thermal fuse, blower motor and fan controller woes - JeepForum.com
post #1 of 7 Old 07-02-2010, 05:28 PM Thread Starter
Zamboni0neXJ
I have replaced everything mentioned above and some twice. Something is making the load on the thermal resistor enough to make it fail and go into the high only setting. On top of that, the controller, under heavy load (ac mainly) shuts off and on every 4 seconds. Blower motor is brand new, thermal resistor was brand new. Replace the controller unit and the plug on the drivers side. Plug was melted and damaged. Haven't taken it apart to see if it got nuked yet.
Please send any and all ideas my way. I am brain shot now.
Zamboni0neXJ is offline
post #2 of 7 Old 07-02-2010, 09:19 PM
BrunoS
sounds like case of high voltage under the hood.
1) what year xj is this?
2) what is the engine running battery voltage?
3) common failure part in 96 and older xj was the blower speed switch, which got dirty/hot spots/failed at the wiring harness connector (would smell like melted plastic at the dash when the blower was on hi speed).
4) if that speed switch connector is fried (like mine was) then you may have a short at that point which is causing your problems;
5) or your alternator is overcharging (like 16 volts or more) and this is yet another thread.
Newly Painted! Emerald Green '96 XJ 4x4 4.0 HO 5-spd
3" Lift + 31" Tires / D35 TracLok / NP231
Drilled out Stock Airbox / Gauge Cluster Upgrade
Magnaflow Muffler / High-flo Cat / MSD Coil
BrunoS is offline
post #3 of 7 Old 07-03-2010, 09:19 AM Thread Starter
Zamboni0neXJ
I forgot to fill out my profile sorry. Its a 99 sport.
Voltage has been normal. I did smell what seemed to be an odd smell after replacing the controller. I am leaning towards it being a bad controller, but never thought about a short. Thanks, I will begin my painful search.
post #4 of 7 Old 07-03-2010, 09:42 AM
myriad360
2008 WJ
Check the fuse values in your fuse box if this circuit is included, something is running hotter than it should. X 2 above, if the fuses are correct, you probably have a short somewhere. Ammeter?
Great XJ Troubleshooting/mod sites list:
2001 Jeep Cherokee 4.0 L Limited, White. Bought in Grangeville, ID 06/11/08. Stock everything.
1998 Jeep Wrangle 4.0 L, Green. Bought in Nampa, ID 02/21/09
1988 Jeep Cherokee 4.0 L, White. Bought in Vancouver, WA in 2003. 1st Jeep, White. Bought with 3" lift, added Pacesetter header and 40 series Flowmaster
myriad360 is offline
post #5 of 7 Old 07-04-2010, 07:53 AM Thread Starter
Zamboni0neXJ
I think I tracked the short down. It was in the blower motor itself. Resistor was still good. Swapped out blower motor and no problems so far.
post #6 of 7 Old 07-04-2010, 01:31 PM
myriad360
2008 WJ
Didn't you already replace the blower motor?
post #7 of 7 Old 07-04-2010, 06:27 PM
Whackmaster
I was having the same problem with my 99...After replacing the blower motor twice it worked fine for about 3 months but it is back to the old way...I have given up............
I LOVE THIS STUFF
Whackmaster is offline
need help, blower motor or fuse? MxAjN XJ Cherokee Technical Forum 12 02-20-2009 05:02 PM
'92 Engine Controller Fuse rstarch345 XJ Cherokee Technical Forum 1 05-31-2007 08:36 AM
Blower motor maxi fuse.... bigkiang XJ Cherokee Technical Forum 1 11-04-2005 08:05 PM
HELP! Blower motor, wiper motor dead surferri07 XJ Cherokee Technical Forum 0 10-26-2004 07:13 AM
Thermal Fuse location on 98 XJ? cmassey_2001 XJ Cherokee Technical Forum 18 07-13-2004 11:19 PM
