thermostat housing gasket - JeepForum.com
post #1 of 9 Old 01-05-2011, 03:39 PM Thread Starter
Willy36
1990 XJ Cherokee
For some reason, my Jeep has a chronic issue of very slowly leaking out of the thermostat housing no matter how I try to seal it. It's only steam, so it's a very tiny gap, but having to top it off every couple weeks is getting old as hell so I'm going to fix it for good this time. So the questions are:
1. What RTV should I use?
2. Should I put RTV on both sides of the gasket or just the non-sticky side?
3. How thick should I make the RTV?
4. I already meticulously took a razor to both surfaces, but should I hit it with Brake Cleaner too? I would just do it, but I already had it torn apart by the time I realized I was out, so I'd have to make a 10 mile trip into town in a Saturn to get more
Willy36 is offline
post #2 of 9 Old 01-05-2011, 03:44 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Any RTV should work, but they make High Temp RTV. Clean the surfaces as clean as possible without damaging the metal. Apply a thin layer of RTV to both sides of the gasket, the housing, and the block. Let it dry for 10 minutes and then put the housing on. Just snug the bolts until the TRV starts to ooze. Wait 15 minutes and bring the bolts to full tightness.
CJ7-Tim is offline
post #3 of 9 Old 01-05-2011, 04:13 PM
egodfrey
egodfrey's Avatar
Some people have more success with just the paper gasket with no rtv, to each their own
But, have you considered that maybe you have a micrsopic crack in your themostat housing that is causing it to leak, a new housing is cheap
So many people to thank here's a start to the list
Spidertrax, Yukon, rustys, warn, branik, PSC, advance adapters, Bad wheels, interco, essentially off-road. And many more
Most of all thanks too Ian Johnson and the xtreme off-road crew for all their work, and 4 wheel to heal for their part in it too.
egodfrey is offline
post #4 of 9 Old 01-05-2011, 04:22 PM
98_XJ
Autozone and Orielly Auto sell the correct RTV to use in a little "bag" hanging on a display on the counter. It is designed for coolant applications. It costs less than a dollar and you just squeeze it along. Worked perfect for my job.
1998 Jeep XJ Limited 4x4
- Rough Country Series II 3" Lift
- 31-10.50-15 Duratracs on Black Rocks
- JCR Offroad Stage 3 Front Bumper
2010 Chevy Equinox
98_XJ is offline
post #5 of 9 Old 01-05-2011, 04:27 PM
Cherokee-at-16
I have to replace mine too. RTV goes on both sides of the gasket, and the block and housing. or just one of these 2 because don't they do the same thing.
Cherokee-at-16 is offline
post #6 of 9 Old 01-05-2011, 05:24 PM
Carves
I scrape and then use a scouring pad to clean the mating surfaces.
Being old school - I use a gasket .... home made usually .... then I apply a thin smear of RTV to both sides of the gasket and let it dry off ... I usually give it an hour.
Put it all back together ... let it sit overnight ... and refill the cooling system.
If you dont have a gasket ... Just use the RTV as specified in the instructions.
If its a trail repair and you need to get going quickly before the RTV has cured properly ... Its quite possible you may need to redo it once you get home.
Used this stuff last time ... seems as good as other brands Ive used.
http://www.permatex.com/products/aut...sket_Maker.htm
Theres "how to use" in the TDS file download on the page.
Carves is offline
post #7 of 9 Old 01-05-2011, 06:10 PM Thread Starter
Willy36
1990 XJ Cherokee
This is my 3rd and they've all done it, so I feel like I'm just somehow putting it together wrong. Funny, I've helped my friend with just about everything on his 410whp car and it holds fine, but I can't get a damn thermostat housing to seal
Occurred to me earlier that I may not be allowing it to dry long enough before refilling, so I'm letting her sit for a few hours then I'll fill her up and will wait til tomorrow late morning or afternoon to drive it. I might try that Ultra Grey if the stuff I used doesn't hold.
Anyways I was running out of sunlight and heat so I just did it like CJ7-Tim said with Red Silicone RTV since I haven't tried that yet. We'll see how it turns out.
ETA: Found some MAF cleaner, so I sprayed a shop towel with that and gave the surfaces a good wiping so hopefully that helps as well.
Willy36 is offline
post #8 of 9 Old 01-05-2011, 07:03 PM
KF4SQB
1994 XJ Cherokee
I'd say a good inspection of the sealing surface on the front of the head is in order. I can't see the problems you're describing without a crack or gouge in the sealing surface. Or perhaps its actually the radiator hose or heater hose leaking, and it just looks like its coming from the thermostat housing? You may also want to check the steel heater tube for a pinhole. It could be spraying steam onto the thermostat housing in such a way it looks like the housing is leaking.
4-wheeling: because football, basketball, baseball, and golf only require one ball!
Confidence: The feeling you get just before you fully understand the situation!
KF4SQB is offline
post #9 of 9 Old 01-05-2011, 07:46 PM
XJohnnyC
XJohnnyC's Avatar
I use a gasket with a very thin layer of blue RTV on both sides. The torque value on the two bolts is not very high, so it is very easy to over-torque these bolts. Thus, it is very easy to crack the housing, as someone else mentioned
XJohnnyC is offline
gasket , leaking coolant , RTV , thermostat housing , xj
thermostat housing gasket mikethefisher XJ Cherokee Technical Forum 6 11-30-2010 06:40 PM
thermostat housing jeeptorino68 XJ Cherokee Technical Forum 6 06-07-2010 05:24 PM
96 XJ-Warped Thermostat Housing? Replaced gasket twice, still leaking. kmh1596 XJ Cherokee Technical Forum 17 03-24-2009 09:19 PM
Thermostat housing ? XJAce XJ Cherokee Technical Forum 3 12-10-2007 06:31 PM
Thermostat housing Blake XJ Cherokee Technical Forum 2 05-10-2005 11:57 PM
