To those of you with typical 4.0L valvetrain noise: - JeepForum.com
post #1 of 18 Old 04-14-2011, 07:44 PM Thread Starter
jeepkid03
Winning
jeepkid03's Avatar
The 4.0 is known as a reliable but noisy engine. Every 4.0 I've owned has had some kind of tick to it, some being louder then others. I've tried synthetic, conventional, 5w30, 10w30, 5w40, 10w40 and some of those mixed with Marvel Mystery Oil without much luck. The Marvel Mystery made the biggest difference out of the above, but still not much.
Over on the Bob Is The Oil Guy Forums I got into a discussion about 4.0 valvetrain noise. A member of the forum suggested I substitute about 1/2 quart of 5w20 synthetic with whatever oil I was running. I filled the Jeep with 5.5 quarts of Valvoline MaxLife 10w40 and 1/2 quart Pennzoil Platinum 5w20 synthetic. The oil pressure is perfect and the jeep sounds much quieter. The valvetrain noise is half of what it was before.
The belief is that the smaller molecules of the 5w20 better lubricate the hydraulic lifters, similar to what the Marvel Mystery did which is why that slightly lessened the noise.
Just figured I'd suggest this to anyone interested.
-Josh
My 0331 Head Swap How-To Thread:
Build Thread:
jeepkid03 is offline
post #2 of 18 Old 04-14-2011, 08:25 PM
djb383
Lifters are down low in the side of the block. Valve train is up high on top. Where is the noise?
djb383 is offline
post #3 of 18 Old 04-14-2011, 08:49 PM
BeepBeepGoJeep
1994 XJ Cherokee
Interesting...i never really tried to cover the sound up, im so used to it i know its just normal, but thats something i might have to try.
[]IIIII[]
BeepBeepGoJeep is offline
post #4 of 18 Old 04-14-2011, 08:57 PM Thread Starter
jeepkid03
Winning
jeepkid03's Avatar
Both can have noise. Mine has some lifter noise and valvetrain noise. The 5w20 helped with both. I can hardly hear the lifters and the valvetrain is quieter. This was verified with a mechanics stethoscope.
When I was first told about this I kinda laughed. 5w20 is for Hondas, in fact its what my mom's '05 Civic is spec'd for. It does work though to my surprise. Same NAPA Gold 1085 oil filter with every change for those who are wondering.
-Josh
Build Thread:
post #5 of 18 Old 04-14-2011, 09:19 PM
AZ Jeff
2014 JK Wrangler
Most 4.0 noise that is thought to be valve train noise is probably actually piston slap. The 4.0 engine pistons have short skirts and are prone to this.
The only 4.0 engines with valve train noise are those that have suffered from inadequate oil changes (and thus sludgey) or those with true mechanical wear issues due to age.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #6 of 18 Old 04-14-2011, 11:52 PM
sbxj
sbxj's Avatar
I've always used Synthetics in my Jeeps but the engine is still noisier than any other vehicle I've owned.
Quieting the engine will only make all the other extraneous Jeep sounds more noticeable...LOL
Jeeps are noisy...Live with it
'01 XJ 2DR Sport
'99 WJ Laredo, 4.0L with HID Retrofit
sbxj is offline
post #7 of 18 Old 04-15-2011, 12:01 AM
lb1047
1998 FSJ Cherokee
Jerk in the transmission
I have a 1998 Jeep Grand Cherokee Larado w/ 6 cy engine. I have noticed over the full 4-5 years that I have owned it that there is a bit of a jump when the tramsmission initially shifts. It has never changed and has never gotten worse. Can anyone tell me what my problem really is?? lb1047
lb1047 is offline
post #8 of 18 Old 04-15-2011, 10:21 AM Thread Starter
jeepkid03
Winning
jeepkid03's Avatar
Kinda missing the point... I said that I've used synthetics. I've used synthetic 5w30, 10w30, 5w40, etc. The little bit of 5w20 synthetic mixed with the MaxLife seems to help. For what its worth my jeep was louder with only synthetic in the crankcase.
AZJeff:
Piston slap is usually most noticeable on startup, when the engine warms up the heat causes them to expand and get quieter. My noise seemed more noticeable once the engine warmed up. Piston slap is more likely on '91-'95 4.0L's. In '96+ they changed to aluminum pistons. This didn't completely eliminate the issue, but helped.
I'm only suggesting this since it worked for me and others. Obviously every jeep is different and this won't eliminate all noise from the motor. This is just a suggestion.
-Josh
Build Thread:
post #9 of 18 Old 04-15-2011, 10:58 AM
Millermagic
Mine is pretty quiet as far as noises go. I do have an exhaust leak that's a bit loud.
I run synthetic.
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline
post #10 of 18 Old 04-15-2011, 11:32 AM
440_Magnum
They always had aluminum pistons... nobody has used anything for pistons except aluminum since the 1940s. What they did in the later 4.0 years was use hypereutectic (high-silicon) pistons with coated skirts instead of bare skirts, which allows a tighter fit and then the coating (PTFE -based) "wears to fit" without scuffing the cylinder walls.
As for the quieting effect of 5w20... I don't really buy it as explained. Mixing a 5w20 oil with a thicker oil results in an oil that, overall, is pretty much like a 10w30. It won't be any quieter (or louder) than straight 10w30. The thin oil doesn't somehow have "smaller molecules," it just has a different thickness, which isn't necessarily related to molecule size but can be related to things like viscosity index improvers. Maybe your engine just "likes" a thinner oil overall, have you tried something like one of the light 30-grades, say Mobil 1 0w30AFE?
For what its worth, I find both of my 4.0s to be plenty quiet on Rotella T6 5w40, but then they are later models (1999 and 2001) which have the coated pistons, main bearing girdle, and other things that the early 4.0 didn't have. I have never thought the 4.0 is inherently any louder than any other engine- it just doesn't have any added sound deadening like multi-layered composite valve covers and oil pans, which other modern engines have and which do a very good job of keeping the engine noise contained inside the engine.
2011 Grand Cherokee Laredo 4x2, 3.6 Pentastar
1999 Cherokee 2door 4x4 5-speed (daughter's)
Two big-block Mopars, Challenger SRT8, and a Ram 1500
2001 Cherokee Sport automatic 4x2 (sold)
440_Magnum is offline
post #11 of 18 Old 04-15-2011, 11:55 AM Thread Starter
jeepkid03
Winning
jeepkid03's Avatar
Thanks for explaining the pistons. I went back and check my sources and you are correct. I've used Rotella T 5w40 and didn't notice much of a difference. I thought the same thing about the 5w20 and 10w40 basically making a 10w30. However, the 10w30 I've used seems louder.
-Josh
Build Thread:
post #12 of 18 Old 04-15-2011, 01:16 PM
Millermagic
Instead of mixing a quart of light synthetic oil with regular dino oil, why not go for a 5w oil ... wouldn't that be just as "thin" at startup and lubricate better and then once the vehicle warms up turn into a "thicker" 40w oil?
post #13 of 18 Old 04-15-2011, 02:00 PM
escapeartist
I just replaced all my lifters due to one being flat. I "broke in" the new lifters using 10w-30 and the thing was as quiet as can be sitting idling at operating temp and through out the break in. I dropped the oil and went to a synthetic 10w-30 for daily use after the break in and it clatters like crazy. Go figure
escapeartist is offline
post #14 of 18 Old 04-15-2011, 10:58 PM
fourlow
1994 XJ Cherokee
Are you talking about the Mercedes sound? You know how the old diesel ones used to sound?
Current setup:
94 Xj 110,000 miles
Rustys Air Tube
JeepersandCreepers Bored out TB
GDI 3 core radiator
Flowkooler Water Pump
Suspension:
RE 3.5" (actual about 4 inches) 6030 SUPER-FLEX, RE1600 Adjustable Track Bar
Wheels/Tires:
Rock Crawler 152 Series, 3.75 Backspacing
31inch BFG MT's
fourlow is offline
post #15 of 18 Old 02-06-2013, 06:22 PM
Jeepeiro_fl_usa
I have piston skirt ( 2 pieces at oil pan ) # 5 and do you think i can just replace it or get 6 new pistons and bearings,lifters.Thank you.
Jeepeiro_fl_usa is offline
valvetrain noise related to synthetic? jeepkid03 XJ Cherokee Technical Forum 8 03-29-2010 05:44 PM
Question about 4.0 valvetrain charger_340 XJ Cherokee Technical Forum 3 11-28-2008 10:48 PM
valvetrain help!?!?!?!?! memphisxj XJ Cherokee Technical Forum 4 05-20-2008 05:30 PM
valvetrain question for 4.0 I6 joeksjeep XJ Cherokee Technical Forum 4 07-18-2007 05:40 PM
Valvetrain noise cmotsvt XJ Cherokee Technical Forum 7 02-27-2005 09:40 PM
