Thumping noise when hitting brakes...Not Pulsating - JeepForum.com
post #1 of 2 Old 04-21-2012, 04:35 PM Thread Starter
LrgLnrd
So I finally got some of my front end fixed which included new u-joints on both sides of the axles and the right front wheel bearing. I had/have a really bad thumping when I hit my brakes that I thought was my left front u-joint but it still remains after replacing. When I had my brakes apart everything looked to be in proper working order good pads, rotors were decent and their not warped no grabbing or dragging sensation.
After some diagnosing I can say that if I use my e-brake to slow down to a stop there is no thump and it feels to coming from the left front when I do use my brakes to stop, also it is speed sensitive the slower I go the longer of a pause before the thump.
I shook my front end down and checked all my fluids in the diff. and transfer case..(This was low) Could this be the culprit????
I also have the "notorious" flex plate thump but thats not what I am hearing...I dont think so...
Any info would be really appreciated, I am gonna try to check it out tomorrow on a lift with it in 4wd hitting the brakes while in the air but not sure if Im gonna have time to check it out.
Thanks Again,
Greg
LrgLnrd is offline
post #2 of 2 Old 05-28-2013, 09:30 AM
XJNKY
I know this is over a year old, but may I ask, did you ever find out what the culprit was? I've been chasing exactly the same thing. I've replaced both front wheel bearings, and brakes. The only thing I have left to look at is my tires, and they're fairly new (5K miles?) and they're not cheap tires either (Duratracs).
Just curious if you ever tracked down your thump.
XJNKY is offline
Thumping noise coltar15 XJ Cherokee Technical Forum 9 10-01-2011 03:41 PM
Thumping noise... JeepNoma XJ Cherokee Technical Forum 4 03-28-2009 04:32 PM
Thumping noise? jeepkid8037 XJ Cherokee Technical Forum 9 01-30-2007 02:49 AM
Pulsating sound when braking...not brakes. TroyAndEddie XJ Cherokee Technical Forum 10 02-25-2005 01:22 AM
