Tightening track bar problems + death wobble - JeepForum.com
post #1 of 4 Old 06-09-2011, 07:11 PM Thread Starter
fedx95
1993 XJ Cherokee
Background: junkyard lift, 5.5" front, 5" rear. stock trackbar with redrilled hole
alright, so i lifted another 1" on the front (to 5.5) and went to 33's. immediately i got death wobble. I tightened my steering box, steering box bolts, correct air pressure on the tires...etc. I had a buddy move the wheel back and forth while i inspected the steering mechanisms. Whoa, that trackbar had play. the axle bolt is properly torqued. Here's the problem:
I was able to remove the upper trackbar nut. now the bolt that it was attached too doesn't move up or down, but the trackbar still wobbles freely about 1/4 of an inch up or down. i cannot remove the trackbar at all. I banged it, flexed in both directions and banged it while flexed. Tried a hammer and wedge too, all to no avail.
To repeat, when i shake the trackbar, it moves vertically about .25 of an inch, but the bolt (with the nut removed) doesn't move at all. PB blasted the hell out of it too.
What can I do to remove the trackbar or to tighten it properly?
Thanks
fedx95 is offline
post #2 of 4 Old 06-09-2011, 07:34 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Get a ratcheting cargo strap. Wrap it over the track-bar and under the axle. Ratchet it tight. Pound on the side of the track-bar frame bracket with a big effin hammer.
The track-bar is worn out and needs to be replaced. At 5" of lift you should be using a double shear heavy duty adjustable track-bar.
CJ7-Tim is offline
post #3 of 4 Old 06-09-2011, 07:52 PM Thread Starter
fedx95
1993 XJ Cherokee
that makes sense. ill try it tomorrow. I thought about the cargo straps for the tightening the socket wrench, but that's a way better application.
Ill see what i do about replacing it. I might have to get another stock one for now. Its mostly a dd, but with some light trail use. i want to do a 4x4 conversion first, which might be coming up soon.
fedx95 is offline
post #4 of 4 Old 06-11-2011, 07:55 AM Thread Starter
fedx95
1993 XJ Cherokee
fixed the deathwobble. The upper joint was so worn it was moving around even with the bolt tightened. Replaced the trackbar with a good junkyard one today. No more deathwobble and the steering feel was greatly improved. Had to hit the side of the trackbar with a BFH, the cargo straps couldn't yank it. Thanks
fedx95 is offline
cherokee , death wobble , tighten , track bar , trackbar
Wobble in front, NOT death wobble, and yes I got the tires balanced 614XJ XJ Cherokee Technical Forum 10 09-26-2012 05:55 AM
High Speed wobble, but not death wobble Schmuckingham XJ Cherokee Technical Forum 10 04-30-2012 07:27 PM
Death Wobble, Idle Problems and Winshield wiper won't turn on until set on high bermudaJEEP XJ Cherokee Technical Forum 4 09-24-2008 10:19 AM
Death Wobble...track bar? broncofire75 XJ Cherokee Technical Forum 15 02-23-2008 08:11 AM
Death Wobble (round 2) - Is it my TRACK BAR? Modfatha XJ Cherokee Technical Forum 9 06-10-2006 07:29 AM
