanks, Silent |
#250 |
Youngin'
as for the stiffiners part, it isnt impossible to install afterwards. me and a buddy from NAXJA installed them in a couple hours, basically we just dropped the pan a little bit, slid the stiffiners in, marked where to drill the holes pulled it back out and used a drill press to put the holes in. probably done in less the 3 hours but man did i notice a difference in the ride after that!!! highly recommended like eric said!!
2001 Dodge Ram 2500 SLT 4x4 5.9L Cummins Turbo Diesel "The Tow Rig" 1988 Jeep Comanche 2.5L 4cyl - 4 speed manual 2001 Jeep Cherokee Sport
4.6L Golen Engine Stroker 6.5" TnT Customs Longarm Kitl Ford 8.8" w/ disc brakes l 6.5" Rock Krawler Coils l TnT Customs HD Trac Barl Omix Ada HD SYE l 1" UBEsl CV Driveshaft l 35" Maxxis Bighorns l 15 x 8 Cragar Black Soft 8s (4" BS) l High Clearance Shock Mounts l 4 - BAJA off road lights l TnT Customs D30 Truss l Hidden Hitch l ARB Front Diff Cover l AJs Custom Front Bumper l SONY Xplod stereo l Alpine Speakers l TnT Frame StiffenerZ l 22" RE SS Brake Lines l 1.5" TnT Customs Boomerang Shackles l HP D30 l JKS Mini Skids and Sway Bar Brackets l TnT Customs OTK Steering |
#251 |
The Post man
Okay so this morning I pulled the Jeep out and went to open the hatch to load some spares.
DOH! ![]() ![]() It turns out that after I changed my tire carrier, I mounted the tire and never thought to test it to see if the hatch had enough clearance to open. I had to laugh at this, because while most of you probably think I'm skilled or fabbing this stuff comes second nature to me, it doesn't. I usually fight my way through each modification and then stuff like this happens and I have to redo it. The good thing is to fix this won't be very hard at all. I just need to cut out the corner piece that stops the carrier arm from swinging open further (see below). That will be my next little project (repair) I guess. ![]()
#252 |
lol nice. looks good closed at least
#253 |
The Post man
But I have more work that I need to keep you up to date on....
The original theme of this thread was "beefing things up" and this next mod was something I was planning on doing eventually, in fact I was originally going to do it when I had the front axle pulled but I didn't want to delay the other mods. This one is beefing up my Dana 30 some more since I have so much money "invested" in it already, its a keeper. As you may know, my Dana 30 has 4.56 gears, an ARB locker, Warn hub kit with alloy inners / outers and 760 u-joints with full-circle clips. The potential weak areas are the ring and pinion (not much I can do about that) and the tubes. I suppose its not too common but some people have bent their Dana 30's and since I'm on 35's I think its possible that I could too. I could add a truss, which is what most people do but I decided to do something a little different: sleeve it. Not only sleeve it, but my LCA mounts where in sad shape even though I've had JKS mini-skids on them. I've beat them so much on the rocks that the mini skids where actually starting to push up and make contact with my old LCAs. So I figured I could install new LCA mounts while I was at it. Compared to some of my other mods, this one wasn't too expensive. I bought a two foot length of Sched 40 pipe locally and some LCA mounts from Currie. The pipe is 2.5" I.D. and 3/16" thick walls. I could have went ultra strong and got 3" DOM with 1/4" walls, but my metal supplier didn't have any and inferred that it would be costly to get. So hopefully the pipe will work. ![]() One note on the Currie LCAs brackets. They are supposed to be stock replacements, but the cut that wraps around the axle tube has a larger radius than the stock 2.5" of the Dana 30. It fits a 3" tube exactly so it has a pretty good fit for my pipe too (not quite 3" diameter). So I started by cutting off the old LCA mounts. Also notice my passenger-side UCA mount. On other Dana 30s I've noticed that the open side is to the front. Mine is to the rear and I don't know why. I don't think it makes much difference. Either way, this is something you definitely need to beef up. I've seen a few of these literally get ripped off, or bend badly. The previous owner of this axle welded a tab across it for support, but I noticed it started cracking beneath that tab a couple years ago. So I added a second piece for more support and to repair the crack. I'll be making this better too while I'm at it. ![]()
#254 |
The Post man
Next was cut the pipe to length and cut it in half lengthwise. Obviously the best way to sleeve an axle is cut off the knuckles and all the mounts and slide that thing on, but I'm not about to do that. This will have to do. As you can see the whole bottom half is sleeved and the top part from the center section to the UCA mount. I drilled some rosettes for plug welding also.
![]() Here's the back side all welded up with the new LCA mounts. Notice I also plated the whole inside of the UCA mount. No more cracks for that thing! At first I was thinking about raising the LCA's up some but I couldn't see a real easy way to do it and didn't want to risk possibly not being able to attach my Treks Y-Link arms back up. So I only ended up raising them up a hair, maybe 1/4" or 1/2" at most. ![]() Another point to doing this is it will keep the tubes from spinning in the center section, which is real bad when that happens. I don't think its too common for Dana 30s, but hey, why not address that problem too! So I welded around the seam connecting the pipe to the center section which is cast. Now this was my first time welding to cast and I've heard it can be difficult. Sure enough, after running my bead I heard a pronounced "crack" and with a light I could see that my weld cracked. Bummer. So later I ran a second bead 1/3'rd on the pipe and overlapping the crack of the first bead. This time when it cooled it did not crack. I also pre-heated the cast part with a propane torch some but I kind of doubt it helped. Here's the driver side. I just added a half-sleeve to the bottom. You also get a good view of my LCA skids made out of 1/4" plate. ![]() And from the back: ![]()
#255 |
Your XJ is killer and your advice is spot on. So I have to ask a question.
If you had it all to do over again would you have still kept the D-30 or would you swap it out if so to what F/S D-44 or other? Keep on making us chris
95 Cherokee SE 4.0, 5-Spd, 8.25; 6.5" Rusty's Lift, Atlas II Rims, 35x12.5x15 Wild Country,Rusty's Tube Bumper, Wilderness Rack Rock Sliders, K&N Panel Air filter, PSC steering box, I-ROK reinforcement kit, ORO U-TURN steering kit,Conversion Headlights/Silverstars And too much $$$ |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
