Tick Tick Tick from engine - 4.0 - JeepForum.com
post #1 of 8 Old 01-26-2008, 12:23 PM Thread Starter
danw77
1994 ZJ
Tick Tick Tick from engine/ Coolant in Oil
Just picked up a 1999 XJ with 115,000 miles on. This morning I noticed a tick, tick, tick coming from the valve cover area (definately not bottom end). It seems to come and go at all at idle and througout acceleration. Speed of tick increases with engine RPM. It's not a leaking manifold. I picked up a can of rislone to run through it. I'm wondering if it's safe to give it a couple hundred miles to work it's way through or if I should take it in to be looked at right away. I don't know any of the history of this engine.
EDIT- coolant in oil, see below...
danw77 is offline
post #2 of 8 Old 01-26-2008, 12:28 PM
HighCountry
Mine has ticked since I got it NEW in 1995, 241,000 miles and still ticking!
I would probably run 15w30 Chevron Delo or Shell Rotella if I were you. Here in the South, mine seems to do best with 15w40 Chevron Delo and a Wix 51515 filter!
Bruce
HighCountry is offline
post #3 of 8 Old 01-26-2008, 12:37 PM Thread Starter
danw77
1994 ZJ
ARGGHHHH! I just notice coolant in the oil.
Any ideas?
danw77 is offline
post #4 of 8 Old 01-26-2008, 01:00 PM
Viscerebral
1990 XJ Cherokee
pray for gasket failure. better than cracked head. pull plugs and look. someone here mentioned something about heads more likely to crack between certain cylinders some time waaaay back.
Viscerebral is offline
post #5 of 8 Old 01-26-2008, 01:07 PM Thread Starter
danw77
1994 ZJ
when i pull the plugs, what do i look for? never had this happen before, and no idea what to do next?!
danw77 is offline
post #6 of 8 Old 01-26-2008, 01:12 PM
Viscerebral
1990 XJ Cherokee
i am probably wrong, but: when my water pump went out and jeep got real hot i had my head gasket blow. water only in #3, but others dry. i believe the gist of the post i thought i read here was that the 4.0 was more prone to head cracking at one point moreso than others, and would allow water in adjacent cylinders, not just one.
forgive me if my memory is faulty.
post #7 of 8 Old 01-26-2008, 03:58 PM
nascarnation
1997 XJ Cherokee
Good input, thanks.
I got my first XJ about 5 months ago and figured it's just part of the Jeep character. I'm using 5W40 Rotella syn.
nascarnation is offline
post #8 of 8 Old 01-26-2008, 04:07 PM
89warwagon
1989 XJ Cherokee
your gonna have to pull the head and take it to the shop to have it magnafluxed(checked for cracks)and have it resurfaced because it's likely warped.
if your really lucky the headbolts are not torqued tight enough causing the head gasket to fail.....
89 xj 5.5 rubicon express,34" swamper ltb's
89warwagon is offline
engine tick jeepkid03 XJ Cherokee Technical Forum 3 12-19-2009 09:25 PM
Weird Engine Tick, I need help AllMuscle XJ Cherokee Technical Forum 5 10-07-2009 12:03 AM
Engine tick cherokeebob1966 XJ Cherokee Technical Forum 13 03-01-2009 06:16 PM
tick tick tick...I dont think its a problem? JeepNoma XJ Cherokee Technical Forum 12 02-11-2009 05:53 PM
strange tick-tick-tick? 9t3country XJ Cherokee Technical Forum 6 03-06-2008 01:40 PM
