#166 | ||
The Post man
Thanks Heavy. I might end up doing it that way.
So far I am pleased with the T&T long-arms save the few quality control issues I had with the parts they sent me. I was a little dissapointed in that regard. I should not have had to drill out the control arm holes in the belly pan because the holes didn't line up. Anyway, time will tell on if I like the geometry and joints / bushings they use.The C-Rok plate is very nice and I am happy with it. If you can weld, the JKS becomes another option and I believe either one is good. Hope that helps you out. Edit: one other option for the steering reinforcement is since you are using the TMR plates, you could just fab up your own steering plates to cover that area and weld it in just like the other frame plating you are doing. The disadvantage is you don't have any inner-frame bracer or crush-sleeves but if your frame isn't cracked in that area now you will probably be okay. Maybe C-Rok can sell you the inner brace by itself??? I am not using the inner brace on mine.
Eric 2000 XJ "PROJECT RUBICON" lifted, locked, shafted, running 35's, 4.56 gears, pair of ARB's, and stock AM/FM cassette My website - EricsXJ.com
#167 | |
Vendor
![]() FWIW, I know that T&T's inner frame brace is available separately.
Jason West - Jeepin.com | JeepinOutfitters.com '95 XJ, RE 5.5", 35" MT/Rs, D30 w/hubs & ARB, D44 w/Detroit, 4.56s, C4x4 bumpers, etc, etc. '09 JK, Unlimited Rubicon, RE 3.5", 35" BFG KM2s, Expedition One bumpers, T&T rockers & skids, XRC10 Comp '00 TJ, SOLD, wife's, RE 4.5" long-arm, 35" MT/Rs, D30+OX, D44+ARB, 4.88s, full cage, winch, C4x4 & Jeeperman bumpers, etc, etc.
#168 |
The Post man
Jason, are the RE long-arms thicker than the RE short-arms? I was assuming they were made of the same material but I don't think the short arms were 2" diameter and they didn't "feel" very thick (like 1/4 wall). If their long arms are thicker, then that was a bad assumption on my part.
#169 |
Vendor
Yeah, there's a big difference in size btwn the material they use for their short arms and for their long arms.
This is the only shot I've got that kinda sorta illustrates the size difference... the tubing on the SuperFlex adjustable end at the crossmember, that's the same size as what's used on the lower arms I think. The rest is the regular size for their long-arms. ![]() RE long-arms vs short arms ![]() ![]()
#170 |
Sweet write up. I need to work a lot more OT and keep putting $ in the bank so I can do this to my 98 XJ. Have you noticed a difference in the ride from your RE to your T&T kit?
98 XJ a work in progress and my wife's worst enemy |
#171 |
The Post man
Got a small update for you.
Its been hot weather here recently so I took the fronts off. ![]() As you can see I worked up a solution for side mirrors. In Sharpie's write-up he mentioned he found some at Autozone that worked for him, so I was on the lookout for something similar. I found these at a local PepBoys for $16 each I think it was. ![]() You just don't use the included clamp, and instead just find an appropriate sized bolt and bolt them on to the hinge holes. No modifications required other than I painted them black to get rid of the bling. ![]() ![]() What sucks about driving doorless is you lose the speakers. The exhaust is a lot louder too so no more radio while driving... hmm....
#172 |
Damnit, I need to do this. I wanna see what its like not having doors. Any trouble with the po-po??
Sounds like its time for some kick panel pods. I dunno about yours, but my rear ceiling speakers are better than my fronts, so I'll still have plenty of tunes with no doors. My exhaust is stock as well.
FOR SALE 1998 Cherokee Classic - White
5" lift - 35" tires - locked/geared/shafted/armored 2012 Subaru WRX Limited |
#173 |
In regard to your music dilemma, here's my solution:
![]() I actually have about 75% of the sound faded to the rear speakers and it sounds great like that with these speakers right in your ear.
1998 White ZJ Laredo: 5.2/242 // d30/d44a // BB // MX6's // Black Steelies // 30x9.50x15 BFG A/T's // FM50 // JCR T-Case Skid // Leather and stuff |
#174 |
Whoa, that first doorless pic looks like steel, and not patriot blue.
I have an xj and it is blue |
#175 |
where did you get that soundbar from?
#176 |
Yes Man!
Soundbar is probably from an earlier xj 96 below. Its for the rear. Edit; Maybe not, but the same can be done with what i said.
#177 |
oh I didnt know earlier xjs had soundbars thanks
#178 |
Mine is very similar to yours, but its in the stock '98 location in the roof right behind the rear seats. Still puts out great sound to the front, so I have mine faded to the rear some as well. The door speakers are too far down to really put out any decent sound.
#179 |
i have the same mirror. except i dont have the big holes from the hinge so i used a bolt from the fender.
The new rockers make the doorless look better too.
There was the episode where I threw my shoe at the enemy, like this!.... my foots cold. |
#180 |
The Post man
No not yet but I am legal in every way except technically I need horns. (stock ones failed after submerging them.) I work for the SO here but I'm not a street cop... I looked up the Nevada law regarding vehicle equipment. Tecnically I only need one rear facing mirror so I'm going above and beyond with the side mirrors. I do like having them for convenience sake. And there is no mention at all about doors being needed, or removing them being prohibited, etc. The problem I see is not having doors may draw the attention of some highway trooper that may pull me over looking for other safety equipment violations. And besides, not only Wranglers, but the UPS guys drive doorless (or door open) all the time too.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
