Thermostat Temperature - JeepForum.com
post #1 of 4 Old 05-30-2011, 08:47 PM Thread Starter
CRunning1
What Temperature should my thermostat be running at? It's running at 210 degrees, is that normal?
CRunning1 is offline
post #2 of 4 Old 05-30-2011, 08:52 PM
sargergp
Yes that's the normal temp for these engines.
sargergp is offline
post #3 of 4 Old 05-30-2011, 09:26 PM
BrunoS
210'F is the stock operating temp. All is well with your motor.
Do be aware that if the temp creeps up at a hot idle as the weather gets warmer, you may have a worn out fan clutch. Typical lifespan is 5 years or so, in this case, the temp will sit above 210'F with the e-fan cycling in and out with no noticeable temp drop...first suspect is not your thermostat but your $35 fan clutch.
Newly Painted! Emerald Green '96 XJ 4x4 4.0 HO 5-spd
3" Lift + 31" Tires / D35 TracLok / NP231
Drilled out Stock Airbox / Gauge Cluster Upgrade
Magnaflow Muffler / High-flo Cat / MSD Coil
BrunoS is offline
post #4 of 4 Old 05-31-2011, 05:08 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
The 4.0 comes from the factory with the 195 degree thermostat. This is the correct thermostat for most stock 4.0 applications.
The engine coolant temperature (which is what you're reading on your dash) is usually between 200-210.
Just because you have a 195 degree thermostat doesn't mean that the engine will run at 195. The thermostat does NOT control the maximum operating temperature of the engine, rather it is the approximate temperature where the thermostat "opens".
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is online now
4.0 operating temperature whuffy XJ Cherokee Technical Forum 21 11-27-2010 08:35 AM
Help Choosing The Correct Thermostat Temperature GFoster XJ Cherokee Technical Forum 6 11-22-2009 09:39 PM
Temperature is at 187? lilseth0014 XJ Cherokee Technical Forum 3 02-25-2009 05:21 PM
Temperature Problem 88XJ_WI XJ Cherokee Technical Forum 12 11-18-2006 11:33 AM
Lower temperature thermostat? 4x4 XJ XJ Cherokee Technical Forum 8 01-17-2003 06:39 AM
