is there a fuse for my o2 sensor - JeepForum.com
post #1 of 7 Old 05-31-2009, 09:54 PM Thread Starter
jayashjeep
somone said i had a fuse for my o2 sensor do i its testing a bad o2 sensor and i just replaced it any hints thanks for any comments.
If mud aint flying you aint trying
jayashjeep is offline
post #2 of 7 Old 05-31-2009, 11:50 PM
XJohnnyC
XJohnnyC's Avatar
There is no fuse for the O2 sensor.
XJohnnyC is offline
post #3 of 7 Old 06-01-2009, 12:18 AM
bdodge
1997 XJ Cherokee
Did you reset the code after you installed the new 02?
97' Cherokee sport 2 DR / 4.0 Power Tech, 5 spd MAN, Command trac / Dana M30/181MM front axel, Corporate 8.25 rear axel / 6.5" Bastard lift, 31X10.5 Daytona futura's on Cragar 15X8 soft 8's, Logans Metals Front winch bumper, Flowmaster super 44, Magnoflow high flow cat
bdodge is offline
post #4 of 7 Old 06-01-2009, 09:01 AM
Ed Rico
1997 XJ Cherokee
There is a fuse in the underhood PDC that supplies the heater circuits for both front and rear O2 sensors in parallel. If the fuse is out, it can affect the ability to get up to and maintain operating temp for the sensors, which can cause problems with staying in closed loop.
-Ed Rico
Ed Rico is offline
post #5 of 7 Old 06-01-2009, 09:04 AM Thread Starter
jayashjeep
i did not reset the code it turnede off its self after i replaced it then came back on
im going to chreck the pdc fuse rate now ill let you know what happen thanks alot everyone im really getting tired of my check engine light on.
post #6 of 7 Old 06-01-2009, 09:14 AM Thread Starter
jayashjeep
where is the pdc fuse located cause i dont see one under the hood? help please
post #7 of 7 Old 06-01-2009, 10:42 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
The PDC is the Power Distribution Center. It is the black plastic box next to the battery. The fuses are not labeled, just check them all. I am pretty sure that there is no O2 sensor fuse in the fuse box in the passenger foot well area.
Check your Owners Manual or Factory Service Manual for more info. If you don't have an OM or an FSM, you should get one, try eBay or the Junkyard.
CJ7-Tim is offline
fuse block melted & fuse didnt blow 92BEATER XJ Cherokee Technical Forum 4 08-23-2011 08:09 AM
Check Engine Light - 02 sensor voltage too high bank 1 sensor 2 billbarr100 XJ Cherokee Technical Forum 15 05-19-2010 03:04 PM
Need wiring diagram for '98 passenger fuse box, fuse #11 johnsoninc86 XJ Cherokee Technical Forum 2 11-09-2009 06:01 PM
my fuse for the o2 sensor jayashjeep XJ Cherokee Technical Forum 0 06-01-2009 09:27 AM
TPS sensor, Coolant temp sensor, and 02 Sensor fail kadetklapp XJ Cherokee Technical Forum 2 09-07-2008 01:48 PM
