Is there something wrong with my leafs - JeepForum.com
post #1 of 13 Old 07-29-2013, 07:26 AM Thread Starter
99_XJ_
I bought my jeep a few months ago since then I put in a spacer shackle budget booster and my back end seems to be sitting rather low. I looked at my leaf springs and there is almost no arch to them. Should I buy new springs? Get them re-bent?
99_XJ_ is offline
post #2 of 13 Old 07-29-2013, 08:16 AM
DNFJ
They look worn but from the side it doesn't look that bad.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #3 of 13 Old 07-29-2013, 09:44 AM
rugsucka
The extended shackle has put extra stress on your 14 year old leafs and accelerated the sag that comes with age. Longer shackles are not a great choice for stock leaf packs - especially old ones.
You need to either replace the stock leaf packs, or rebuild what you've got into a bastard pack. If you were to grab the main leaf from another XJ, cut just the curving up part of the eye leaving as much flat leaf as possible, you could rebuild what you've got.
Other BP donor choices are Explorer, Dakota, S10, Dodge Van - any 2.5" leaf will do, but you do not want to get a thick leaf that will stiffen the ride too much.
rugsucka is offline
post #4 of 13 Old 07-29-2013, 03:15 PM Thread Starter
99_XJ_
would I be just better off getting a whole new pack?
99_XJ_ is offline
post #5 of 13 Old 07-29-2013, 09:06 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Stock leaf packs are soft, flexy and lightweight for a smoooth ride and don't deal well with the extra stresses extended shackles bring. Those leaves are worn out and lost their arch. Get some new leaf packs, but not OEM if you're looking for added lift.
***Chris***
chris87xj is online now
post #6 of 13 Old 07-30-2013, 06:43 AM
steiny93
if you want stock ride and height they replacing these with oem's is the fix
if you want to change height then you have quite a few options in regards to the packs (bastard pack / add a leaf / different now oem leaf pack)
its kinda a preference deal
steiny93 is offline
post #7 of 13 Old 07-30-2013, 06:58 AM Thread Starter
99_XJ_
I already have the shackles, I want to make the clearance in the rear a little more, every time i go wheeling the rear only hits. I just want my back end to look lifted, to me it looks stock now. I'm not too trusting with used leafs, but would i just be better off getting AAL or 2 new leaf packs.
99_XJ_ is offline
post #8 of 13 Old 07-30-2013, 04:22 PM
jserna
1987 YJ Wrangler
If you do not want to get used springs, AAL's could be a good choice. Make sure you get full length AAL's, not the short ones.
jserna is offline
post #9 of 13 Old 07-30-2013, 07:37 PM
Mywrangler94
I am going through the same quandry...i've gotten in touch with Morris 4X4, since on their site, they list 9 different springs with 9 different arches. Anywhere from 5 1/8 arch to 7" of arch. All of them have 4 leafs. Dont want to ride like I'm on a sled...my YJ does that, BUT, I don't want to feel like im on a marshmallow either. So when I hear from them, I will let anyone who is interested know. By the way, the jeep is a 98 with 85,000 miles, no rust, everything works, and it was free...lol. so I think I'll keep it and get rid of the TJ I have..Will keep you all posted if your interested....
Mywrangler94 is offline
post #10 of 13 Old 07-30-2013, 08:15 PM
jserna
1987 YJ Wrangler
I replaced the oe springs with rancho packs. They work great, the ride more firm but not harsh. If i remember correctly, they gave about 2in of lift. They were not expensive either.
jserna is offline
post #11 of 13 Old 07-30-2013, 08:32 PM Thread Starter
99_XJ_
Now would that be 2in onto of my 2in shackles, or would it be 2in including my shackles...
I'm new to the Jeep world haha, i used to be in the vw community (big mistake I know) so Im just asking a lot of questions, even though it sounds like i don't know a damn thing.
99_XJ_ is offline
post #12 of 13 Old 07-31-2013, 12:45 AM
sAe23
1995 XJ Cherokee
Don't add AAL's to your saggy OEM leaf packs.
Look up "shackle relocation brackets". Depending on the length of your shackles, and the angle you install them at, you'll add about 2" to what ever height you are at.
If that's all the lift you want, then get new OEM springs and spacers for the front coils to level it out.
If you want more lift, just keep in mind the 2" the brackets add.
There is also a way to net less lift by using one brand of bracket that requires you to cut out the factory shackle pockets.
sAe23 is offline
post #13 of 13 Old 07-31-2013, 07:14 AM
jserna
1987 YJ Wrangler
The rancho springs gave the 2in of lift minus the longer shackle. I later installed the longer shackle when I installed a 4in teraflex lift.
jserna is offline
cherokee , jeep , leaf springs , xj
