#1 | |
TieRod conversion
Well after countless hours of searching for a HD Tierod w/bigger TRE's and not being rich enuff to swing theCurrie setup, I decided to do the 1998 V8 Grand Cherokee conversion..Not only is the rod Bigger, IT's Solid all the way thru!..(unlike stock one i have) And the Ends are A LOT beefier then the stock ones i have. Heres the link i followed for the conversion http://www.stu-offroad.com/steering/zjtie/tierod-1.htm I got my parts from Autozone and the "moog" #'s are what was on the boxes i bought. 73$ out the door! Heres some pics of the swap:
![]() ![]() ![]() New parts ![]() ![]() ![]() ![]() ![]() ![]() About 1/8 diff between the 2 ![]()
Colorado Jeep Club Member #'303' 1998 Jeep Wrangler TJ Sport 4.0 I6, D30 and D44,4.56 G2 Gears,belly,gas & steering skids, 35x12.5 Wrangler MTR Kevlars,4" ProComp Coils,1.25" JKS BL,1"Currie MML,Bilstein 5100's, Chromoly LCA's front and rear, JKS Disco's,K&N intake,PSC BFH front stinger bumper w/winch & d-rings,PSC Rear stinger/carrier w/d-ring,PSC Rocker Knockers,Dynomax Ultraflo welded ss, APN header,PIAA 520 ATP, Bestop top,alpine CDA-105 deck,Tuffy underseat Security box, JL Audio speakers in sound bar and dash, Corbeau front seats, matching Neoprene cover on bench,trimmed flares...and PLENTY more to come.. **Oil Field Trash Makin' Oil Field Ca$h**
#2 |
![]() ![]() ![]() I know its not a Chromoly tierod, BUT its is a HUGE diff in weight, strength and hopefully durability ..Gives me piece of mind knowing i have a rod that doesnt flex with the pull of a hand...And now i have a spare Trail Rod Just in case!... Going to check Toe, Camber, and alignment in the a.m.. Hope this helped someone out there that was looking for a non "break the bank" way to beef things up a bit. ![]()
#3 |
Good post and thanks for taking time to do. I need to do this badly and the price is right. Can you post all the Autozone part number or moog numbers you have?
Thanks. |
#4 |
Nice man, I've done the same.
One of the best mods I've done.
I have an xj and it is blue |
#5 | |
Tie Rod End ES3096L Adjusting Sleeve ES2079S Tie Rod DS1312
#6 |
Awesome....thanks.
#7 |
good plan... my TRE's are looking well, a little old and tired. Was thinking about this too. Thanks for the parts list!!
2000 Jeep Cherokee Classic 1992 M101 CDN2 1/4 Ton Off-road Trailer. 90% Daily Driver 100% Fun! ____=__= l l ,[_____], l---- L -[]lllllll[]- ()_) ()_)--o-)_) |
#8 | ||
i did this conversion only because my old tie rod wasn't adjustable. i also did it for the strength and durability, but when i went to autozone, it was 70 for replacement or 80 for the upgrade.. i wonder what one i chose? definitely a great upgrade though and for cheap..
1994 Cherokee Sport - 4.0 HO - AW4 - 4WD Quote:
#9 |
Nicely done!
#10 |
I did the same when installing my lift... I can't believe the difference between the two... how guys wheel with the stock tierod is beyond me... I did however keep my old one as a trail spare.
98 Cherokee Sport- 4.5", AA SYE and TW Shaft, 33" Cooper Discoverer STTs, XCr8000, Jcroffroad Stage 2 Winch Bumper , 60" Hi-lift, Cobra Ultra III, Gragar Soft 8s, Detour Tail Bone, jcr Offroad Stage 2 Sliders, RockCrusher Diff Covers Front, Lockright in the front, Aussie in the Rear (Ford 8.8) with 488s... More $$$ for Bank Account (On Back Order...) 99 Cherokee Sport- Stock and Staying that Way (Wife's DD) Christian Jeep Group Member #160 |
#11 |
I installed this last night and can tell a difference just cruising down the road. Does not feel like the tires are flexing when hitting a bump like it used to. Definetly worth doing.
#12 |
Looks like I have a project to do...
TNT 5.5", 35 x 12.5 MTRs on Trail Ready Beadlocks Armor: 2x6 inch 3/16 tube rockers, Factory Front and Gas Tank skids, Homemade Mini Skids, Riddler Differential Covers, and Homebrew Hybrid cage. Recovery: AJs Offroad Custom Front Winch Bumper and Rear Tanker Bumper with Homebrew Tire Carrier/Stinger. Rhinolined entire Exterior black, and Herculined interior. Axles: 4.56 superior gears in D30 and 8.25 with 29 spline. Steering: Currie Extreme and PSC Hydro-assist Cardomain: http://www.cardomain.com/ride/2973108 |
#13 |
other than pulling the old one off and putting the new one on. was there any other work that needed to be done?
#14 |
Do a DIY alignment check after. You have to take the driver's side wheel off to get to the castle nut if you are using a torque wrench to tighten things down.
#15 | |
I noticed you kept the stock drag link and right side TRE, are the 98 V8 zj ones the same as the xj ones?
"Too weird to live, too rare to die" 2000 XJ Silver, 3", 31's DD 88 XJ Blue, 4.5", 33's, Project Build Thread Quote:
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
