Are these control arm bushings bad? - JeepForum.com
post #1 of 8 Old 06-27-2013, 03:15 AM Thread Starter
Dcoy
I'm trying to diagnose a crazy 50-55mph wobble in my newly lifted Cherokee. The only part that I can find any abnormal play ( I think ) in are these upper control arm bushings. Just not sure if are truly are bad or not..... take a look and let me know, Thank
https://www.youtube.com/watch?v=iBYY_iqoQEg
Dcoy is offline
post #2 of 8 Old 06-27-2013, 07:12 AM
RLE
RLE's Avatar
Great job on the video. IMHO that looks like a lot of play in the upper bushings. I had very bad death wobble at about that speed, too, and it never went away until I replaced the upper bushings. They are more difficult to change which is why they tend to be neglected. While you're at it, replace the lower ones.
You can replace them with rubber or poly ones. Poly ones are stiffer at first but compress over time and do not last as long as rubber. I replaced mine with Moog poly last time and have been happy with the result.
RLE is online now
post #3 of 8 Old 06-27-2013, 08:02 AM
whitexj98
You need to do a front end inspection. With the vehicle on the ground have somone turn the wheel back and forth while you look at everything in the front. There should be no slop, track bars are the number one cause for DW, but not always...
98 XJ lifted/Locked/Geared
My Build: http://www.jeepforum.com/forum/f177/my-98-build-1253511/
whitexj98 is offline
post #4 of 8 Old 06-27-2013, 08:38 AM Thread Starter
Dcoy
I have replaced the track bar already and a tie rod end. Everything else under there is solid. Thanks.
Dcoy is offline
post #5 of 8 Old 06-27-2013, 08:40 AM Thread Starter
Dcoy
Thanks, nothing else would i rather be doing this weekend then working on my jeep!
QUOTE=RLE;15612998]Great job on the video. IMHO that looks like a lot of play in the upper bushings. I had very bad death wobble at about that speed, too, and it never went away until I replaced the upper bushings. They are more difficult to change which is why they tend to be neglected. While you're at it, replace the lower ones.
You can replace them with rubber or poly ones. Poly ones are stiffer at first but compress over time and do not last as long as rubber. I replaced mine with Moog poly last time and have been happy with the result.[/QUOTE]
Dcoy is offline
post #6 of 8 Old 06-27-2013, 08:48 AM
whitexj98
Its not uncommon for the track bar bolt to be wallered out either... have you inspected like i suggested? Just pushing and pulling on componets wont show all slop.
The upper bushings do look to have some excessive slop, wont hurt to replace them. I would only put moog rubbers in. Replacing is really pretty easy. Use a drilll bit to make multiple holes in the rubber then you can take a hammer and chissel and collapse the sleve and drive it out. The passenger can be installed by tapping it in, but the driver side doesnt have much room for swinging a hammer so a ball joint press tool works pretty good to install them.
post #7 of 8 Old 06-27-2013, 11:34 AM Thread Starter
Dcoy
Had the wife do it before, thats how I found the bad track bar, but it wouldn't hurt to do it again. Thanks.
Dcoy is offline
post #8 of 8 Old 06-27-2013, 03:21 PM Thread Starter
Dcoy
wow man, just had the wife turn the wheel and my axle is for sure moving around under there. The axle side of my new track bar is moving a good bit, looks like the bushing is bad because the bolt isn't moving so the mounting hole isn't oval. upper control arms seam to have some play, ordered them today.
Dcoy is offline
