Thermostat caused me to have a leak? - JeepForum.com
post #1 of 4 Old 07-10-2006, 08:57 PM Thread Starter
CherokeeClassic
So today I left my jeep running (98 cherokee classic) for about 10 mins (100 degrees outside) with the air on. I came outside and my return line to the water pump was leaking at the clamp. Possible the thermostat wasn't working and causing back pressure and making the hose and clamp leak? So i went and got a 190 thermostat and installed it. Refilled everything and my temp gauge is really stable now and no leaks.... anyone else seen anything like this? thanks
stu
CherokeeClassic is offline
post #2 of 4 Old 07-10-2006, 10:21 PM
Pizza Man!
I saw my Grampa make a new gasket for the t-stat housing on his Bronco II, using a peice of asbestos, a utility knife and and a ball-peen hammer on the side of the road once, when I was a kid.
99 XJ Sport, auto, np231s, sittin' stock K&N drop-in filter, ventshades.
And Yes I run pies in my XJ, and I don't know how the guy with the integra gets up those washed-out farm driveways.
As always, my signature is a work in progress
Pizza Man! is offline
post #3 of 4 Old 07-11-2006, 06:50 AM
Thayer
stu
The hose and clamp sees that "back pressure" everytime you start your car when it's cold. Maybe the clamp was just loose or the hose wasn't seated well...?
1997 Cherokee Sport NAXJA #1255
RK 4.5" LA Kit
Thayer is offline
post #4 of 4 Old 07-11-2006, 06:57 AM
xjmatt
I'd be more weary of the hose and clamp than the T-stat. I've seen the return hose wear through above the clamp because the hose is in such a tight position and rubs against the head with the normal engine vibration. I'd pull that upper hose and take a good look at it especially around where the clamp seats.
95 XJ sport 4.0L geared 4.10
AX-15 with an NP231
JB SYE with a High Angle CV driveshaft
RE 4.5" lift 33x12.5x15 ProComp AT's on AR 767's
JKS QD's RE HD trac bar & frame mount
Disc's on all 4 corners, stopping fast is so nice
Rusty's Airtube with K&N and Hella 500's on an ARB Bull Bar
xjmatt is offline
Rusty's caused my DW..... fla_cracker XJ Cherokee Technical Forum 16 07-31-2009 11:18 AM
Gas prices caused you to drive your XJ less? Dannyboy18 XJ/MJ Cherokee Non-Technical Forum 117 12-11-2008 04:04 PM
A/C Compressor caused engine leak? jmp-n-run XJ Cherokee Technical Forum 2 06-20-2008 10:26 PM
what caused this? doyle68 XJ Cherokee Technical Forum 13 05-16-2008 06:58 PM
Is this caused by a bad O2 sensor? firehawk XJ Cherokee Technical Forum 8 11-29-2006 02:45 PM
