Throttle Body Parts - Page 2 - JeepForum.com
post #16 of 27 Old 09-09-2013, 02:01 PM Thread Starter
who_datjeep
Anybody?
who_datjeep is offline
post #17 of 27 Old 09-09-2013, 10:31 PM
infob
1993 XJ Cherokee
I would be interesting to know about a tps gasket aswell since mine never had one unless the po removed it....
infob is offline
post #18 of 27 Old 09-10-2013, 05:22 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Never heard of a TPS gasket.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #19 of 27 Old 09-10-2013, 06:05 PM
infob
1993 XJ Cherokee
Perhaps mistaking the tps for the iac o ring?
infob is offline
post #20 of 27 Old 09-10-2013, 06:46 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Crossed my mind......
post #21 of 27 Old 09-10-2013, 09:03 PM Thread Starter
who_datjeep
No, I did not mean an IAC o ring. I meant a red TPS gasket. It seems that some TPSs come with one and some don't.
post #22 of 27 Old 09-10-2013, 09:17 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Never seen one.
post #23 of 27 Old 09-10-2013, 09:22 PM Thread Starter
who_datjeep
Originally Posted by cruiser54 View Post
Never seen one.
Now you have.
post #24 of 27 Old 09-10-2013, 09:27 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
They must come pre-installed in some TPSs then.
post #25 of 27 Old 09-10-2013, 10:54 PM
infob
1993 XJ Cherokee
Interesting... See something new every day
infob is offline
post #26 of 27 Old 09-12-2013, 12:27 PM
JWELK
Yes, you can blast it with TB cleaner. However the way it is made, it probably will do little good. It is bit like a maze. I noticed no difference before or after cleaning. However after cracking the gasket, the idle was much faster and erratic. A bit of backing from a notepad, an Xacto-knife and some Indian Head gasket cement, all appears to be well.
Regards,
Jim W
JWELK is offline
post #27 of 27 Old 09-13-2013, 03:58 AM
vrsoft
This helped me tremendously: http://www.jeepforum.com/forum/f9/cl...mmies-1114849/
I used cleaner on everything except the sensor connectors (pin areas) to prevent potentially damaging them. I also rinsed the o-ring for the IAC in tap water to make sure it was completely clean before re-using it since it was in good shape and i didn't have a replacement. Otherwise, I'd say always replace o-rings as a best practice.
1993 YJ 4.0L
1999 XJ 4.0L (Going up for sale very soon)
2007 XK 5.7L
vrsoft is offline
cherokee , clean , hose , throttle body , tps
