Thats a 1st.. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Thats a 1st..
Savvy Aluminum Gas Tank SkidIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNEW JK WRANGLER GRAB BARS NOW at ROCKRIDGE4WD
Unread 02-15-2015, 07:11 AM   #1
2tall2slow
Thats a 1st..
New battery. Lately upon cranking, volt gage reads low. Occasionally after crank, gage drops from 14v to 9v(red zone) and check gage light appears. Earlier while on highway gage dropped suddenly to 9v and check gage light came on while driving. After getting parked shut engine off and tried cranking, fired right up no problem. Getting a battery reading of 12v. When cranked its about 13v. Ideas? Puzzled. Btw its cold here.
2tall2slow is offline   Reply With Quote Quick reply to this message
Unread 02-15-2015, 07:27 AM   #2
rdnkjeeper
What's your battery voltage when the engine is running? It should be around 14 volts. If it isn't, you might have an alternator problem. After re-reading your post, I would say that your alternator is starting to have problems.
It's a Jeep thing and Yes I do Understand!!
rdnkjeeper is offline   Reply With Quote Quick reply to this message
Unread 02-15-2015, 07:32 AM   #3
2tall2slow
Its showing 13v while running. Seems a bit low. Alternator eh? I shall check it in a few. Thanks
Unread 02-15-2015, 08:33 AM   #4
2tall2slow
Auto parts guy hooked it up and confirmed battery is low, suggesting that alternator is going bad. Once i cranked and he ran furthur test he was suprised that alternator passed test. Instinct told me to buy alternater anyway, just hope it lasts until i get home to change it out. Sub zero wind chills out here.
Unread 02-16-2015, 01:18 AM   #5
1stockjeep
1993 XJ Cherokee
The testing machines don't really give accurate info, I worked at one for a few years and unless it's totally obvious it's bad they usually pass
1stockjeep is offline   Reply With Quote Quick reply to this message
Unread 02-16-2015, 05:02 AM   #6
2tall2slow
Replaced alternater last night. Belt looked good. Havent had the check gage light lately, but this morning voltage gage wanted to dip as low as 12v after trying to run defrost. (Not quite in the red zone) hopefully issue is resolved. Any ideas on what else could be a culprit? Factory everything in this jeep, no rigged wiring anywhere.
Unread 02-16-2015, 06:57 AM   #7
Jeepkruzer
Before you do any more tests, make sure the battery is fully charged with a battery charger. An alternator really isn't meant to be a battery charger, they are meant to be a battery maintainer.
Jeepkruzer is offline   Reply With Quote Quick reply to this message
Unread 02-16-2015, 07:08 AM   #8
Ferryman
It won't do any harm to check all grounds, that is engine to body, body to battery.
Wirebrush them and retighten.
Ferryman is offline   Reply With Quote Quick reply to this message
Unread 02-16-2015, 02:35 PM   #9
sAe23
1995 XJ Cherokee
^^^This!
sAe23 is offline   Reply With Quote Quick reply to this message
Unread 02-17-2015, 07:59 AM   #10
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Originally Posted by sAe23 View Post
^^^This!
Yup^^.
Originally Posted by chris87xj View Post
If you own a Renix Jeep, you'll want to check this out. >
An index to over 25 write-ups can be found in Post #1.
Cruiser's Mostly Renix Tips
My Jeep Technical Photos
http://www.cherokeeforum.com/g/album/1725214
cruiser54 is offline   Reply With Quote Quick reply to this message
Unread 03-02-2015, 06:22 AM   #11
2tall2slow
Must have been a faulty alt. Couple weeks now since replacement, have had no issues. When in doubt, go with instinct.
