Temperature Question - JeepForum.com
post #1 of 21 Old 01-23-2012, 06:52 AM Thread Starter
MrKevinRosales
So I've got a '96 Country and it still runs great, One thing that i have noticed though is that the temperature gauge never goes about a quarter of the way.
From what I know shouldn't the temperature gauge typically be half way across?
The Jeep was originally my dad's and he says that this started happening last time the radiator was changed, and that prior to that, the gauge had always been at the halfway point.
Is there something wrong with this?
Also my heating doesn't really work very well, could this be part of the issue?
MrKevinRosales is offline
post #2 of 21 Old 01-23-2012, 08:12 AM
GtiKyle
Thermostat could be stuck open. Was this changed at the time of the radiator? Some people think that to avoid overheating, they pull the thermostat. Makes things worse, so i'd check that first.
1998 Cherokee, 6.5" LA, D30/C8.25 4.56 locked F/R, 35" MTR's, other goodies ...
Build thread :
GtiKyle is offline
post #3 of 21 Old 01-23-2012, 04:13 PM
blackgnx
1997 XJ Cherokee
yep yep thermostat. while the engine is cold and started up feel you upper hose is it firm? if not eirther it's low on coolant or the stat is stuck open somwhat.
blackgnx is offline
post #4 of 21 Old 01-23-2012, 04:42 PM
djb383
+3.....low temp reading AND poor heater performance are most likely due to a stuck open (or missing) t-stat. FWIW, a firm hose has nothing to do with the t-stat....but rather a cooling system with no leaks and a good rad cap. Pressure should rise equally throughout the system as the coolant temp rises, regardless of t-stat being open/closed......t-stat may not even be in there but pressure should still rise 'till rad cap rating is reached.
djb383 is offline
post #5 of 21 Old 01-23-2012, 04:45 PM
Carves
I'd pull the thermostat out for a look, first up ... you'll probably find its a 160* ... or its stuck/sticking, open/partly open.
Drop a new 190 / 195 in ... make sure you have at 12qts of coolant in there ... and see how it responds.
Carves is offline
post #6 of 21 Old 01-23-2012, 05:19 PM
Camfam07
ok so I kind of have the oppisite affect here on mine, it will stay little under half way, if it idles for more than 5 minutes starts getting hotter and hotter, and then makes its way past the half way mark! im sure this isnt normal, thermo replaced about 6 months ago, doesnt have a breather hole on the thermo dont know if it matters, is there something else I can do to keep it cool? I have mostly water in the RAD could that be doing it?
Camfam07 is offline
post #7 of 21 Old 01-23-2012, 05:37 PM
Carves
actually it is fairly normal ... up to a point - as the fans should kick in and control it.
Sounds like an airflow problem ... so consider fitting a new fan clutch if you dont know how old yours is ... and make sure the electric fan is operational.
T'Stat breather hole assists with clearing air pockets ... can be useful
Water Only - in the rad is better for cooling .... Not so good for rust or in freezing conditions ... but it wont be the cause, of an overheating situation.
Carves is offline
post #8 of 21 Old 01-23-2012, 06:28 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Carves replying to a cooling system question.....
WHO WOULD HAVE THOUGHT??
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #9 of 21 Old 01-23-2012, 07:05 PM
Camfam07
Thanks I was thinking it was the Clutch fan, and im thinking of upgrading to a 2 row radiator with the electric fan? and then can I remove the fan clutch and just have the pulley on there??
Camfam07 is offline
post #10 of 21 Old 01-23-2012, 07:07 PM
Camfam07
2 electric fans actually*, I want to do the conversion and fully get the fan clutch out of the equation.
Camfam07 is offline
post #11 of 21 Old 01-23-2012, 07:36 PM
djb383
Much easier/cheaper to replace the fan clutch.
djb383 is offline
post #12 of 21 Old 01-23-2012, 07:58 PM
Camfam07
Yeah but "EASY" takes all the fun out of things, lol but I think for now most affordable and best route to go is fan clutch, I cannot think of anything else as far as cooling goes even replaced the water pump about a week ago and still getting overheating only idleing never overheats when towing a little bass tracker boat and or Road Trips. Fan Clutch and/or a high flow thermo housing is all I can think to replace now.
Camfam07 is offline
post #13 of 21 Old 01-23-2012, 08:03 PM
djb383
I'll bet after the radiator, fan clutch, water pump, t-stat and rad cap have been replaced, overheating will be a non-issue. Fan shrouds are in place, correct?
djb383 is offline
post #14 of 21 Old 01-23-2012, 08:07 PM
Camfam07
Yes shrouds are in place, havent replaced the RAD yet but thats next and if I do I will do the 2 row and just use 2-3 electric fans, to cool it.... anyways, yeah so far new water pump and thermo. but im thinking the fan clutch is stock, ill start there.
Camfam07 is offline
post #15 of 21 Old 01-23-2012, 08:24 PM
djb383
When u say stock, do u mean original? Is the rad original?
djb383 is offline
heat , temperature gauge
Temperature question? normal temp? Brg0012 XJ Cherokee Technical Forum 4 03-24-2010 02:03 AM
temperature and coolant question bcameron1974 XJ Cherokee Technical Forum 2 12-22-2009 07:00 AM
question about temperature 88XJ_WI XJ Cherokee Technical Forum 10 09-01-2007 08:29 PM
Temperature Gauge question!? Vettetrax XJ Cherokee Technical Forum 6 04-15-2006 10:28 AM
Running temperature question Calpolyclimber XJ Cherokee Technical Forum 5 04-05-2004 03:21 PM
