Temperature Question - Page 2 - JeepForum.com
post #16 of 21 Old 01-23-2012, 09:41 PM
Camfam07
Originally Posted by djb383 View Post
When u say stock, do u mean original? Is the rad original?
Probably its as old as dirt im sure, I know its at least 5-6 years old guy that owned it cant remember back that far but he owned it for ten years, anyways its an old one
Camfam07 is offline
post #17 of 21 Old 01-24-2012, 06:45 AM Thread Starter
MrKevinRosales
Alright, seems like changing the thermostat is the way to go, is there a specific temperature that I should go for?
MrKevinRosales is offline
post #18 of 21 Old 01-24-2012, 07:12 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
195 is the recommended stat temperature for the "vast majority" of 4.0 applications. I buy my stats directly from Jeep; well worth the extra few bucks for a reliable stat that holds a very steady temp.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is online now
post #19 of 21 Old 01-24-2012, 07:29 AM
bobbo_xj
...and stay away from fail safe thermostats. Unless you don't mind changing out stats at least once a year.
2001 XJ Sport, 173k mi.
bobbo_xj is offline
post #20 of 21 Old 01-25-2012, 03:33 PM Thread Starter
MrKevinRosales
Alright, so I just got the new thermostat in.
Turns out that there wasn't one.
how long should until I fill the radiator back up?
post #21 of 21 Old 01-25-2012, 04:56 PM
djb383
No stat? Button 'er up and fill 'er up. Let it idle with the rad cap off, keeping the rad full of coolant. When coolant/air start to burp/flow out the top of rad, put a new rad cap on. Check coolant level in the rad, motor cold, next several days and add coolant as necessary.
djb383 is offline
heat , temperature gauge
Temperature question? normal temp? Brg0012 XJ Cherokee Technical Forum 4 03-24-2010 02:03 AM
temperature and coolant question bcameron1974 XJ Cherokee Technical Forum 2 12-22-2009 07:00 AM
question about temperature 88XJ_WI XJ Cherokee Technical Forum 10 09-01-2007 08:29 PM
Temperature Gauge question!? Vettetrax XJ Cherokee Technical Forum 6 04-15-2006 10:28 AM
Running temperature question Calpolyclimber XJ Cherokee Technical Forum 5 04-05-2004 03:21 PM
