Tick tick tick tick.... from the tranny or bell housing? - JeepForum.com
post #1 of 14 Old 12-14-2011, 08:10 PM Thread Starter
BlueRidgeMark
1994 XJ Cherokee
I have a new noise to keep me company in my 94 XJ 4.0. It's a light ticking from the trans area, or maybe the bell housing, whenever I'm idling. It goes away under any kind of load.
Any quick ideas?
BlueRidgeMark is offline
post #2 of 14 Old 12-14-2011, 08:23 PM
Driver831
Any quick ideas?
I had an XJ before ( 3 actually ) but non the less had the same issue. Mine turned out to be a cracked flex plate.
Follow on Instagram kids! @ Driver831 @provinggroundsracing
www.Provinggroundsracing.com
Driver831 is offline
post #3 of 14 Old 12-14-2011, 08:25 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Loose flex plate bolts, or as mentioned, possibly a cracked flex plate.
CJ7-Tim is offline
post #4 of 14 Old 12-15-2011, 03:20 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Very common. Get them tightened up by removing them first, applying LocTite, and reinstalling them. There are 4 bolts. If you wait too long, the holes in the flexplate are going to get elongated. Then you get to pull the trans.
cruiser54 is offline
post #5 of 14 Old 12-15-2011, 07:54 AM
Azzy
How is your exhaust looking in the area?
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #6 of 14 Old 12-15-2011, 09:15 PM Thread Starter
BlueRidgeMark
1994 XJ Cherokee
Flex plate? Please educate me! I'm still a newb!
Azzy - the exhaust is fine. I checked that.
post #7 of 14 Old 12-15-2011, 09:19 PM
autoteacher
flex plate is basically the flywheel. The bolts refered to can be reached from the front side of the flexplate.
autoteacher is offline
post #8 of 14 Old 12-16-2011, 04:31 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Somebody needs to do a write-up on this with photos!! I'm tired of typing this each time. Is there one anywhere?
post #9 of 14 Old 12-16-2011, 06:17 AM
Azzy
Pull your inspection cover, its the thin metal at the front of the bellhousing. Get a good flashlight and look up there. Check the bolts holding the flexplate on.. there should be mo slack in them.
Azzy is offline
post #10 of 14 Old 12-16-2011, 06:20 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Azzy, do a write-up wouldya? Not everyone understands what an inspection plate is.
post #11 of 14 Old 12-16-2011, 08:01 PM Thread Starter
BlueRidgeMark
1994 XJ Cherokee
Okay, flywheel I understand. Never heard it called a flexplate before. Is that a Cherokee thing?
Inspection plate...
Gotta be on the front of the bellhousing, I'm guessing. Probably pretty obvious once I get in there. Pull a few bolts, pop the plate off and I can see inside?
That adds up, too, because my stethoscope says it's more of a bell housing noise than a trans noise.
Hmmm. Did an image search on the Web and the first hit was one of our threads!
I'll try to get some pics while I'm at it. Might help the next guy.
post #12 of 14 Old 12-16-2011, 09:07 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Flywheel is for manual trans with a clutch bolted to it. Flexplate is a plate with a ring gear attached to it that bolts to a torque converter. Flexplates have been around since automatic transmissions have. Not just a Jeep thing.
post #13 of 14 Old 12-17-2011, 05:21 AM Thread Starter
BlueRidgeMark
1994 XJ Cherokee
Interesting! I never heard that term before. Thanks for the info.
post #14 of 14 Old 12-17-2011, 05:29 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Do pix for sure.
Tick Tick Tick, awating the boom KurT5 XJ Cherokee Technical Forum 61 03-14-2010 08:08 PM
tick tick tick...I dont think its a problem? JeepNoma XJ Cherokee Technical Forum 12 02-11-2009 05:53 PM
strange tick-tick-tick? 9t3country XJ Cherokee Technical Forum 6 03-06-2008 01:40 PM
Tick Tick Tick from engine - 4.0 danw77 XJ Cherokee Technical Forum 7 01-26-2008 04:07 PM
tick-tickitity-tap in tranny NoVaGP XJ Cherokee Technical Forum 3 04-27-2003 07:34 AM
