#211 | ||
Awesome rig by the way, You have some impressive fab skill.
#212 |
The Post man
I have rubber or poly bushings on my axle end as well. But as you can see in the pics most of the articulation is achieved via the johnny joints on the belly pan end of the arms.
Eric 2000 XJ "PROJECT RUBICON" lifted, locked, shafted, running 35's, 4.56 gears, pair of ARB's, and stock AM/FM cassette My website - EricsXJ.com
#213 | ||
Vendor
Jason West - Jeepin.com | JeepinOutfitters.com '95 XJ, RE 5.5", 35" MT/Rs, D30 w/hubs & ARB, D44 w/Detroit, 4.56s, C4x4 bumpers, etc, etc. '09 JK, Unlimited Rubicon, RE 3.5", 35" BFG KM2s, Expedition One bumpers, T&T rockers & skids, XRC10 Comp '00 TJ, SOLD, wife's, RE 4.5" long-arm, 35" MT/Rs, D30+OX, D44+ARB, 4.88s, full cage, winch, C4x4 & Jeeperman bumpers, etc, etc.
#214 | |
Wojtek "who needs paved roads when u have a jeep" 87 xj 6" long arm lift, 35's, 4.88 yukon gears, front detroit true trac colorado jeep club member # 74 |
#215 |
Vendor
you're probably maxing out the rodends on your steering and trackbar.
If you can unload the coils though, why do you need more?
#216 |
I DONT UNLOAD THEM OPPS SORRY FOR CAPS anyway i figured it out it was my track bar
#217 |
Vendor
oh, sorry, thought you said you did.
#218 | |
The Post man
I simply bolted mine to the stock UCA mounts. T&T Customs = $69.95 + shipping and welding required Pyrotect = $45.25 after shipping and they are the exact length I need + bolt on.
#219 |
I recently put the Teraflex rear disc brake conversion kit on my 2000 XJ and was wondering what replacement disks and pads I would order when these wear out? I'm currently in Korea and have to order everything online which makes mistakes costly. Are these parts the same as the on the Grand Cherokee rear brakes?
#220 |
The Post man
James,
That really belongs in its own separate thread but thats okay - the TeraFlex kit uses Ford Explorer parts. And its time for another update... Next on the list to do was to address issues with my rear suspension so I tore it apart. ![]() My RE 4.5" leafs have been on my rig for more than 6 years. I've noticed that the bushings were worn and needed to be replaced. When I took out the leaf pack, this is what I saw: ![]() And the rubber bushing literally fell out in my hand... ![]() A couple months prior I had purchased replacement RE bushings via Jason at Jeepin Outfitters so I had these ready to go in. But I knew it would be a struggle to press these in in my garage so I removed the old bushings and sleeves myself and took them in to a spring shop to have the new bushings pressed in. They charged me $10 a bushing = $40 which is more than I wanted to pay but it was still worth it. ![]() Then it was time to address the condition of the leafs themselves. Here's what they looked like: ![]() I hate rust! So I took a wire wheel to the leafs to clean them up and get them ready for fresh paint. It took several hours to go through each leaf and get it done. ![]()
#221 |
The Post man
Then I built a shackle box to improve my shackle angle. Because this could be its own write-up I started one in another thread with more details. That thread is here: making a custom shackle box
Here are a few pics however: Built using 1/4" plate. ![]() Had to redrill the hole to get the proper angle. Hoping for 45*. ![]() Then I put it back together and here is what I ended up with. ![]() I was in a rush to get this done before a trail ride the very next day. So I didn't have a chance to test them out before I left. When I got to camp I found a rock to test the flex out on. ![]() By my best judgement it looks like I've drooped the driver side tire about an inch or maybe two further than before, with much more room to go only there wasn't enough weight to push the axle down further. The improvement wasn't earth shattering but I'm certainly happy with that. It should also flex easier and I believe it does, but again, I didn't have bad flex to begin with so the improvement was not as noticeable as it would otherwise be. Here is the same flex shot showing the shackle at droop: ![]() And here is a shot of the suspension compressed: ![]() And just another flex shot: ![]()
#222 |
Damn!
You don't skimp on quality work!
I have an xj and it is blue |
#224 |
Sweet! I worked on my rear suspension last night and found an abundance of surface rust. Not cool.
FOR SALE 1998 Cherokee Classic - White
5" lift - 35" tires - locked/geared/shafted/armored 2012 Subaru WRX Limited |
#225 |
Moparrrrrrrr
so you guys dont like rust? stay away from minnesota then
![]() my jeep doesnt have much rust though so its all good. just little spots underneath here and there on the suspension. jeep looks good and im subscribing because after mines lifted and done with suspension and bumper mods and what not, im looking into so stiffiners..
-2001 Dodge Dakota Quad Cab 4x4 - 4.7 V8, the new hotness! -1997 Jeep Grand Cherokee Limited - 4.0, 4" lift, 33s, bilstiens, IRO stuff, FOR SALE -1999 Jeep Cherokee Sport 2 door - 4.0, 8" lift, 35" KM2s, IRO stuff, Long Armed, Armored, Rolled, Parted |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
