Thunderbird Coils + S10 Bastard Pack Lift - Page 4 - JeepForum.com
post #46 of 57 Old 02-05-2012, 10:59 PM Thread Starter
fedx95
1993 XJ Cherokee
Ok, if you decide to used the overload leaf however, you will need longer u bolts. Just make sure they are in excellent condition.
fedx95 is offline
post #47 of 57 Old 02-08-2012, 12:34 AM
Sorenabel
1990 XJ Cherokee
Ok thank you. I did the lift thee other day with the full s10 pack in the rear added to the xj main and then the tbird could in the front. Did anyone leave the stock xj coil isolaters on with the tbird coils? The lift turned out great. Got about 4.5" of lift in the rear and about 4" of lift in the front. She rides alot better now then stock. I left the stock xj coil isolatetoff when putting the tibrds coils on, I was thinking about puttin them back on to level it with the rear? Or maybe using some camaro coil isolaters I got from the the junkyard?
Sorenabel is offline
post #48 of 57 Old 02-08-2012, 09:36 AM Thread Starter
fedx95
1993 XJ Cherokee
I left the stock isolators there. You can net more or less lift depending on how you put the tbird strut plate on. About 1" up or down. I would suggest you put the isolator on to dampen the load a bit
fedx95 is offline
post #49 of 57 Old 02-08-2012, 04:21 PM
Sorenabel
1990 XJ Cherokee
Ok ill do that as soon as the weather gets a little better. The tbird coils are alot softer then I thought they would be.
post #50 of 57 Old 03-29-2012, 05:11 PM
dillonreid
1992 XJ Cherokee
I have a three inch procomp on my cherokee that is about 10 years old so my leafs are sagginf do you think i could just use Dakota or s10 leafs to get back my 3 inches? If so how would i go about doing that? And could i do tbird coils with out new brake lines?
dillonreid is offline
post #51 of 57 Old 03-29-2012, 10:19 PM Thread Starter
fedx95
1993 XJ Cherokee
If you use two of the three leaves of s10 pack, you could probably net 3". I would use the main s10 leaf and the second one, ditch the third and the overload.
fedx95 is offline
post #52 of 57 Old 03-29-2012, 10:51 PM
keepishop
1989 XJ Cherokee
s10 leaves are wonderful for bastard packs. I've got a thread with a few different mixes of xj and s10 leaves that might help.
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap,
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline
post #53 of 57 Old 03-29-2012, 11:16 PM
dillonreid
1992 XJ Cherokee
Sweet thanks guys ill be sure to let you know how it goes I'm going to be away from the Jeep for nine days so I have plenty of time to research haha
http://www.jeepforum.com/forum/f22/my-jeep-geoff-texas-build-1348154/
post #54 of 57 Old 06-12-2013, 02:45 PM
alecxj
How many inches of lift did it give you??
alecxj is offline
post #55 of 57 Old 11-25-2013, 03:14 PM
theHouseOG
I bought two new Thunderbird Coils from a company on ebay. They were super cheap but New so I skipped out on going to the junk yard. But I don't have the thunderbird strut plate. What does that mean? Will this not allow me to attach it to the XJ? I have been searching but can't find a definitive answer on this.
Thanks
theHouseOG is offline
post #56 of 57 Old 11-25-2013, 03:50 PM
JV82000
1989 XJ Cherokee
Yes you need the strut plate. The thunderbird coils don't taper in like the xj does.
JV82000 is offline
post #57 of 57 Old 11-25-2013, 04:08 PM
theHouseOG
****..... is my official response.
Looks like I'm going to have to go purchase some strut plates.
Quick bastard pack ??? (not about lift) jeeptech01 XJ Cherokee Technical Forum 3 01-08-2011 07:54 AM
OME/Bastard Pack Rear Lift durfXJ XJ Cherokee Technical Forum 0 04-29-2009 04:10 AM
YJ lift springs for bastard pack?? PH0T0 XJ Cherokee Technical Forum 4 01-05-2009 04:35 PM
How much lift from a bastard pack and what... 4.0H.O.XJ XJ Cherokee Technical Forum 2 06-27-2008 10:27 AM
bastard pack lift 1988XJ XJ Cherokee Technical Forum 4 10-07-2007 06:29 AM
