Quantcast Time to beef things up! - - a build thread of sorts - Page 16 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Time to beef things up! - - a build thread of sorts
Official Chassis Saver Rust Preventive Truck & Auto UnTJ 5.25" Speaker Adapters - NalinMFGSALE -- Yukon Gear Free Spin Hub Conversion Kit - Dana 30
Old 07-08-2008, 12:02 PM   #226
Gravesdiggerxj
I dig those shackle boxes Eric, I'll have to build a set.
Gravesdiggerxj is offline   Reply With Quote
Old 07-09-2008, 02:09 AM   #227
EricsXJ
The Post man
EricsXJ's Avatar
Here's a short video clip from my last trail ride. I came down hard on the frame rail and only got a scratch.
video clip
Eric
2000 XJ "PROJECT RUBICON" lifted, locked, shafted, running 35's, 4.56 gears, pair of ARB's, and stock AM/FM cassette
My website - EricsXJ.com
EricsXJ is offline   Reply With Quote
Old 07-10-2008, 08:52 PM   #228
berettajeep
Eric you take to long posting up here!
I need my daily Cherokee upgrade fix!!
berettajeep is offline   Reply With Quote
Old 07-10-2008, 09:20 PM   #229
COJeepin
Yeah, me too Eric. I already have the rock rails added to my list of upgrades over the winter.
2001 XJ Sport with a whole bunch of stuff
COJeepin is offline   Reply With Quote
Old 07-10-2008, 10:13 PM   #230
wokkerk
I like the video a lot Eric. That lift and those tires make a section like that look easy!
1997xj "SPQR" (in Jeep heaven)
2000xj Freedom Edition "Stormtrooper"
wokkerk is offline   Reply With Quote
Old 07-29-2008, 05:35 PM   #231
familyxj
Come on Eric! I know you have a cage or something else in the works to feed my addiction to this thread!
98 XJ a work in progress and my wife's worst enemy
familyxj is offline   Reply With Quote
Old 07-30-2008, 12:20 AM   #232
EricsXJ
The Post man
EricsXJ's Avatar
Sorry guys! Cage won't be for a while but I still have a few other small projects that still need to be done. There will be updates!
Eric
Old 07-30-2008, 02:50 PM   #233
Yekcid
Schweet build . . .
. . . now subscribed.
Red 99 XJ Sport
Pure stockness for now . . . until Bill Gates pays me back.
Yekcid is offline   Reply With Quote
Old 07-30-2008, 03:39 PM   #234
MidnightRider
can't wait
Legends are Made in Shallow Graves
MidnightRider is offline   Reply With Quote
Old 07-31-2008, 11:53 PM   #235
TreddyoXJ
1997 XJ Cherokee
video clip
"Thought you were going to do it backwards!"
That's pretty funny. I bet you wouldn't have any trouble doing that backwards, though. Your rig looks excellent. Props on all your recent modifications and fab work. I hope you write another book sometime that has all of this stuff included in it.
I have two questions related to earlier in the thread: Do you think that the T&T belly pan and LA's would have clearance issues with the exhaust and hangers in general, or do you think that your issues were a special case specifically due to trail damage? Second, are frame stiffeners a necessity with the T&T system? I'm not real hot on the idea of welding all of that to my frame (or paying for it), but if there are going to be catastrophic consequences for not doing, I suppose I'd have to do it. I'm not noticing any major issues with the rigidity of my frame right now, but I don't wheel that hard at this point. In the future, I imagine that I will go bigger and harder, but are stiffeners really worth the price and effort? Thanks for your input!
SOLD: 1997 Jeep Cherokee Country w/ 4.0L HO, AW4, D44, D30 w/ Aussie locker, Edge Trail Jammer System, 4.5" Rough Country lift, Zacatal Roof Rack, T&T front bumper, On board CO2 (20lbs), All lower body/bumpers/trim are Herculined, JKS Disco's, 31x10.5 MT Baja Claws, Warn 9.5ti, Front Rubi 44 in-progress, T&T Customs lift coming soon... Ephesians 6:10-17.
TreddyoXJ is offline   Reply With Quote
Old 08-10-2008, 01:37 AM   #236
EricsXJ
The Post man
EricsXJ's Avatar
Okay I've finally got some more updates!
So we all know that with a SYE and CV driveshaft, your pinion should be 1 - 3* lower than your driveshaft. I had achieved that using 6* shims. Well after making the shackle boxes which changed my shackle angles, I realized that my pinion angle was pretty messed up. It was actually 1* higher than my driveshaft! So I needed to use smaller shims, but I also wanted to add a tiny bit more lift, 1" or so because the jeep sat level unloaded. But when it was loaded for the trail and with the spare tire on the back I felt it was sagging and I really can't stand that. Originally I was going to re-do the shackle boxes yet again to gain a little lift, but I didn't like the guessing game on where my pinion angle would be, again.
Lucky for me my friend Bryan had recently changed his rear suspension also and got rid of some 1.5" blocks that happened to have a 2.5* taper to them. I figured my 6* shims where about 1/2" thick at the fat end so getting rid of those and installing the blocks should give me roughly 1" lift.
So here's a pic of the block installed and new u-bolts. It did give me a little more than 1" lift, but the biggest benefit is it corrected my pinion angle perfectly. (Now the pinion is 2.5* lower than the driveshaft)
And yes I know blocks aren't the best things, but they do have their place. Think of them as just a really fat shim.
Eric
Old 08-10-2008, 01:48 AM   #237
EricsXJ
The Post man
EricsXJ's Avatar
Then I've also been wanting to modify my rear tire carrier. Why? Because I can't leave well enough alone.
Here is how the tire sat before:
Since I've actually hit the tire before when dropping off ledges, and one time when I did that and forgot to lower the air pressure in that spare, it tweaked my carrier pretty bad, my goal was to raise the tire mount up and also angle it in to match the rear profile of the XJ.
Long story short, here's how it turned out:
And here's a link to another thread I started with other details and a few other pics of this little project: http://www.jeepforum.com/forum/f11/rear-tire-carriers-how-close-your-tire-window-590614/
Eric
Old 08-10-2008, 01:50 AM   #238
broncofire75
Its cute!!
LOL awesome man I like it that way much better. Your jeep looks sick with bumpers, sliders and no doors!
-1998 XJ Sport 4.0L-
-6.5" RE/Rustys/RC lift, Custom Y-link LAs, custom shackle relocation boxes, Pro Comp/RE monos-
-315/75/16 Toyo MTs on Moabs-
-Shaved 8.25 w/HD shafts/Auburn LS/4:10s, HP30 w/ Lock-right, sliders, HD track bar bracket, AA SYE, AppA TC skid, AFE intake, Magnaflow exhaust, Bored TB-
broncofire75 is offline   Reply With Quote
Old 08-10-2008, 01:51 AM   #239
EricsXJ
The Post man
EricsXJ's Avatar
I only have a couple stickers on my rig.
Eric
Old 08-10-2008, 02:02 AM   #240
broncofire75
Who makes the bumper?
Or did you make the whole thing?
Glock Forum
