Thunderbird Coils + S10 Bastard Pack Lift - Page 2 - JeepForum.com
post #16 of 57 Old 04-03-2011, 06:30 PM Thread Starter
fedx95
1993 XJ Cherokee
i painted the drivers side fender flares today after those pictures, if anyone caught that only the passenger side is painted
fedx95 is offline
post #17 of 57 Old 04-04-2011, 02:20 PM Thread Starter
fedx95
1993 XJ Cherokee
ok so i need swaybar links as well as brakelines. till then i cant flex
fedx95 is offline
post #18 of 57 Old 04-04-2011, 02:49 PM
keepishop
1989 XJ Cherokee
You can relocate your front brake lines to allow for another 2 or 3 inches of travel.
http://liftyourxj.com/tweaks.html#BrakeLines
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap,
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline
post #19 of 57 Old 04-04-2011, 02:54 PM
Diamond-x
1991 XJ Cherokee
I think I found the source of the heat, the huge iron plate under your rig!
Nice job on the lift.
Diamond-x is offline
post #20 of 57 Old 04-04-2011, 05:07 PM Thread Starter
fedx95
1993 XJ Cherokee
thanks. yeah, that plate burned me a few times. thats my oil catch pan. im tired of failing to fix leaks
fedx95 is offline
post #21 of 57 Old 04-04-2011, 05:08 PM Thread Starter
fedx95
1993 XJ Cherokee
thanks kepishop. ill be doing that. the rear however are the ones that dont have as much slack
fedx95 is offline
post #22 of 57 Old 04-04-2011, 09:15 PM
keepishop
1989 XJ Cherokee
Unbolt the distribution block. Actually to do it right (er, right-er, less wrong, whatever...) you can make a bracket to move the block up higher by a couple inches. Just a Z shaped chunk of sheet metal with a hole on either end. Sandwich one end to the axle with the breather tube bolt thing (maybe use a spacer to keep the length right), and use a bolt and a nut on the other end to hold the block in place.
Should work fine on the road, but don't wheel on it since it leaves the hard lines in a more vulnerable place to branches.
Bleed or Quit.
post #23 of 57 Old 04-05-2011, 05:04 PM
wretchedjeep
Its tough to tell from the pics, but how much lift would you say you got? Also, is it enough to warrant a sye?
wretchedjeep is offline
post #24 of 57 Old 04-05-2011, 05:19 PM Thread Starter
fedx95
1993 XJ Cherokee
The front is sitting at 22" from hub to flare, so that's about 4.5" of lift. The rear was lifted about 3.5-4". I have to go measure again. I don't need the SYE b/c i have a 2wd. So far, ive driven top speed of about 45mph, and no vibrations. Of the brake lines, the one that needs extending the most is the one that goes vertical to the body from the axle, closer to the middle, that is only on the drivers side.
fedx95 is offline
post #25 of 57 Old 04-06-2011, 09:36 AM
wretchedjeep
That's not bad at all. I'm interested to see the flex you get out of it. How much did it cost to do?
post #26 of 57 Old 04-06-2011, 09:46 AM Thread Starter
fedx95
1993 XJ Cherokee
cost me under $200, and thats with new shocks, but not including brake lines or sway bar links. I can't flex till
i take care of the brake lines
fedx95 is offline
post #27 of 57 Old 04-07-2011, 11:55 AM
95whiteXJ
1991 XJ Cherokee
For the bastard pack...do I need to use all the S-10 leafs, or just the first 2?
And I have a ZJ pitman arm and tie rod ready to install with the t-bird & S-10 leafs....would these help in the alignment & camber?
95whiteXJ is offline
post #28 of 57 Old 04-07-2011, 04:20 PM
keepishop
1989 XJ Cherokee
Whatever you want. The idea is to mix and match until you get exactly what works for you.
No. Not at all. The tierod is a good thing, but it will still need to be adjusted after a lift.
Bleed or Quit.
post #29 of 57 Old 04-07-2011, 04:39 PM
95whiteXJ
1991 XJ Cherokee
'Preciate the advice.
Brandon
post #30 of 57 Old 04-07-2011, 07:39 PM Thread Starter
fedx95
1993 XJ Cherokee
If you want the same amount of lift as me, use your XJ main, and the whole s10 leaf pack without the overload (the stubby small bottom one).
The overload will give you about another 3/8-1/2 of lift, but you will need longer u bolts. Remember-absolutely important -PBBLASTER a week before. Will make your install time like 5x faster.
Get some carbide bits a hair larger than the S10 centerpin. You will need them to bore out the XJ leaf spring. REGULAR BITS WON'T WORK I TRIED.
Get some kind of leaf compressor. I used ratcheting tie downs, b/c i was able to drop the front axle so far down, and needed minimal compression
fedx95 is offline
Quick bastard pack ??? (not about lift) jeeptech01 XJ Cherokee Technical Forum 3 01-08-2011 07:54 AM
OME/Bastard Pack Rear Lift durfXJ XJ Cherokee Technical Forum 0 04-29-2009 04:10 AM
YJ lift springs for bastard pack?? PH0T0 XJ Cherokee Technical Forum 4 01-05-2009 04:35 PM
How much lift from a bastard pack and what... 4.0H.O.XJ XJ Cherokee Technical Forum 2 06-27-2008 10:27 AM
bastard pack lift 1988XJ XJ Cherokee Technical Forum 4 10-07-2007 06:29 AM
