Thermostat without air hole - Page 2 - JeepForum.com
post #16 of 26 Old 06-02-2011, 08:40 PM
willobegolfer
Be sure to flush the heater core while your at it. You'll get a lot of gunk out of it too. Just take the hoses off the thermostat and alternate the water hose between the 2 hoses flushing both ways. Don't use a spray nozzle though. The high pressure could put a hole in the heater core. Just put the water hose up to the hoses and let it flush. I kept having issues with high temp. I did everything. Replaced hoses, thermostat several times, water pump which the fins were corroded off, and a new radiator, and it was still running warmer than need be. Flushed the heater core since it was also in the flow of the system and it started working at normal temps. It was actually blocking the flow of fluid from circulating. I would also say go ahead and replace the pump. My jeep is a 2000 and there were no fins left to circulate the fluid, and it's anly around $35. Hope this helps.
willobegolfer is offline
post #17 of 26 Old 06-02-2011, 09:57 PM Thread Starter
jdc48160
I think I've decided how we're gonna attack this thing.
New Stant SuperStat, new radiator cap, new water pump, new radiator.
Gonna flush all the junk out with water and a chemical flush before installing the new parts.
jdc48160 is offline
post #18 of 26 Old 06-02-2011, 10:24 PM
Carves
Originally Posted by 93gc40 View Post
......... Are the fans working corectly? ........
Dont forget the 93gc40 comment while your throwing some money at it.
A good radiator provides cooled liquid for a good waterpump to shunt around .... but a good fanclutch makes sure the radiator is cooling properly
The fanclutch spin test is only indicative and I agree with what djb383 said ... If you dont the history of the current one ... Replace it.
Carves is offline
post #19 of 26 Old 06-02-2011, 10:25 PM Thread Starter
jdc48160
Almost forgot about that! Fan clutch too while I'll have it all torn apart. Duh.
jdc48160 is offline
post #20 of 26 Old 06-05-2011, 06:01 PM Thread Starter
jdc48160
Well, mere days before tackling the issues with the Jeep, it had enough today and started blowing steam out from under the hood, luckily, just as my girl was pulling it into her driveway.
So, tomorrow, it goes to the pros at a local shop I've used before.
I'm gonna leave this one to the pros.
Means I can move on to the next thing with the Jeep. New shocks.
jdc48160 is offline
post #21 of 26 Old 06-05-2011, 10:46 PM
richyrich514
richyrich514 is offline
post #22 of 26 Old 06-06-2011, 06:54 PM Thread Starter
jdc48160
Turns out it was the water pump. It took a ****. Wasn't leaking, but, the old nasty coolant that had been in there for who knows how long, had corroded the fins off the impeller, so it wasn't hardly pushing coolant thru the system.
New water pump is going in today, as well as another new thermostat since it did overheat, and a new radiator cap to maintain the proper pressure in the system.
jdc48160 is offline
post #23 of 26 Old 06-06-2011, 07:51 PM
djb383
Originally Posted by jdc48160 View Post
........the old nasty coolant that had been in there for who knows how long..........
Time for a new radiator maybe to go with that new pump?
djb383 is offline
post #24 of 26 Old 06-06-2011, 07:57 PM Thread Starter
jdc48160
I'm thinking so.
Electric fan isn't working either. Relay is probably bad.
jdc48160 is offline
post #25 of 26 Old 06-06-2011, 09:27 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Alot of that rusty crap from the water pump impeller is probably clogging the radiator.
cruiser54 is offline
post #26 of 26 Old 06-06-2011, 09:54 PM Thread Starter
jdc48160
Its next.
Running WAY better already. Staying around 210 or even slightly below now.
jdc48160 is offline
drill bleed hole in Thermostat? cubsin2079 XJ Cherokee Technical Forum 11 04-18-2011 10:09 AM
Will a new thermostat. badlands1 XJ Cherokee Technical Forum 3 02-21-2009 05:17 AM
Thermostat lonecountryboy XJ Cherokee Technical Forum 2 04-22-2008 06:22 PM
How, where and what size air hole to drill in an aftermarket thermostat?? L20KEV XJ Cherokee Technical Forum 4 05-11-2007 12:07 PM
Thermostat Bleeder Hole - WTF xjRalfy XJ Cherokee Technical Forum 12 06-17-2006 10:26 PM
