-   -   Tech/FAQ links and TSBs. (http://www.jeepforum.com/forum/f11/tech-faq-links-tsbs-89273/)
balloo93 06-19-2004 02:20 AM
EricsXJ and I decided to finally post up some links that could be used as a reference for a lot of the major question the board seems to have. PM me additional links that you think are necessary.
Special thanks to:
EricsXJ
GottaBeJeep
cfkingfish
lbsnowryder
Islandroaddie96
Roll Tide
XJ99
LOCKED UP
JVracer04
kapplera
sonicjay
xjfanatic
twisted_ed
fatwreck
cmotsvt
el_chupo_
Walton99
conrasm
nick_deno
zach1288
Andrew2516
Jeepin_XJ_101
00xj54
drew and not you
madrabbitt
XJ Xtreme
DefaZ
AZ Jeff
JBassXJ
Jeds Sr.
ben1.8t
sharpie1k
jeepkid8037
tozier9
CJ7-Tim
Blue-J
Steve88XJ
Kyle Deidrick
Atari.fan3000
TheRifleman
PESteele
Jmila1901
XJohnnyC
Cherokeegrrl
fourwheelerjeff
lost honda pro
mortalenema
dude_in_an_XJ
T4STE
Higgs98XJ
the_weirdo
89SAFARIXJ
HCI_Stang
XJ9635
Paraleyes
captain_ruggy
HERE WE GO:
balloo93 08-06-2004 09:45 PM
**TECH DOWNLOADS/ OFFROAD TECHNIQUE/LOCKER MANFACTURER LINKS**
COMPREHENSIVE GUIDE TO SENSOR DIAGNOSTICS ON THE 87-90 RENIX 4.0L
http://www.lunghd.com/Tech_Articles/...iagnostics.htm
84-01 PARTS CATALOGS
http://www.xjjeeps.com/tech_referenc...section=2&ID=0
AW4 TROUBLESHOOTING GUIDE
http://members.fortunecity.com/90limited/
AW4 TRANS MANUAL
http://www.pirate4x4.com/tech/billav...AW4_manual.PDF
AX15 TRANS MANUAL
http://www.pirate4x4.com/tech/billav...ssion_AX15.pdf
4WHEEL TERRAIN TECHNIQUES
**Not all XJ stuff, but general refrences. Some trick may not work with ECU vehicles.**
http://www.pps.net.au/4wdencounter/4wdtech/4wdtech.html
http://4wheeldrive.about.com/cs/off...aa020401a_4.htm
http://4wheeloffroad.com/techarticles/17158/
GENERAL OFFROAD TECH
http://www.4x4now.com/4wht.htm
http://4wheeldrive.about.com/gi/dyn...%2Fspotting.htm
http://4wheeldrive.about.com/gi/dyn...oa dguide1.htm
LOCKER MAKER LINKS
http://www.offroadlockers.com
http://www.eaton.com/EatonCom/Produc...cker/index.htm
http://www.traction.eaton.com
http://www.arbusa.com/
http://www.powertrax.com/
LOCKER VENDORS
http://www.differentials.com/catalog.html
http://www.drivetrain.com/Powertrex.html
COMPREHENSIVE LIST OF ACCESSORY MANUFACTURERS / FABRICATORS / VENDORS
http://www.jeepforum.com/forum/f11/comprehensive-list-accessory-manufacturers-fabricators-vendors-338529/
balloo93 12-21-2004 11:43 AM
**LIFTS**
HUGE LIST OF AVAILABLE LIFT KITS
http://www.jeepforum.com/forum/f11/all-read-xj-suspension-kit-options-enjoy-382635-post3394819/
TIRE LIFT COMBO
Stock lift:
http://jeepforum.com/forum/showthread.php?t=91208
http://jeepforum.com/forum/showthread.php?t=82869
Lifted fitment:
http://jeepforum.com/forum/showthread.php?t=90893
Overview of various lifts/tires:
http://jeepforum.com/forum/showthread.php?t=45602
TIRE SIZE COMPARISION/CONVERSION CALCULATOR
http://www.1010tires.com/TireSizeCalculator.asp
www.dakota-truck.net/TIRECALC/tirecalc.html
2" BUDGET BOOST COIL SPACER AND SHAKLE
http://www.delta4x4club.com/TECH/JEEP/BOOST.php
HOME BREWED BB LIFT
http://fitchva.com/jeep/?p=56
www.rocklizardfabrications.com/home_brew_budget_boost.htm
http://www.go.jeep-xj.info/HowtoFrontSpacer.htm
http://www.go.jeep-xj.info/HowtoRearSpacer.htm
http://www.go.jeep-xj.info/HowtoMainLeaf.htm
ROUGH COUNTRY/HECKETHORN (covers AAL install)
www.off-road.com/jeep/cherokee/99/09_sept/hrclift/hrclift.html
SKYJACKER 3" LIFT
www.polytropia.com/cherokee/suspension.html
OME 3.5
http://jeep.off-road.com/jeep/article/articleDetail.jsp?id=258011
RE 3.5" SUPER FLEX LIFT
http://www.jeepforum.com/forum/f11/how-install-lift-many-pics-404101/
RE 5.5" HD LIFT
http://www.delta4x4club.com/TECH/JEEP/RE55XJLIFT.php
TNT LA KIT
http://www.projectxj.com/mods/long.arms.htm
S10 LEAF SWAPS
http://www.naxja.org/forum/showthread.php?t=50083
DAKOTA LEAF SWAPS
http://www.lunghd.com/Tech_Articles/...udget_Lift.htm
balloo93 12-21-2004 11:47 AM
**SUSPENSION MODS AND FIXES**
DIY DRIVE WAY ALIGNMENT
http://www.go.jeep-xj.info/HowtoAlignment.htm
HOW TO REMOVE REAR SWAY BAR
http://members.tripod.com/Jeep_n_John/swaybar.html
REDRILLING STOCK TRAC-BAR MOUNT AFTER LIFT
http://www.go.jeep-xj.info/HowtoTrackbar.htm
HOMEBREWED LONG ARMS
http://www.jeepforum.com/forum/f11/another-homebrew-bootyfab-longarm-build-248377/
DEATH WOBBLE FIXES
www.kevinsoffroad.com/techarticles/deathwobble.html
http://www.yuccaman.com/jeep/dw.html
HOME BREWED BPE FRONT AND REAR
http://www.jeepforum.com/forum/f11/how-do-you-make-barpin-eliminators-91472/
www.lunghd.com/Tech_Articles/Suspension_Steering_Axles_and_Brakes/Rear_BPEs.htm
REAR SHOCK MOUNT RELOCATION (higher mount more ground clearence)
http://www.go.jeep-xj.info/HowtoRearShockM.htm
REAR UPPER SHOCK MOUNT REPAIR/ OPTIONS (BPE's)
www.rocklizardfabrications.com/broken_shock_mounts.htm
http://www.jeepforum.com/forum/f11/shock-bolt-replacement-fix-pics-heavy-323809/
SHOCK LENGTH GUIDE FOR DIFFERENT LIFTS SIZES (other tech too)
http://www.jeepforum.com/forum/f11/length-4-lift-shocks-751414/
QUICK DISCONNECTS
http://jeep.off-road.com/jeep/articl....jsp?id=257890
http://www.jksmfg.com/support.htm
DIY QUICK DISCONNECTS
http://www.off-road.com/jeep/cheroke...isconnect.html
http://www.cardomain.com/ride/325707/12
ADJUSTING BUMPSTOP LENGTH
www.rocklizardfabrications.com/Adjusting_Bumpstops.htm
HOMEBREWED TC DROP BRACKET
http://www.go.jeep-xj.info/HowtoTCdrop.htm
LCA and UCA LENGTHS FOR DIFFERENT LIFT SIZES
http://www.yuccaman.com/jeep/re_db.html
WJ CONTROL ARMS FOR LESS RUBBING UP TO 3-3.5" LIFT
http://www.madxj.com/MADXJ/technical...rms/WJ_LCA.htm
balloo93 12-21-2004 11:52 AM
**FRONT AND REAR AXLES // DRIVESHAFTS**
DOUBLE CARDAN REBUILD
http://www.pavementsucks.com/tech/doublecardan.php
http://www.jeepforum.com/forum/f11/cv-driveshaft-rebuild-part-deux-345170/
http://www.stu-offroad.com/axle/driv...iveshaft-5.htm
DIFF COVER INSTALL
http://www.jeepforum.com/forum/f11/d30-differential-cover-swap-writeup-429732/
PINION SEAL REPLACEMNT FOR D30 AND D35
http://www.jeepingsingles.net/tech/pinionseal.asp
STOCK JEEP AXLE GUIDE
http://www.tellico4x4.com/index.php/cPath/2880_76_2934
FRONT AND REAR AXLE GUIDE
http://www.yuccaman.com/jeep/gear1.html
http://memimage.cardomain.net/member...7_182_full.jpg
http://www.xjjeeps.com/tech_referenc...section=2&ID=3
8.25 - http://www.jeepforum.com/wiki/index.php/Chrysler_8.25
d35 - http://www.jeepforum.com/wiki/index.php/Dana_35
GEAR RATIO CHART AND FORMULA FOR TIRE SIZES
http://www.superlift.com/library/gears.asp
FRONT D30 AXLE and STEERING
XJ FRONT LEAF CONVERSION
www.pirate4x4.com/tech/billavista/Leafspring_conversion/leafs.htm
ZJ TO XJ TIE ROD CONVERSION (couple of TJ articles, but XJ and TJ use same steering linkage)
http://www.jeephorizons.com/tech/tjtierod/
http://www.stu-offroad.com/steering/zjtie/tierod-1.htm
http://members.rennlist.com/gman/jeep/
TIE ROD END DUST BOOT REPLACEMENT (poly boots can be bought at most auto parts stores if you can't find factory replacements)
http://www.go.jeep-xj.info/HowtoTieRod.htm
STEERING STABILIZER REPLACEMENT
http://www.4x4xplor.com/steeringstabilizer.html
STEERING
STEERING STOP ADJUSTMENT (On a TJ, but same set up as the XJ knuckles)
http://www.4x4xplor.com/steerstop.html
DANA30 HOME_BREWED POSI_LOCK SYETEM AND VACUUM DIAGRAM
http://www.gljt.org/modules.php?name...wtopic&t=10033
http://www.4x4wire.com/dodge/tech/solid_axle_cad/
http://www.driveev.com/jeepev/convpgs/4x4convert.php
FRONT HUB REPLACEMENT
www.off-road.com/jeep/cherokee/2001/02_feb/bearing/index.html
BALL JOINT REPLACEMENT
http://www.madxj.com/MADXJ/technical...balljoints.htm
D30 PINION SEAL
http://www.madxj.com/MADXJ/technical...inionSeals.htm
D30 AXLE SEALS INSTALL
http://www.delta4x4club.com/TECH/JEEP/TUBESEALS.php
FRONT HUB CONVERSION
http://www.delta4x4club.com/TECH/JEEP/HUBS.php
SWAPPING 1 PIECE TJ AXLES INTO A VAC DISCO D30
http://www.stu-offroad.com/axle/yjd3...jconvert-1.htm
XJ DANA30 / 297-X UJOINT UPGRADE/ UJOINT REBUILD
www.madxj.com/MADXJ/technical/technicalfiles/ARD30shafts297andSeals/D30shafts297andSeals.htm
http://www.4x4wire.com/tech/axle/ujoint/
http://www.jeepin.com/features/ujoint/index.asp
http://www.delta4x4club.com/TECH/UNIVERSAL/UJOINTS.php
LOCK RITE LOCKER INSTALL (TALL GEARS) WITH CARRIER REMOVAL STEPS
http://www.jeepaholics.com/tech/lrhubs/default.htm
http://www.4x4wire.com/jeep/tech/axle/lr00a/
REAR AXLE
XJ DANA44 AXLE SWAP
www.pirate4x4.com/tech/billavista/D44_buildup/D44.htm
RING AND PINION INSTALL (GEARS) ON A CHRY-CO 8.25 AXLE
http://www.jeepforum.com/forum/f11/gear-install-chryco-8-25-a-109859/
http://www.rockfrogs.org/phpBB2/view...9ca48330e3c63b
AXLE PIC CHART FOR COMMON AXLES
PICS OF A D35 AND A CHRYSLER 8.25 REAR AXLES
http://www.jeepforum.com/forum/f11/rear-axles-how-can-i-tell-88078/
FORD 8.8 REAR AXLE SWAP INFO
http://members.cox.net/rough-riders/...8/ford8_8.html
http://www.bc4x4.com/tech/2003/xj88/
http://www.4x4wire.com/jeep/tech/axle/ford8_8/
http://xjfanatic.com/ford88.php
http://www.jedi.com/obiwan/jeep/ford88.html
LARGE TECH AND FAQ ON THE 8.8
http://www.jeepsunlimited.com/forums...d.php?t=674123
balloo93 12-21-2004 11:56 AM
**RECOVERY AND PROTECTION**
SIMPLE TO THE POINT DIY FRONT RECOVERY BUMPER
http://jeep_n_john.tripod.com/bumperpage1.htm
CRUDE DIY TOWHOOK BRACKET SCHEMATIC
http://www.bc4x4.com/tech/2004/xjhook/
TOW HOOK INSTALLATION
www.off-road.com/jeep/cherokee/99/11_nov/cust4x4hooks/cust4x4hooks.html
INSTALLING PRE 96 TOW HOOK BRACKETS ON A 97+
http://www.jeepforum.com/forum/f11/how-install-pre-96-oe-tow-hook-brackets-97-pics-485570/
SKIDROW TRANSFER CASE SKID
http://www.delta4x4club.com/TECH/JEEP/TCASESKID.php
TOMKEN TRANS SKID
http://www.ericsxj.com/tomken.htm
MOPAR GAS TANK SKID / RECEIVER HITCH
BUMPER INSTALLATION (FRONT)
REAR HIDDEN HITCH INSTALL
http://www.cardomain.com/ride/325707/13
TRAILER HITCH WIRING INSTALL
http://www.jeepin.com/features/trailerwiring/index.asp
balloo93 12-21-2004 11:59 AM
**TRANSMISSION AND TRANSFER CASE**
General AX5 INFO
http://www.novak-adapt.com/knowledge/ax5.htm
General AX15 INFO
http://www.novak-adapt.com/knowledge/ax15.htm
General AW4 INFO
http://www.novak-adapt.com/knowledge/aw4.htm
http://jeepforum.com/forum/showthread.php?t=273048
GENERAL NP231 INFO
http://www.novak-adapt.com/knowledge/np231.htm
GENERAL NP207 INFO
SWAPPING IN A MANUAL FOR AN AUTO
http://www.jeepforum.com/forum/f11/automatic-manual-swap-thread-258497/
B&M TRANS TEMP GAUGE INSTALL
http://jeepin.com/features/tranny_temp_gauge/index.asp
http://4x4trailhunters.com/tech/article.php?id=12
B&M AUX TRANS COOLER
http://www.cardomain.com/ride/325707/11
http://www.jeepin.com/features/trannycooler/index.asp
TRANS GEAR RATIOS
AX15- http://www.off-road.com/jeep/tech/trans/ax15.html
AX5- http://www.off-road.com/jeep/tech/trans/ax5.html
BA10/5- http://www.off-road.com/jeep/tech/trans/ba10.html
TF904/909- http://www.off-road.com/jeep/tech/trans/tf904.html
AW4- under best auto trans http://www.off-road.com/jeep/cherokee/xjtech/jeepspeedfaq/
NUETRAL SAFETY SWITCH REBUILD
http://jeepin.com/features/nss
http://jp.automotive.com/93239/154-0805-1987-2001-jeep-cherokee-neutral-safety-switch/index.html
http://www.boyandjeep.com/tech-articles/aw4-neutral-start-switch-rebuild
NUETRAL SAFETY SWITCH REBUILD AND SCHEMATICS
http://www.cherokee-jeep.com/1-2swremov.htm
AW4 TRANSMISSION OVERRIDE SWITCH
http://www.go.jeep-xj.info/HowtoAutoSwitch.htm
http://jeepforum.com/forum/showthread.php?t=234510
http://members.cox.net/steve88xj/aw4/
http://www.jeepforum.com/forum/f11/aw4-tcu-mod-write-up-234510/
SPEEDO GEAR SWAP FOR RECALIBRATING SPEEDO (BIGGER TIRES)
http://jeepin.com/features/speedogear/index.asp
www.off-road.com/jeep/cherokee/98/07_jul/speedo/speedo.html (note: chart #'s in this article are wrong.)
GREASING THE OUTPUT SHAFT/SLIP YOKE
http://www.jeepforum.com/forum/f11/greasing-slip-joint-97-xj-s-write-up-357569/
REPLACING THE REAR OUTPUT SEAL (SLIP YOKE HOUSING)
http://www.go.jeep-xj.info/HowtoTCseal.htm
FIX FOR A NP242 STUCK IN 4PART TIME
http://www.jeepforum.com/forum/f11/stuck-part-time-4-wheel-drive-427233/
NP231 PARTAIL OVERHAUL
http://4x4trailhunters.com/tech/article.php?id=20
NP242 PARTAIL OVERHAUL
http://www.mallcrawlin.com/forum/showthread.php?t=8549
NP241OR RUBICON TRANSFER CASE SWAP INFO
http://www.jeepforum.com/forum/showt...=1#post3056557
http://www.jbconversions.com/pages/reviews/showpage.php?m=4wor&i=2004.07_n2&p=1
NP231 TO NP242 SWAP
http://www.weatherlover1.com/jeep/242.htm
DIY WIDE CHAIN NP231
http://www.madxj.com/MADXJ/technical/technicalfiles/JAtCaseUpgrade/tCaseUpgrade.htm
TRANSFER CASE DROP INSTALL
http://www.jeepforum.com/forum/f11/how-install-tc-drop-write-up-405578/
The Official SYE (Slip Yoke Eliminator) Thread
http://www.jeepforum.com/forum/f11/official-sye-slip-yoke-eliminator-thread-all-read-426483/
DOWN AND DIRTY HOMEMADE SYE FOR ODD TRANSFER CASES OR CHEAP SOBs
http://www.naxja.org/forum/showthread.php?t=80289
**SYE (Slip Yoke Eliminator) NP231 TC (XJ and YJ/TJ use the same methods for install)**
ADDITIONAL AA/PORC SYE INFO
http://www.jeepforum.com/forum/f11/sye-install-supplemental-photos-212704/
http://www.yuccaman.com/jeep/****_sye.html (you have to copy, paste, and add porc manually in place of the ****)
ADDITIONAL RE Hack-N-Tap/FRONT DS COMBO
http://www.jeepforum.com/forum/showt...dapter+hack%2A
VIDEO OF A AA OR **** TYPE SYE INSTALL
http://www.crgrissom.com/jeep/SYE.wmv
AA- http://www.4x4wire.com/jeep/reviews/aasye99/
http://www.4x4xplor.com/SYE-CV.html
RE 88-95- http://www.dorianjepsen.com/wrangler/syekit/index.php
http://www.dpgoffroad.com/tech/rubiconsye.htm
RE 96-01- http://www.yuccaman.com/jeep/sye.html
www.off-road.com/jeep/cherokee/98/03_mar/RE_SYE/slip-yoke.html
Tom Woods- http://www.polytropia.com/cherokee/sye.html
JB- http://www.rockcrawler.com/techreports/JB_Wood_crosstrainer/index.asp
http://www.jpmagazine.com/howto/29623/
http://7slotgrille.com/tech/sye2/
DIY Hack-n-tap STYLE SYE FOR NP231
SYE (Slip Yoke Eliminator) NP242 TC
RE- http://www.polytropia.com/cherokee/sye.html
http://www.angelfire.com/nc3/84jeepxj/sye.html
JB CONVERSIONS "SHORTY" SYE
http://www.jeepin.com/features/supershorty/index.asp
DATABASE OF DIFFERENT MAKERS CV DRIVESHAFTS FOR CHEAP SYE
ADDITIONAL INFO ON STOCK ADAPTERS FOR HACK-N-TAP/STOCK DS COMBO
http://www.jeepforum.com/forum/showp...46&postcount=2
balloo93 12-21-2004 12:01 PM
**BRAKE SYSTEM UPGRADES AND MAINT**
DIFFERENCES BETWEEN CAST AND COMPOSITE ROTORS AND HUB DIFFERENCES
http://jeepforum.com/forum/showthread.php?t=360959
USING YJ BRAKE LINES FOR LIFTED XJ
www.madxj.com/MADXJ/technical/technicalfiles/ARyjBrakeHosesOnXJ/YJbrakeHosesOnXJ.htm
USING YJ E-BRAKE CABLES FOR LIFTED XJ
http://www.jeepforum.com/forum/f11/extended-e-brake-cable-lifts-345675/
http://www.4x4wire.com/jeep/tech/brakes/xjhoseext02/
BRAKE JOBS/GUIDES
http://jeepin.com/features/drums/index.asp
http://jeepin.com/features/discs/index.asp
http://go.jeep-xj.info/HowtoFrontDisks.htm
http://go.jeep-xj.info/HowtoRearDrums1.htm
MEMBER DRUM BRAKE JOB
http://www.jeepforum.com/forum/f11/drum-brakes-write-up-hope-helps-534338/
UPGRADING MASTER CYLINDER ON PRE 95 XJ's
www.madxj.com/MADXJ/technical/technicalfiles/ARbrakeBoosterUpgrade/BrakeBoosterUpgrade.htm
http://www.4x4wire.com/jeep/tech/bra...kes03/booster/
http://www.cardomain.com/ride/325707/15
REAR DISC BREAKS ON A Chry Co 8.25 REAR AXLE
http://geocities.com/dcpaschal/mitch.html
http://cherokeekid5.tripod.com/zj_discs_on_a_xj.htm
http://home.swbell.net/rriojas3/reardisk.html
http://www.jeepforum.com/forum/f11/fitting-kj-liberty-rear-disc-brakes-xj-cherokee-8-25-axle-750112/
REAR DISC BREAKS ON A D44 REAR AXLE
http://jeepin.com/features/cvdiscs/index.asp
REAR DISC BREAKS ON A D35 and D44 REAR AXLE
www.madxj.com/MADXJ/technical/technicalfiles/BAzjRearDiscsOnXJ/ZJrearDiscsOnXJ.htm
balloo93 12-21-2004 12:06 PM
**COOLING**
THINGS TO CHECK IF YOU ARE OVERHEATING
http://www.lunghd.com/Tech_Articles/Cooling/Overheat_Diagnosis.htm
3CORE RAD INSTALL
http://www.jeepin.com/features/gdi/index.asp
FAN TEMP SENSOR TEST
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/15/1c/7f/0900823d80151c7f.jsp
AUX FAN TEST WITH A JUMPER
http://www.fivezerofive.com/cpg132/...ls.php?album=81
INSTALLING NEW RADIATOR
http://www.go.jeep-xj.info/HowtoRadiatorFitting.htm
BURPING the COOLING SYSTEM
http://www.lunghd.com/Tech_Articles/Cooling/BurpAirMod.htm
CONVERTING THE CLOSED COOLING SYSTEM
www.geocities.com/chmwatson/FAQs/Jeep/radconv_overflow-bottle.html
www.off-road.com/jeep/cherokee/98/12_dec/radiator/radiator.html
www.madxj.com/MADXJ/technical/technicalfiles/JTopenSystemSwitch/OpenSystemSwitch.htm
TIGHTEN/LOOSEN THE SERPENTINE BELT
87-95 http://www.cardomain.com/ride/2406854/2
96-01 Serp Belt - JeepForum.com
WATER PUMP REPLACEMENT
http://jeepin.com/features/waterpump/index.asp
http://www.cardomain.com/ride/325707/17
OVERRIDE SWITCH ON ELEC FAN
for a 99, may work with other OBDII Radiator Fan Override Switch (The Easy Way) - NAXJA Forums -::- North American XJ Association
OBDI http://www.jeepforum.com/forum/f11/a...p-pics-811703/
balloo93 12-21-2004 12:08 PM
**BODY MODS**
FACTORY PAINT CODE LOACTION AND HOW TO READ IT
Find Your Paint Code Location
HOMEMADE DIY GUTTER MOUNTS FOR A RACK
Homebrewed Gutter-Mount Roof Rack
PUTTING 97+ FRONT CLIP ON A OLDER XJ
97+ Panel swap
STUCK HATCH FIX
Fixed the hatch today...
HOMEBREWED REMOVALABLE DOOR
myXJ.Net
97+ http://jeepforum.com/forum/showthread.php?t=408138
TRIMMING FENDERS
www.madxj.com/MADXJ/technical/technicalfiles/JAfenderTrimming/FrontFenderTrim.htm
(Front Fender Trimming)
www.madxj.com/MADXJ/technical/technicalfiles/SRrearFenders/rearfender.htm
(Rear Fender Chop)
Jeepin.com: "Stage-one" XJ fender trimming
Fender Trimming
DELTA 4X4 CLUB TECHNICAL DEPARTMENT - JEEP CHEROKEE XJ FENDER CUTTING AND TRIMMING
Write Up: Cutting & Folding Rear Fenders (rear fender cut and fold)
http://www.jeepforum.com/forum/f11/w...-tires-955688/
CUSTOM TUBE FENDERS
Tube flare write up. - NAXJA Forums -::- North American XJ Association
CUTTING REAR LOWER QUARTERS
Paraleyes- http://www.jeepforum.com/forum/f11/c...5/#post9237914
http://www.naxja.org/forum/showthrea...lower+quarters
POOL NOODLES TO FILL GAPS
TJ FLARE INSTALL
XJ TJ Flare Install
korda's XJ | mods | TJ flares
http://www.cardomain.com/ride/588437/10
TJ flares and Paint finally done! - NAXJA Forums -::- North American XJ Association
Trimming rear Fenders & Installing TJ flares (Lotta pics)
FENDER FLARE RELOCATING
www.madxj.com/MADXJ/technical/technicalfiles/TPfenderFlares/FenderFlares.htm
Yucca-Man: 53guy's Rear Fender Trim Write-up, retaining the stock flare (Best I've seen!)
INSTALLING NEWER (97+) DOOR SEALS ON OLDER XJ
www.madxj.com/MADXJ/technical/technicalfiles/ARdoorSeals/DoorSeals.htm
HOOD VENTS
Tech article - Hood Vents
DELTA 4X4 CLUB TECHNICAL DEPARTMENT - LEBARON HOOD VENTS
Extreme Duty Replacement Rocker Panels
3"x4" Custom rocker panel replacement using box steel to withstand any trail abuse there is.
www.madxj.com/MADXJ/technical/technicalfiles/SRrockerPanels/RockerPanels.htm
Extreme Custom Heavy Duty Rocker Panels
Completely custom-made hard core custom rocker panel replacement. Possibly the most complicated/sophisticated way of building weld-in rocker panel replacements.
www.madxj.com/MADXJ/technical/technicalfiles/JArockRails/RockRails.htm
Serious High-Clearance Rocker Panel Replacement
2"x6" Custom rocker panel replacement with ultimate ground clearance gains, requiring the doors to be shortened! Rockers setup as air tanks also.
Heavy hacking ahead!
www.madxj.com/MADXJ/technical/technicalfiles/ARrockerPanels/RockerPanels.htm
Replacing Rear Quarter Window
http://www.jeepforum.com/forum/f177/...xj-zj-1143392/
balloo93 12-21-2004 12:11 PM
**INTERIOR AND ELECTRICAL**
DIY SECURITY CONSOLE WITH STOCK PARTS
http://jeepforum.com/forum/showthread.php?t=394307
GRAND CHEROKEE SEATS FRONT AND REAR IN A XJ
http://www.jeepforum.com/forum/f11/wj-seats-installed-353084/
http://www.jeepforum.com/forum/f11/2-door-seat-swap-flip-forward-write-up-752202/
HOW TO TIGHTEN UP A LOOSE TILT STEERING WHEEL COLUMN
http://www.chevyasylum.com/column/tiltcol.html
HOW TO REPLACE KEY CYLINDER ON 88
http://www.naxja.org/forum/showthrea...n+lock+removal
HOW TO REPLACE KEY CYLINDER ON 96
http://www.sparkys-answers.com/2009/...ower-inop.html
KEY STUCK IN CYLINDER
http://www.jeepforum.com/forum/f11/removed-key-stuck-ignition-write-up-530673/
REPLACING THE DOOR LOCK ACTUATOR ON A 97+
http://www.links4jeeps.com/writeups/lock_actuator/
REPLACING THE TURN SIGNAL MULTI_SWITCH ON A 97+
http://www.jeepforum.com/forum/showt...ht=turn+signal
97+ WINDOW NOT WORKING EXCEPT DRVS SIDE
http://www.jeepforum.com/forum/showt...ght=door+locks
INSTALLING 97+ WEATHER STRIPPING ON A PRE97
http://www.madxj.com/MADXJ/technical.../DoorSeals.htm
COMPASS AND CLOCK CALIBRATION INFO
http://www.jeepforum.com/forum/f11/stock-compass-help-313788/
DIY IGN KILL SWITCH
http://autospeed.drive.com.au/cms/article.html?&A=0059
BEDLINING THE FLOORBOARD
http://jeepforum.com/forum/showthrea...lined+floor%2A
HEADLINER REPARE INSTALL
http://www.lunghd.com/Tech_Articles/.../Headliner.htm
http://www.wlsheadliners.com/tutorials/cherokee/
http://www.4x4xplor.com/headliner.html
WALMART OFFROAD LIGHT COVER MOD
http://www.jeepforum.com/forum/showt...=355895&page=3
WALMART OVERHEAD LIGHTS MOD
http://www.jeepforum.com/forum/showt...=walmart+light
HEADLIGHT UPGRADES
http://www.jeepforum.com/forum/showp...1&postcount=15
http://www.go.jeep-xj.info/HowtoHeadlightLoom.htm
ONE OF THE BEST HD HEADLIGHT HARNESS WRITE UPS I HAVE EVER READ
http://fitchva.com/jeep/?p=57
LED TAILIGHT CONVERSION
http://www.driveev.com/jeepev/convpgs/ledlighting.php
LED INTERIOR/CLUSTER CONVERSION
http://www.jeepforum.com/forum/f140/97-xj-interior-led-conversion-486998/
CLUSTER CONVERSION
http://www.jeepforum.com/forum/f11/97-xj-gauge-cluster-swap-write-up-how-752630/
INTERIOR STORAGE DECK
http://www.ericsxj.com/storage.htm
http://www.jeepforum.com/forum/f11/storage-sub-box-write-up-handy-dandy-super-duper-storage-box-197251/
INTERIOR STORAGE DECK (With the add-on for leveling out cargo with seat down)
http://www.yuccaman.com/jeep/storage.html
97+ QUARTZ CLOCK INSTALL IN A PRE 97XJ
http://www.jeepforum.com/forum/f11/quartz-clock-wrie-up-64514/
http://www.go.jeep-xj.info/HowtoDashClock.htm
CB RADIO
SPEAKER UPGRADES / SUB ENCLOSURES
http://www.jeepforum.com/forum/f11/write-up-97186/
LED BACKLIGHTING FOR GAUGE PANEL
http://www.jeepforum.com/forum/f11/led-panel-lights-conversion-write-up-109945/
GAUGE SWAP
http://www.jeepin.com/features/gaugeswap/index.asp (88-90 to 91-95 cluster swap)
ON BOARD AIR INSTALLATION
http://www.rocklizardfabrications.com/power_tank.htm
http://www.ericsxj.com/oba.htm
UPGRADING CHARGING SYSTEMS (slow starts and better charging)
http://www.bc4x4.com/tech/2004/jeepalt/
UPGRADING YOUR ELECTRICAL SYSTEM TO SUPPORT HIGH-AMPERAGE ACCESSORIES
http://jeep.off-road.com/jeep/articl....jsp?id=277034
BUILD YOUR OWN HD BATTERY CABLES AND GROUND STRAP
http://www.geocities.com/JeepI6Power/electric.html
http://www.jeepforum.com/forum/f11/upgrading-negative-battery-cables-lots-pics-444922/
http://www.jeepforum.com/forum/f11/upgrading-positive-battery-cables-lots-pick-445428/
http://www.jeepforum.com/forum/f11/replaced-engine-ground-strap-writeup-lots-picks-444082/
UPGRADING A 87-90 WITH A 136AMP ALTENATOR
http://www.jeepforum.com/forum/f11/136-amp-alternator-mod-338597/
http://www.naxja.org/forum/showthrea...rnal+regulator
DUAL BATTERY
www.pirate4x4.com/tech/billavista/dual_battery/my_dual_battery_setup.htm
www.4wdandsportutility.com/tech/03054wd_batteries/
http://www.madxj.com/MADXJ/technical/technicalfiles/ARbattRelocation/BattRelocation.htm
http://www.hellroaring.com/4wheel.htm
http://www.wranglernw.com/pc-6370-79...1987-2001.aspx
HVAC BLOWER FIX (if motor speed selector not working)
www.geocities.com/chmwatson/FAQs/Jeep/HVAC-fuselink_fix.html
HVAC VACUUM DIAGRAM (FOR A 92)
http://autorepair.about.com/library/...bl312a-lib.htm
HVAC HEATER BLOWER MOTOR REPLACEMENT ?-96
http://www.lunghd.com/Tech_Articles/...ower_Motor.htm
HVAC HEATER BLOWER MOTOR REPLACEMENT 97-01
http://autorepair.about.com/library/a/1i/bl793i.htm
http://www.jeepforum.com/forum/f11/97-xj-blower-motor-removal-replacement-367612/
HVAC HEATER CORE REPLACEMENT
http://autorepair.about.com/library/a/1h/bl566h.htm
http://www.naxja.org/forum/showthrea...#post243641386
WIRING SCHEMATICS FOR 1984 - 1998 XJ AND MJ
http://www.autozone.com/servlet/UiBr...3d80153e8f.jsp
FUSE BLOCK DIAGRAM FOR '00 XJ's
http://www.jeepforum.com/forum/f11/fuse-diagram-2000-xjs-33820/
balloo93 03-30-2005 04:42 PM
**Maintenance**
FLUID QUANTITIES AND TYPES
http://www.quadratec.com/jeep_knowle...rticle-123.htm
TIGHTENING/LOOSENING THE SERPETINE BELT
AXLE FLUID CHANGE
http://www.getahelmet.com/jeeps/maint/diff_fluid/
http://www.off-road.com/jeep/cheroke...ept/gb/gb.html
http://www.stu-offroad.com/misc/diff-1.htm
SPARK PLUG REPLACEMENT ON 00 and 01 4.0L ENGINES
http://jeephorizons.com/tech/spark.html
BELTS, BRAKE FLUID, POWERSTEERING, AND TC
http://go.jeep-xj.info/HowtoService.htm
AW4 TRANS SERVICE
http://go.jeep-xj.info/HowtoAutoService.htm
FRONT AND REAR BRAKES
BRAKE BLEEDING
http://www.stu-offroad.com/suspensio...brakebleed.htm
O-RING REPLACEMENT ON FUEL INJECTORS
http://autorepair.about.com/library/a/1f/bl522f.htm
REPLACING FUEL PUMP ON A 97+
http://www.jeepforum.com/forum/showt...highlight=fuel
Serpentine belt routing 95
http://autorepair.about.com/library/...bl506a-lib.htm
WIPER BUSHING REPLACEMENT
http://www.jeepforum.com/forum/f11/windshield-wiper-fix-new-pics-jeep-268354/
balloo93 06-10-2005 02:03 AM
**WHEEL AND TIRE TECH**
JEEP RIMS LISTING THROUGHOUT THE YEARS
http://www.jeepforum.com/forum/f177/jeep-cherokee-stock-rims-encyclopedia-320730/
BOLT PATTERN FOR VARIOUS MAKES AND MODELS
http://www.discountedwheelwarehouse...._Reference.cfm
BACKSPACING INFO AND DEFINITIONS
http://www.high-impact.net/wheels/ba...lustration.htm
GENERAL WHEEL INFO
http://www.rsracing.com/tech-wheel.html
balloo93 04-15-2006 05:16 PM
**ENGINE MAINT, PERFORMANCE, AND UPGRADES**
DYNOMAX CAT BACK INSTALL
http://www.cardomain.com/ride/325707/10
INSTALLING A FLOWMASTER TO STOCK EXHAUST
http://www.jeepforum.com/forum/showt...=1#post3918726
HEADER OPTIONS FOR THE 00-01 4.0L
http://www.jeepforum.com/forum/f11/all-00-01-4-0l-xj-headers-offered-502290/
V8 SWAP INFO. LOTS OF INFO ON WHAT WILL WORK AND HOW TO FIT IT
http://www.novak-adapt.com/knowledge/xj_swap.htm
2.8L to 3.4L ENGINE SWAP
http://www.lunghd.com/Tech_Articles/...Project_XJ.htm
POSSIBLE HIGH IDLE SOLUTION
COMMON MISFIRE CONDITION ON 00-01 (INJECTOR 3)
http://www.jeepforum.com/forum/f11/2001-missfire-problem-72181/
CPS REMOVAL
http://www.jeepforum.com/forum/f11/crank-position-sensor-write-up-197260/
http://www.yuccaman.com/jeep/cps.html
CHECKING THE COIL AND CPS TESTING PROCEDURES
http://autorepair.about.com/library/faqs/bl077g.htm
CHECKING THE CAM POSTION SENSOR AND CRANK POSTION SENSOR (aka CPS)
DIY OBA (On Board Air) USING STOCK AC COMPRESSOR
http://www.jeepforum.com/forum/f11/complete-c-oba-write-up-tons-pics-194132/
DIY ADJUSTABLE MAP SENSOR
http://www.jeepbarracks.com/modules....article&sid=18
TB CLEANING THREADS/Link
http://www.off-road.com/jeep/cherok...ngine/tbody.htm
http://www.jeepforum.com/forum/f11/wow-new-plugs-air-filter-question-143804/
http://www.jeepforum.com/forum/f11/throttle-body-question-comment-154516/
NON-HO TO HO SWAP, QUICK OVERVIEW
http://www.off-road.com/jeep/cheroke...p/engswap.html
INSTALLING A 99+ INTAKE ON A 91-98 HO HEAD
http://www.jeepforum.com/forum/f11/banks-header-01-intake-manifold-swap-1993-xj-my-version-215685/
CHECKING AND ADJUSTING THE TPS ON A 87-90 4.0L
http://autorepair.about.com/library/faqs/bl232i.htm
READING THE OBDII DIAGNOSTIC CODES
http://www.getahelmet.com/jeeps/tech/codes/
http://www.allpar.com/fix/computer-codes.html
READING OBDI DIAGNOSTIC CODES
http://go.jeep-xj.info/HowtoECUcodes.htm
OIL IN AIR FILTER (BLOW BY) FIXES
www.off-road.com/jeep/cherokee/xjtech/engine/40ltr/blowby.htm
www.off-road.com/jeep/cherokee/98/04_apr/valvecover/cover.html
www.madxj.com/MADXJ/technical/technicalfiles/JAvalveCover/ValveCover.htm
http://www.yuccaman.com/jeep/filter.html
INSTALLING A EXTERNAL IN-LINE FUEL PUMP
http://www.delta4x4club.com/TECH/JEEP/SWAMPYBYPASS.php
REPLACING FUEL FILTER ON A 97+
http://www.jeepforum.com/forum/f11/fuel-filter-pump-replacement-97-s-up-138580/
OIL PRESSURE SENDING UNIT TROUBLESHOOTING
CONVERTING TO LARGER OIL FILTER
www.madxj.com/MADXJ/technical/technicalfiles/ARoilFilterConversion/OilFilterConversion.htm
FUEL INJECTOR O-RING REPLACEMENT
www.off-road.com/jeep/cherokee/xjtech/engine/oring.html
CHANGING THE OIL ADAPTER O-RINGS
http://www.cardomain.com/ride/325707/3 (Cardomain is messed up. Go To page3 for writeup)
http://www.lunghd.com/Tech_Articles/...nt_O-Rings.htm
www.madxj.com/MADXJ/technical/technicalfiles/ARoilFilterConversion/OilFilterConversion.htm (covers removal and
install of Oil FIlter Adapter Housing).
MOTOR MOUNT REPLACMENT
http://www.jpmagazine.com/howto/31818/
www.off-road.com/jeep/cherokee/xjtech/engine/engmounts/
www.off-road.com/jeep/cherokee/2001/01_jan/EngineMounts2/mount.html
http://jeepin.com/features/motormounts/index.asp
REAR MAIN SEAL REPLACEMENT
http://jeepin.com/features/rearmain/index.asp
BORING A HO (91+ 4.0L) THROTTLE BODY OUT TO 60mm
http://go.jeep-xj.info/HowtoTBboring.htm
http://www.cardomain.com/memberpage/325707/2
ARB SNORKLE INSTALL
http://www.delta4x4club.com/TECH/JEEP/SNORKEL.php
HOMEBREWED SNORKLE/ DEEP WATER INTAKES
www.pirate4x4.com/tech/billavista/snorkel/snorkel.htm
www.madxj.com/MADXJ/technical/technicalfiles/JAairIntake/AirIntake.htm
www.madxj.com/MADXJ/technical/technicalfiles/JJcustomSnorkle/CustomSnorkle.htm
REMOVING STOCK AIR BOX SILENCER/VENTURI
www.go.jeep-xj.info/HowtoSilencer.htm
OPEN AIR (CONE FILTER) INTAKES
http://www.patricksnorton.com/cherokee/tech/afilter.php
http://www.cardomain.com/ride/325707/7
MUSTANG CONE STYLE AIR BOX CONVERSION
http://www.jeepforum.com/forum/f11/96-04-mustang-gt-intake-mod-how-462724/
STROKER ARTICLES FOR THE 4.0L
http://www.angelfire.com/my/fan/stroker.html
www.madxj.com/MADXJ/technical/technicalfiles/DMstrokerStory/StrokerSummary.htm
http://www.bc4x4.com/tech/bryce/stroker/stroker.cfm
NUTTER BYPASS AND VARIOUS OTHER INFO ON CARB'D APPLICATIONS
http://www.m1911.org/cherokee_mods.htm
balloo93 07-23-2006 02:09 PM
***STEERING***
STEERING BOX REBUILD
http://www.fourwheeler.com/techarticles/drivetrain/129_0801_saginaw_steering_box_rebuild/index.html
DIY INCREASED PRESSURE AND VOLUME MOD
http://westtexasoffroad.homestead.com/powersteering.html
DRIVEWAY ALIGNMENT
http://www.4x4xplor.com/alignment.html
http://www.madxj.com/MADXJ/technical/technicalfiles/BSlowerWJctrlArms/WJ_LCA.htm
ADJUSTING THE STEERING BOX
http://en.allexperts.com/q/Jeep-Repair-817/Jeep-repair-maintenance.htm
LOOSE STEERING COLUMN FIX
SWAPPING IN A DURANGO STEERING BOX
http://www.naxja.org/forum/showthread.php?t=71626&highlight=durango
http://www.jeepforum.com/forum/f11/d...ughts-1191132/
STEERING PUMP COOLER
http://www.lunghd.com/Tech_Articles/Suspension_Steering_Axles_and_Brakes/Power_Steering_Cooler.htm
ORO OVER KNUCKLE STEERING INSTALL
http://jeepin.com/features/uturn
http://elcaminocentral.com/showthread.php?t=27192
http://www.fiero.nl/forum/Forum2/HTML/088020.html
The time now is 07:37 AM.
