Thunderbird Coils + S10 Bastard Pack Lift - Page 3 - JeepForum.com
post #31 of 57 Old 04-07-2011, 07:47 PM
95whiteXJ
1991 XJ Cherokee
Originally Posted by fedx95
If you want the same amount of lift as me, use your XJ main, and the whole s10 leaf pack without the overload (the stubby small bottom one).
The overload will give you about another 3/8-1/2 of lift, but you will need longer u bolts. Remember-absolutely important -PBBLASTER a week before. Will make your install time like 5x faster.
Get some carbide bits a hair larger than the S10 centerpin. You will need them to bore out the XJ leaf spring. REGULAR BITS WON'T WORK I TRIED.
Get some kind of leaf compressor. I used ratcheting tie downs, b/c i was able to drop the front axle so far down, and needed minimal compression
Good to know....and my fire dept chief has spring compressors he's gonna let me use so I don't have to rent some again lol
95whiteXJ is offline
post #32 of 57 Old 04-11-2011, 07:44 PM Thread Starter
fedx95
1993 XJ Cherokee
update:
i have been driving it around.
I took it up to 85mph, no vibes (apart from the damn warped rotors under braking). Very satisfied, the ride is good, just take it easy on the speedbumps. The airshocks are going in tomorrow or wednesday.
fedx95 is offline
post #33 of 57 Old 04-14-2011, 08:31 PM
JV82000
1989 XJ Cherokee
Your really should get some new LCA's and a new trac bar. The old stuff is too short. I'm doing the lift as we speak but i'm installing a RE adjustable trac bar, RC fixed LCA's, front brake lines from a chevy truck, rear brake line from a dodge van, and also I'm going to try and make some sway bar disco's from a set of links off of a full size bronco.
JV82000 is offline
post #34 of 57 Old 04-15-2011, 05:51 AM Thread Starter
fedx95
1993 XJ Cherokee
I'm doing the brakelines and I have to do something with the swaybar, ie longer bracket or discos, I'm on a vey tight budget, and can't really afford the Lcas or trackbar. I just redrilled my trackbar hole, seems to be working fine. I installed the rear airshocks, gave me an inch of lift in the rear, which leveled out the Jeep. I only inflated to 70psi, out of a possible 200psi. Ride is still good, a little harsh on large depressions in the road
fedx95 is offline
post #35 of 57 Old 05-06-2011, 05:14 PM
1stblack97ZJ
What are you doing for front sway bar links.
Also, did you ever end up making a writeup?
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline
post #36 of 57 Old 05-07-2011, 06:36 AM Thread Starter
fedx95
1993 XJ Cherokee
I'm still running the stock swaybar links. They barely rub if at all. I might weld something up. I'll have to do write soon if there's enough demand
fedx95 is offline
post #37 of 57 Old 05-07-2011, 07:47 AM
1stblack97ZJ
Hmm. guess ill buy some from IRO.
I'm also doing thunderbird springs in the front.
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
post #38 of 57 Old 05-07-2011, 08:22 AM
Hummeron37s
Interesting. I never heard of this lift but I am new to Jeeps so it ok. I have a addaleaf in the rear and coil spacers in the front but was looking at ways to get rid of the coil spacers. I could do tbird coils in the front and leave the add a leaf or change the whole rig to coilovers or airbags like i want to..
Hummeron37s is offline
post #39 of 57 Old 05-07-2011, 08:03 PM
1stblack97ZJ
here is some info I found on the tbird springs:
Front coil springs from a 3.8 V6 equipped Ford Thunderbird/Cougar offer 3-4in of lift and the softer ones noted below ride and flex like stock XJ coils.
83-88 TBird, Cougar = more lift
89-97 TBird, Cougar = less lift
Spring ratings:
Front: 223-282 lb./in. 3.8 liter V6 *closest to XJ ratings* these coils are used on the bare bones basic cars
Front: 349-403 lb./in. 3.8 liter SC Loaded with every option, very stiff ride
Front: 270-330 lb./in V8 Medium ride
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
post #40 of 57 Old 05-25-2011, 06:34 AM Thread Starter
fedx95
1993 XJ Cherokee
update:
do not buy the shock extenders and reuse stock length shocks. They work fine off road, but I took it wheeling last saturday and bent one, and snapped the other. So one side of my jeep is bouncing till i go pick up my spares.
fedx95 is offline
post #41 of 57 Old 01-25-2012, 01:59 AM
Sorenabel
1990 XJ Cherokee
So any of the tbirds will give a stock jeep atleast 3" or so inches of lift? Just wondering cause I was at the jy today and was going to pull some v6 or v8 ones out but the could looked shorter them jeeps stocks springs... Is it just the spring and isolater that we use for it? Thank you
Sorenabel is offline
post #42 of 57 Old 01-26-2012, 08:14 AM Thread Starter
fedx95
1993 XJ Cherokee
v6 ones are the best ride. v8 ones are medium. v6 SC (aka loaded trim) are very harsh so don't get those. They will all probably net you 4.5 of lift with the strut plate.
fedx95 is offline
post #43 of 57 Old 01-27-2012, 06:54 PM
Sorenabel
1990 XJ Cherokee
Did you use your stock u bolts for the rear leafs?
post #44 of 57 Old 01-31-2012, 09:31 PM Thread Starter
fedx95
1993 XJ Cherokee
I did but only because
1)the jeep had absolutely no rust (miami jeep).
2)budget
Unless you live in miami or arizona, i highly suggest you get some new ones.
fedx95 is offline
post #45 of 57 Old 02-04-2012, 11:21 PM
Sorenabel
1990 XJ Cherokee
I live in medford oregon. Theres no rust on my jeep except in the front passenger side wheel well cause my younger sister drive it into a pole doing about 45. But thats the only rust fortunately.
Quick bastard pack ??? (not about lift) jeeptech01 XJ Cherokee Technical Forum 3 01-08-2011 07:54 AM
OME/Bastard Pack Rear Lift durfXJ XJ Cherokee Technical Forum 0 04-29-2009 04:10 AM
YJ lift springs for bastard pack?? PH0T0 XJ Cherokee Technical Forum 4 01-05-2009 04:35 PM
How much lift from a bastard pack and what... 4.0H.O.XJ XJ Cherokee Technical Forum 2 06-27-2008 10:27 AM
bastard pack lift 1988XJ XJ Cherokee Technical Forum 4 10-07-2007 06:29 AM
