08-29-2002, 01:12 PM
#1
thump or pop sound during turn
Whenever i go and make a relativly sharp turn or quick turn a thump or pop sound is made underneath my jeep. I know its either tires or lift cause it didnt happen stock. Does anyone know what this might be and it is dangerous. It doesnt sound too threatening, but still
1998 Jeep Cherokee 4.0L I6. 3.5" Rubicon Express Superflex lift. Quick Disconnects, BDS steering stablizer. 31x10.5 BFG MT KMs on 15x8 Black Rockcrawlers. Flowmaster Exhaust, Surco Safari Rack, Smittybilt bumper thumper with IPF 960 driving lights, no rear sway bar, Big Daddy Offroad Monter Tie Rod, Rubicon Express Adjustable UCAs and RE Heavy Duty Trackbar w/ HD Bracket.
08-29-2002, 05:54 PM
#2
The Post man
Does it happen when you turn the wheel sharply to the right, but not when you turn left?
Eric
2000 XJ "PROJECT RUBICON" lifted, locked, shafted, running 35's, 4.56 gears, pair of ARB's, and stock AM/FM cassette
My website - EricsXJ.com
08-29-2002, 06:12 PM
#3
seems to happen when i turn either way, its just like a "crich" or "tuck" sounding sound. woah that is worded wierd, but yeah.
08-29-2002, 08:20 PM
#4
Mine does it from time to time. Usually when turning and braking at the same time. It will also do it if I bump over a curb at a roll sometimes. This started after my lift also. I have looked through the dirt to see if I could see where it was hitting (if it is actually hitting) and found nothing so far. It has not been as frequent lately. I think it has something to do with the position of the spring when under a bit of extra load (i.e. the braking and turning) and how the spring shifts when you turn. I have run it up on all kinds of inclines, turned the wheel this way and that and can never reproduce the sound. I just say keep an eye on your nuts and bolts! If they are all tight I say your fine. Maybe just needs a bigger lift  That's what I'm doing!
BTW, what type of lift do you have? Mine is one of those econo lifts. I'm thinking that my new lift with longer springs may stop it all together.....
[COLOR=DarkOliveGreen]2004-WJ 4.0, Loredo
Kevin's 2.5" BB
265/75R16 Goodyear AT/S
Pro-Comp ES3000 shocks
Westin Safari-Bar
Maxtel 6" Off-Road lights
360? of Tint
Thule Roof Rack
Do my new seat covers count?![/COLOR]
08-29-2002, 08:22 PM
#5
[QUOTE] Originally posted by JCSXJ
[B]seems to happen when i turn either way
Never mind the question of your lift. Duh! I couldn't see it in your description area when I was writing my reply......
Kevin's 2.5" BB
Westin Safari-Bar
360? of Tint
Thule Roof Rack
08-29-2002, 11:07 PM
#6
The Post man
My RE disconnects were the source of most of my post-lift noises. Its easy to eliminate or confirm them as suspect, just disconnect them and drive around (carefully) and listen for noises when to turn. If there are no noises whatsoever, but they return when you put the disconnects back on, there is your answer.
I asked about the left vs right because on mine, when I turn far to the right, the drag link rubs on the lower link of the swaybar disconnect.
Eric
08-29-2002, 11:08 PM
#7
My Jeep will make that similar noise as well. Like you said, I have tried on all types of terrain to make it happen but cannot seem to find it. I have noticed though that every once in a while the tire will grab the fender flare on either side and make a loud pop if i turn and and the susp is flexed a bit. Could that be it?
2001 Cherokee Sport 2-door 4x4
2 inch BB
Surco Safari Rack w/ spare tire roof mount
4 Hella 500's on the rack.
PowerTrax No-Slip
JKS quicker disconnects
Moabs w/ 31inch MTR's
08-29-2002, 11:25 PM
#8
I got a damn noise cus my exhaust is hitting my shackle on almost any kind of spring movement (boooo). but that's not a 'tuck' or 'crich'.
Darren
96 XJ
"Oh, thank god. It's some sort of rescue toaster."
08-30-2002, 07:18 AM
#9
I think it may be my discos. Ill keep you updated tho
08-30-2002, 10:36 PM
#10
I'm completely stock and have noticed something similar. Although I describe the noice as more of a squeak. I can't ever reproduce it, but it seems like it only happens when making a sharp, low speed turn.
2001 Acura CL Type S
2000 Jeep Cherokee Sport 4WD
08-30-2002, 11:39 PM
#11
I had a noise from my exhaust rubbing my shackle also. I applied a lot of foot force and managed to move the pipe away. Now it only does it when I hit a large bump (pothole, etc.). I suppose you could heat and bend the pipe but had no way to do it at the time.....
As for my front end noise it definately more of a sharp clunk.
Kevin's 2.5" BB
Westin Safari-Bar
360? of Tint
Thule Roof Rack
08-31-2002, 11:11 AM
#12
well i took it out for its first run as being a Mod' XJ, and even tho it wasnt a long enough run for me to disconnect my sway bars it was still really fun. But i didnt notice it anytime after i got outta the trails.
09-01-2002, 05:16 PM
#13
1985 AMC XJ 4x4
2.5L, Automatic
Sporting Dual Exhaust Leaks
Eagle Alloys, 10x15
"My Jeep doesn't leak, it marks it's territory!"
09-01-2002, 08:37 PM
#14
I have the same problem on my stock 88. And wolf, now that I think of it, it does sound the same as when my rear u-joints went out. Will have to check em tommorrow.
1988 XJ - 4.0; RE 3.5"; rear D44 w/ ZJ disc brakes; 31x10.50 BFG ATs; Sanden OBA
