Testing neutral safety switch - JeepForum.com
post #1 of 8 Old 02-01-2012, 09:44 AM Thread Starter
In_da_middle
In_da_middle is offline
post #2 of 8 Old 02-01-2012, 02:31 PM
Its_A_JeepThing
are you wanting to know how to test or???
Its A Jeep Thing- SO GET ONE!
ONLYJEEPPARTS.COM
Its_A_JeepThing is offline
post #3 of 8 Old 02-01-2012, 02:59 PM
Its_A_JeepThing
Warning: During the following checks there is a chance that the vehicle could lunge forward causing damage or injuries. Allow plenty of room around the vehicle, apply the parking brake firmly and hold down the regular brake pedal during the checks.
1. Automatic transmission equipped models have a neutral start switch which prevents the engine from starting unless the shift lever is in neutral or park.
2. Try to start the vehicle in each gear. The engine should crank only in park or neutral.
3. Make sure the steering column lock allows the key to go into the lock position only when the shift lever is in park.
4. The ignition key should come out only in the lock position.
If you have a standard transmission just let me know and I will tell you what you must do. Your welcome
ONLYJEEPPARTS.COM
post #4 of 8 Old 02-04-2012, 01:28 AM
Mdeez415
1988 XJ Cherokee
Everything was running well with the new battery an alternator. It took alittle while to turn over sometimes so I thought a new starter was in the works in the near future, today it stopped turning over. Not dead, just not turning over. I got it towed home and took out and replaced starter. It started right up like 5 times. Then boom. Its not turning over, again. Just keeps cranking. How can this happen with a new starter? I'm really confused. It's stuck at a friends house kinda far away and I just wanna get it home. HELLLLP!!!
1988 4.0 L 5 spd Laredo
Mdeez415 is offline
post #5 of 8 Old 02-04-2012, 07:23 AM
whitexj98
You say its not turning over but is cranking???
98 XJ lifted/Locked/Geared
My Build: http://www.jeepforum.com/forum/f177/my-98-build-1253511/
whitexj98 is offline
post #6 of 8 Old 02-04-2012, 10:31 AM
Its_A_JeepThing
easy....CPS Crankshaft position sensor
ONLYJEEPPARTS.COM
post #7 of 8 Old 02-04-2012, 03:26 PM
Mdeez415
1988 XJ Cherokee
It is cranking like it wants to start, and it did start a few times after the new starter. Its seems like it "wants" to turn over, but wont. I was reading on the neutral safety switch, but dont kno.The jeep is stuck at a friends house like an hour away. bummed. what can i do or check?
Mdeez415 is offline
post #8 of 8 Old 02-04-2012, 06:17 PM
Its_A_JeepThing
Definatly sounds like the CPS, to check to see if it is the CPS you try a few things.
TO CHECK CPS:
1. Disconnect the CPS electrical connector from the main wiring harness from the rear of the intake manifold.
2. If your working on a 91 or earlier model, connect an ohmmeter across terminals a and b (marked on the connector). The meter should read 200+- 75 ohms on a hot engine.
3. If your working on a 1992 or later model, Check the resistance between the B and C terminals (marked on the connector). The meter should indicate no continuity (open).
4. If the readings are not to specification, replace the CPS.
TO REPLACE CPS:
1.Disconnect the electrical connector from the CPS.
2. Detatch the CPS by removing the two bolts on the transmission bell housing on the drivers side, which are facing the firewall. Trace the electrical connector to the sensor.
3. Installation is reverse operation.
ONLYJEEPPARTS.COM
Neutral Safety Switch Gone Bad??? zgr8t1 XJ Cherokee Technical Forum 6 09-21-2010 02:53 PM
Neutral Safety Switch 4x4forfun XJ Cherokee Technical Forum 7 05-05-2009 02:46 PM
Neutral Safety Switch nickcf XJ Cherokee Technical Forum 1 04-14-2007 01:02 PM
Neutral Safety Switch inflatus XJ Cherokee Technical Forum 2 10-04-2006 07:37 PM
neutral safety switch ?? nickwc XJ Cherokee Technical Forum 2 09-20-2004 09:59 PM
