Temp Guage not working...not the sending unit - JeepForum.com
post #1 of 9 Old 01-27-2011, 10:17 AM Thread Starter
LandRover
LandRover's Avatar
So my temperature guage isn't working in the new XJ... I pulled the sending unit out of the old one and swapped it in...no dice. I know that unit is good becuase the guage worked fine in the old one. What else can I check? Is there a fuse for that? I assumed it had to be the sending unit.
RHD '98 XJ
RE 3.5", Bushwaker Flat Flares,
OR-Fab bumpers, PowerTrax locker,
Sliders, Goodyear Duratrac 33's
LandRover is offline
post #2 of 9 Old 01-27-2011, 01:15 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Originally Posted by LandRover View Post
..... I pulled the sending unit out of the old one and swapped it in...no dice. I know that unit is good because the gauge worked fine in the old one. .......
What old one ?
Check the wire harness and wire connector for corrosion or damage.
CJ7-Tim is offline
post #3 of 9 Old 01-27-2011, 01:21 PM Thread Starter
LandRover
LandRover's Avatar
Sorry, that was totally unclear. The "old one" is my '99 XJ that my wife drove into a tree. I'm sure the sending unit was good because the guage worked fine in that XJ. So when I put that sending unit into this one, it didn't work.
the harness and connector look great...no corrosion or issues that I can see.
RHD '98 XJ
post #4 of 9 Old 01-27-2011, 01:42 PM
CJ7-Tim
CJ7-Tim's Avatar
The sender inputs to the PCM, the PCM uses the data to run the engine and to display on the dashboard.
So the problem is either the sender, the wires, or the gauge in the instrument cluster. You could swap the 99 cluster into the new Cherokee.
CJ7-Tim is offline
post #5 of 9 Old 01-27-2011, 02:26 PM
severous01
severous01's Avatar
well, check the cluster.
severous01 is offline
post #6 of 9 Old 01-27-2011, 04:14 PM Thread Starter
LandRover
LandRover's Avatar
It's so cool having a spare everything. I highly reccomend it. I'll check the cluster next. Hate tearing the dash apart though. What a pain.
RHD '98 XJ
post #7 of 9 Old 01-27-2011, 04:39 PM
440_Magnum
The cluster really isn't bad on a 2nd-gen Cherokee. It helps to lower the tilt wheel ALL the way down.
2011 Grand Cherokee Laredo 4x2, 3.6 Pentastar
1999 Cherokee 2door 4x4 5-speed (daughter's)
Two big-block Mopars, Challenger SRT8, and a Ram 1500
2001 Cherokee Sport automatic 4x2 (sold)
440_Magnum is offline
post #8 of 9 Old 01-28-2011, 08:36 AM Thread Starter
LandRover
LandRover's Avatar
If I swap the clusters will the odometer reading stay the same, or will I see the reading for the jeep the cluster came out of? where is that info stored?
RHD '98 XJ
post #9 of 9 Old 01-30-2011, 09:30 PM Thread Starter
LandRover
LandRover's Avatar
I swapped the clusters and found out that the odometer reading is apparently stored in the cluster. I got the reading from the old jeep.. I want to swap the old motor (93k miles) into this jeep this summer, so I decided not to use that cluster...i'll swap it in when I do the motor and have an accurate reading on that motor. The temp guage did work though...
I put the original cluster back in and the temp guage magically worked on it too...loose connection apparently. Sweet.
RHD '98 XJ
Temp Sending unit? XJKyle1995 XJ Cherokee Technical Forum 9 05-28-2011 12:59 AM
Where is my temperature guage sending unit? ('98 XJ) LandRover XJ Cherokee Technical Forum 11 12-14-2010 03:12 PM
My oil guage is acting up and i don't think it's the sending unit kruucks XJ Cherokee Technical Forum 6 04-29-2009 09:54 AM
oil pressure sending unit, coolant temp unit h2rescue XJ Cherokee Technical Forum 6 01-31-2006 09:23 PM
Where's my Temp Sending Unit????? joshsg XJ Cherokee Technical Forum 3 06-22-2003 11:53 PM
