thinking about RE6025 3.5" over Rusty's 3" w/springs - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > thinking about RE6025 3.5" over Rusty's 3" w/springs
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME
Unread 06-20-2005, 08:17 AM   #1
mh89xj
but the RE doesn't come with shocks. So what do I need to add to the RE kit? I only want to order once. Add shocks, adjustable trac bar, and TC lowering kit. do I need to add any Shackles? thanks for the help
89 XJ Laredo
222,000k
4-Speed Automatic AW4 Transmission
Dana M30 Front Axle Dana M35 Rear Axle
3.55 Axle Ratio
BDS 3" lift w/ 31x10.50 Pro Comp MT's
mh89xj is offline   Reply With Quote
Unread 06-20-2005, 08:26 AM   #2
GottaBeJeep
No shackles, but I would recommend some 3/4" front spacers if you are getting the RE 3.5" kit with full leaf packs. Also, some longer brakelines. I can't remember if the RE 3.5" kit comes with longer lines, but if not, you will need some. Go to O'Reilly's and get some Wagner 1994 YJ Wrangler non ABS front and rear brakelines. Rear line should run about $12-15 and the fronts around $15-18 each. This kit will sit you about 5" rear and 4.5" front when first installed, so do not skip the brakelines. For the adjustable trackbar, I highly recommend the JKS over the RE1600. The JKS is a lot more expensive, but it will last you a lot longer and is twice the beef. The RE1600 trackbar is just garbage.
Rock Lizard Fabrications
...Off Road Armor that's "Tough as Scales"
GottaBeJeep is offline   Reply With Quote
Unread 06-20-2005, 09:19 AM   #3
mh89xj
thanks for the response
where can i find 3/4" front spacers and how much do they cost? I forgot about the break lines. Can i get them at advance or autozone? i don't have an Orielly's around here. Thank for the warning about the RE trac bar.
I found some 3/4" poly spacers on rustys site, would these work ok?
89 XJ Laredo
222,000k
3.55 Axle Ratio
